Question about Maytag Neptune FAV6800AW Top Load Washer
I have a FAV6800AWC Top Load Maytag Neptune When in spin cycle you cannot keep it balanced, makes a banging soud (loud) and kickes washer off
  • 668 Answers
It sounds like the spin basket rear support is loose. The support is part of the spin basket & does not come separately. This type of repair will more than likely need the spin basket replaced & possibly the outer tub also. It will cost you $200-300 to replace the assembly.
Hope this helps.
Shane
Posted on Mar 13, 2011
Cycle stuck on 23 minutes and keep repeating cycle
If you do a Spin Only cycle with that wash load will the machine Spin up?
If not any error code?
Does the wash Tub bang around with a Spin Only cycle?
Do you want to DIY the fix or call in a repair service?
Jan 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Will not balance the load. shows a unbalanced load error at every spin cycle. will only work with no clothes in
Tony see this post Clutch Fix
I feel the issue is a Clutch issue if the wash tub is banging around in Spin Cycle and errors out with thr UC unbalance code.
If you decide to dive in I will point you to another forum where I can help you.
Oct 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune Washer Spin Cycle
If your FAV6800A or FAV9800A wash tub is banging around in Spin Cycle of the Wash Cycle and your Control Board signals a dC or uC error code to the console I feel you have a Clutch malfunction. I feel the TDS is working as designed with the unblance error code shut down.
See my Clutch Fix post for more info related to dC and uC unbalance errors with the FAV6800A and FAV9800A TL’s and the repair action…….Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer? makes a
more than likely it just needs a little leveling...lift front of washer . there are 2 leveling feet on each front corner under the washer.. they turn like a screw ..just adjust these feet till its level and you should be ok....shake the washer by hand . if it doesnt move it shoud be level,,,,an unlevel washer makes terrible noises ...as you know..thanks and have a great day
Jan 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Off balance spin/poor wringing
CHECK TO MAKE SURE ALL THE SUSPENSION SPRINGS ARE CONNECTED INSIDE THE WASHER. IF SO, THERE IS A SNUBBER UNDER THE WASHER MILKSTOOL THAT IS MADE OUT OF PLASTIC THAT CAN WEAR AND NOT ALLOW THE SUSPENSION TO GLIDE LIKE IT IS SUPPOSED TO. NOT THE EASIEST FIX DUE TO THE BRAKE BEING UNDER HEAVY SPRING PRESSURE. USE CAUTION
Jan 25, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Three day old Indesit washing machine
Is it a maytag? My maytag front load washing machine had 2 long bolts with plastic braces on them, to keep the drum still during shipping. Mine would bang and shake all over. I got the book out before I finally figured it out. I had to take the back cover off and remove the bolts and plastic braces over them. They look like they' 8 inches long or so. It works great now.
Carolynn
Jul 15, 2008 | Indesit W 123 Front Load Washer
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
78 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
