Question about Linksys Wireless-G Broadband Router
Internet goes off every 10-20 minutes - unplug router and it comes back on only to go off in a few minutes; as a result, host computer and laptop set up via wireless connection continue to go off
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 100 Answers
You may have some setting incorrect in your wireless router. What I would suggest that you do is reset the router and adjust your settings correctly.
This should take no more than 10 minutes and you'll be as good as new.
Here is a Tip I wrote up on how to do exactly that.
http://www.fixya.com/support/r8641009-wireless_network_reset_setup_linksys
Magoo
Posted on Mar 13, 2011
I can not connect to the Internet. I have WiFi connection but can't do anything else
Plug your computer/laptop directly into router. Can you get to the Internet then?
If you CANNOT get to the internet when your computer is plugged into the router, reboot your router. If it doesn't have a power switch, unplug it. Leave it unplugged. Next, you need to figure out if you have another modem for DSL or Cable. If you do have another DSL or Cable modem, unplug that device to. After 5 minutes has elapsed for both devices being unpowered, plug in the DSL or Cable modem to the power source. Keep the router unplugged from power. After your DSL or Cable modem has powered up for 5 minutes, plug your router into the power source. Wait a few minutes. Reboot your computer/laptop. Try the wireless connection again.
If you CAN get to the internet when your computer is plugged into the router. Reboot your computer. Try to connect again. If you cannot connect after rebooting, make sure you are connecting to YOUR OWN wireless access point and not someone else's.
Do you have other computers/laptops/wifi devices that CAN/CANNOT connect to your wireless / access the Internet?
Jul 03, 2011 | Computers & Internet
Won't connect online
This just happened to my siste and a frind of mine recently. It can be a few things.
Are you connecting via wire from your laptop or wireless? I'm hoping they did not remove a wireless router and not explain this to you.
With a new modem your main IP address would change. First I would try turning off everything, unplug the modem and any connected switches or routers. Wait at least 10 minutes, better yet, unplug them and go to work, go shopping etc.. Then plug the modem back in, wait 2-5 minutes, plug in any routers and switches, wait 1 minute then turn the laptop back on. See if that solves the problem.
Nov 19, 2007 | X-Micro Technology (XWL11GRIX) Router
I plug my router into my modem and it just doesn't want to work with me. Everything was working fine, and then last night my connection gradually got worse until I lost the Internet. I plugged my computer...
There must be a small reset button on your router. Hold it down for 30 seconds. Release it. wait for one minute. Now unplug the power and plug it back in. Wait for 1 minute.
Once you reset the router, it will come back to factory default settings.
You will need to reconfigure the router form the start according to your Internet service provider.
Click here for step by step instructions
Sep 26, 2010 | Linksys Wireless-G WRT54G Router
Only one computer at a time can connect to the internet. Both computers are connected to wireless internet via the router.
Make sure that the modem is connected to the Internet port of the router.
If it is connected to the Internet port and still only one computer is able to go on line then you will need to reset the router and reconfigure the router.
Sep 15, 2010 | Linksys WRT160N Wireless Router
Internet intermittently going down
Before going out and buying a new router, you should try reseting this one.
There should be a small pin hole on the back of the router, stick a pin in there to set it back to factory settings.
You can also check the WAN connection to make sure it isn't loose.
Thanks,
Pat
Apr 02, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
My netgear rangemax does not emit a steady wifi signal. if i plug in my computer, the internet is working fine. all of the lights are on on the router. The wifi network shows up for a few minutes, goes...
Intermittent wireless connection can be caused by different factors, such as:
1. Wireless interference within the network. For best results, place your router:
- near the center of the area in which your computers will operate.
- in an elevated location such as a high shelf where the wirelessly connected computers have line-of-sight access (even if through walls).
- away from sources of interference, such as microwaves, and 2.4 GHz cordless phones.
- away from large metal surfaces.
2. Wireless settings on the router are still set to default. This may cause conflict with other Netgear routers within your network range.
- change the router's SSID or wireless network name.
- change the router's channel.
- enable wireless security on the router.
3. If the wireless connection is still unstable after performing the steps above, it is possible that the firmware is corrupted. Upgrade the router's firmware.
Nov 27, 2009 | NetGear RangeMax WPN824 Router
My rangemax router keeps reverting back to no signal, I unplug it from the cord that goes to my internet service for a few minutes plug it back in works for about 10 minutes then goes back to no signal...
For that you need to reset your router to factory defaults.
Then reconfigure fix this problem.
First RESET your router to defaults.
for that press RESET button for 10 seconds RESET button is in back side of router.
Then connect your router to computer with ethernet cable.
Then you can access it with following link.
http://192.168.1.1
or
http://192.168.0.1
type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Set WAN settings as your internet service provider settings.
Enable DHCP .
Click on wireless and enable wi fi.
If you want secure router then enable WEP security then add new code it is your password key for connect wi fi.
Also change channel type in wireless option 4,6 and 11 channel are best.
Try 1 by 1 then save settings and restart router.
Let me know if you need further assistance.
Thanks.
Nov 06, 2009 | NetGear RangeMax WPN824 Wireless Router...
DIR 615 router. Host computer can not find network.
I dont know your router personally but what you need to do is setup a network bridgefull explanation is given here
http://www.microsoft.com/windowsxp/using/networking/expert/crawford_02april22.mspx
Oct 27, 2009 | Computers & Internet
Linksys WRT54G - Can't reach certain websites / email
See if you can surf by ip address. Go here:
http://myip.unicorn-webdesign.de/urltoip.php
Then try to get to the site.....if so, you have a dns problem. Check the dns servers that are listed in the router. If it is set to static, change to auto obtain dns servers. You may also be able to add another dns server which may fix the issue. Try one of these:
https://www.opendns.com/start/device/linksys
Mar 14, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys Wireless-G Broadband Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
