Question about BenQ Scan to Web 5000U Flatbed Scanner
My computer is having problem, my battery meter is not reaching 100% i dont understand, because my computer is not old and am using window 7
  • 72 Answers
Not sure how long you are charging your laptop. But turn it off and let it charge for a 24 hour period to see if that makes a difference. You might need to fully discharge your battery (let it run down completely) and recharge it again. Do this a few times and see if you can get a full charge before disconnecting it.
Posted on Mar 13, 2011
Shutter release disabled recharge battery
If you are using the same battery, it could be it has reached the end of life. The charger can indicate the battery is fully charged, because the voltage has reached a correct level, but still the battery can have one or more bad cells. So as soon as you start using the battery, it can lose enough energy to give this nasty message. If you put in another battery and still have the same message, there must be a serious problem in the camera.
To check your battery, just after the camera has given this message, with a multi meter. You will see the voltage has dropped at least 1,2 volt beneath the voltage printed on the battery. The typical 7 volt Nikon battery, will give 8 volt on the multi meter. But placed in the camera it will drop to 7 volt. If the multi meter reading is less then 7 volt it has at least one bad cell and should be replaced.
Dec 27, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
Data retrieval
There are some things that you can try. Look and see if Vista drivers work. Also if you are using the more advanced versions of windows 7, you can use XP mode in the windows 7 environment and see if you can install the drivers for it.
Jun 29, 2013 | Iomega Computers & Internet
Acer Aspire battery level suddenly drops 80 %
Have you seen inside a laptop battery, it's not just a battery. It also has control circuitry inside, could be that. Not usually repairble but you can do some makes of battery. See here:Circuit.
Personally I would buy a new battery.
Jan 27, 2012 | Computers & Internet
The battery wont charge to 100%.. plus, the battery capacity decreases day by day.. i dont understand cause ive charged it for 3nights wont stop.. but it not reach 100%.. the indicatior also wont change...
The battery could be faulty or the charging circuit is faulty. I suggest you return it to the supplier for repair or replacement as this netbook would still be under warranty.
If you try to repair it yourself you may void your warranty.
Jul 03, 2011 | Acer Aspire One AO532H-2527 Netbook
I cannot scan photos to my computer with the hp desktop all in one 340 series (windows 7) i have a power adapter plugged in and a cable wire in the front of the computer, somebody set up the computer to...
Hi there! i understand that you're having problems on how to scan photos using the computer or the printer itself, normally just to let you know something, your printer is some kinda old and i believe that it's already considered as an obsolete printer. Now, if you are using a windows seven operating system some of the old printers scan button is not working and you will need to do some workaround, and here's my tip for you. Open this link and it will walk you through to scan using a different software from your computer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01579338&cc=us&lc=en&dlc=en&product=1128309&tmp_track_link=ot_search#N3051
hope that it'll help you a lot.Goodluck!
May 30, 2011 | HP Deskjet F340 All-In-One Printer
When i formatted my computer and install windows 7 then i have lost my ethernet controller and vedeo controller .then what to do i dont understand . my model is VGN-fs295vp
Hello
You need to install drivers using the CD/DVD comes with your system, otherwise download from sony support web site by providing your model number.
Hope this helps
Jan 31, 2011 | IBM Integrated 10/100 Ethernet Controller
I got a dazzle dvc 100 but didnt get set up diks with it . where can i download the software so my dazzle will work . i run on windows 7
well you can download the drivers here 64 bit win 7 operating system or here 32 bit win 7 operating system.
but if you dont understand much of what i have put up above then use this link
link
Nov 14, 2010 | Pinnacle Dazzle DVD Recorder
I have a singer futura ce 200. MY old computer crashed so i got a new computer with windows 7. I read that i needed the upgrade to make it compatible but still cant get the software to intall. HELP!!
Go to your start menu, then look for internet explorer (32 bit) do not use the 64 bit. I have the same problem with using my printer. I hate windows 7, it stinks. All my old programs I have to do this with.
Oct 21, 2010 | Singer CE-100 Futura Computerized Sewing...
I have a medion computer approx 10years old and am hoping to load it with windows 7 but on trying to load this the computer says the proccesor needs changing can you tell me if this should be possible...
There is no way to run windows 7 on this computer. The hardware is just too old.
On the other hand, if you're used to this one, you can buy a new one with Windows 7 preloaded for under $400 (even at WalMart!) and it will work much better than the ten year old computer. Since Windows 7 costs about $100 just by itself, you can move up for only about $300 overall.
Feb 22, 2010 | Computers & Internet
Halecol
1)try to check also if you'll see a solid GREEN LED light on your ac adapter.if yes, possible problem could be on the battery port or the battery itself
2)With regard to the battery meter,where did you find that?If not in the BIOS,try this.restart computer and press F2 several times .Once you're inside the BIOS.try to go to the battery option-try to see if the battery indicator would say 100% also.
3)if 100%,try another battery if you have one.use only the battery as the only source of power..if a known good battery works then the problem is with your old battery.if a known good battery won't work,that would mean that you have a problem with your battery port.if that is the case, you may have to replace your motherboard for that but if you still have an active hardware warranty on your pavillion dv 4000.try calling the manufacturer for a motherboard replacement and try asking also if your battery is part of any recall.
4)if the battery meter in the BIOS does not say 100%, try charging the battery for an hour then go back to the BIOS try to see if the battery meter would go up.if it increases the battery meter try using the battery as the only source of power...if nogo,go back procedure 3.
Jan 17, 2008 | Computers & Internet
BenQ Scan to Web 5000U Flatbed Scanner Logo
23 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
