Question about Timex Watches
I want to change to savings time on my timex indigtlo
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
Dec 13, 2017 | Timex Watches
Timex 1440 Sports Radio Time and CDT Instaructions
just change the time from the menu...unless we're missing something here
Mar 09, 2008 | Timex 1440 Prizefighter 53032 Sports...
How do u get hourly beep to turn off on digital watch
To set time, date, and options:
1) With time and date showing, press and hold SET.
2) Current time zone (1, 2, or 3) flashes. Press + or to select time zone to set, if desired.
3) Press NEXT. Hour flashes. Press + or to change hour (including AM/PM); hold button to scan values
4) Press NEXT. Minutes flash. Press + or to change minutes
5) Press NEXT. Seconds flash. Press + or to set seconds to zero.
6) Press NEXT. Month flashes. Press + or to change month.
7) Press NEXT. Day flashes. Press + or to change day.
8) Press NEXT. Year flashes. Press + or to change year.
9) Press NEXT to set options. Press + or to change value and then press NEXT to go to next option. Press DONE at any
step to exit and save settings. Available options are 12- or 24-hour time format, MM-DD or DD.MM date format, hourly
chime N, beep for button presses, customizable mode set (Select “HIDE” for unwanted modes – they are removed
from mode sequence).
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If you don't have the manual, Try this link:
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need further help, call Timex in Little Rock, Arkansas, phone 1-800-448-4639.
I hope this helps you. Thanks, Bill
Aug 31, 2010 | Timex Watches
How do i change from the time after daylight savings
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals. Rate me, please .
Apr 07, 2010 | Timex 5J261 Solar Powered Ironman...
I have a Casio WR50M Wave Captor Atomic Watch will not change to
You should be able to make it change. If you do not have instructions, you can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Apr 07, 2010 | Watches
Timex ironman triathlon - need directions to adjust time for day
Follow this link and download usars manual for your watch:
http://assets.timex.com/manuals/?timexBrand=core
Use ZOOM tool as the writings are tiny.
Do not forget to rate, please.
Mar 09, 2009 | Timex Sports Ironman Triathlon 100-Lap...
Cannot change from 24 hour to 12 hour also did not change to daylight savings time
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Mar 08, 2009 | Timex T5G341 Sports Radio Control Watch
Cannot changer from 24 hour to 12 hour
You could change between 12 and 24 hour by pressing the "Mode" button and the "Receive/Start/Stop" button at the same time. I still cannot figure out how to reset for Daylight Savings Time, though.
How do I change time on timex watch?
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Mar 16, 2007 | Timex 5B841 Wristwatch
Watches Logo
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
