Question about Philips Philishave HQ5812 Electric Shaver
The surround that hold the blades in place has broken
    Sergeant:
    Champion:
  • 232 Answers
Google philips comany and they should sell parts for it.Might even have a 800 number listed for parts
Posted on Mar 13, 2011
Piece of lid broke off
Sand the area on bottom of piece along with areas surrounding the broken piece. Get another small piece of plastic that is large enough to cover the broken piece and adjacent areas and apply the glue to that using a good epoxy for adhesion. Let it set up and it will hold - trust me.
Sep 27, 2016 | Cuisinart Dough Blade Plastic for DLC-2014...
Why is it making a loud clicking noise?
If it makes a loud clicking noise on startup or shutdown, it could be caused by a weakness in the springs that hold the compressor in place in the hermetically sealed shell.
If it is a constant noise while compressor is running it could be a slightly bent fan blade hitting its surroundings. Check the condenser and evaporator fans.
Aug 31, 2015 | Refrigerators
Broken screen
To begin your fix, you'll need a few simple tools and a replacement LCD screen. For tools, I recommend a screwdriver with a variety of small bits, such as a Phillips #00 and a Torx T5. It's also a good idea to have a few thin metal blades or plastic spudgers. These are really handy for removing the trim that surrounds the screen.
As for the replacement LCD, you should be able to buy one either from the laptop manufacturer's authorized parts dealer or a third-party supplier. Depending the screen, they usually cost between $50 and $250 dollars-more if it's a high-end display or you buy an OEM replacement. Regardless, you'll want to buy a new screen that matches your broken one exactly. The only sure way to do this is to remove the broken one.
After disconnecting the power supply and removing the battery, carefully examine the bezel around the screen. You'll need to remove this bezel to access the screws that hold the LCD panel in place.
On this laptop, several rubber cushions hide screws, which hold the bezel in place. I'll need to remove these cushions and the screws that are underneath.
With the hidden screws removed, I used a thin metal blade to pop loose one of the bottom corners and worked my way around the bezel with a plastic spudger.
Feb 17, 2013 | Computers & Internet
How do i replace a broken blade
Pull off the spark plug wire (safety precaution). Turn the mower on its side to expose the blade. You will have to get something to hold the blade in place while you remove the bolt ( I use a block of wood in most cases) Loosen the bolt, remove the blade and replace. Use the wood to hold the blade again while you tighten. You may be able to just sharpen the blade if it is not too far gone.
Sep 27, 2012 | Garden
Had my #10 blade sharpened and now have several probs w blade and
You may know the first part of this, but...
Ordinarily, the blades are removed and replaced as follows:
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
In your case the retaining clip may have broken off. With the blade removed, push that same gun metal colored bar in. You should see the other end of it move in unison just behind the nylon cog that moves the blades when they are installed. Check the tip of that other end to see that the "turned back on itself" rounded portion is there. That's what holds the blade on. If it is missing, you will have to replace the part (the tongue part has to be removed to do so since the retaining clip part is under it, with a small spring holding it in place). A new one can be obtained, I think, at:
http://www.clipperrepair.com/parts.htm?brand=8
You say that you had the blade sharpened. By someone who knew what he or she was doing, I hope. It is possible that whoever sharpened it, reassembled it improperly so that the area where the retaining clip connects is too far toward the rear of the blade (opposite the teeth) and the clip is unable to click over it into place. If you look at the back of the blade, you will see the small slot just about in the center where the nylon drive cog fits to move the blade back and forth when it is mounted. Just below that there is a plate with two tabs extending toward the teeth. The part of that plate (toward the teeth) that has a slight indentation is where the retaining clip clicks into place. If it is not doing so, then either the clip is broken or the blades are not assembled properly. You can try (careful blade assembly is tricky in regard to getting them straight) to loosen the two screws and very carefully move that plate enough (very little should be required) toward the teeth so that the clip will hold. I would make very sure that the clip is not broken before doing that.
Hope this is helpful to you.
Apr 11, 2010 | Oster Golden A5 2-Speed Universal Motor...
The blades seem loose and chatter. Two blade sets have gotten broken tabs. It seems as though the metal blade release isn't holding the blades down properly. If I seat a blade and then hold the release...
your blade need to be adjusted and also we need to check the hinge for spring tension, also your sockets on your blades may be worn out. e-mail askmannyssharpening@yahoo.com they can help you with this problem.
Mar 06, 2010 | Oster Golden A5 2-Speed Universal Motor...
My Panasonic ER 203 with problem spring of
If the spring on the blade has come out, the blade has to be broken. The manufacturing process for this type of blade makes it impossible to take it apart without breaking the plastic that holds the spring. There is simply no way to effectively repair the blade.
You will need to replace the blade or the entire unit.
Feb 14, 2010 | Panasonic ER 203 Beard Trimmer
Hi. I have an older fein multimaster msxe 636 II. The blades have round bolt holes. The new models have the star type holes. Can I use the star type blades since they are more available?
With respect to the above "answer", this tool has NO locking lever! It uses only a set screw to hold blades in place. It so happens that newer "star" mounting blades will fit into this tool easily, One must center the blade so the fingers of the star are outside of the raised circular surround of the hole. A washer (use a larger tapered one) and the set screw will then press the blade against the back surface of the bit holder. Tighten up this assembly, turn it on a cut away!
Dec 30, 2009 | Fein Multimaster Rs - Msxe 636 - 2 Rs
Jig saw
On the spring loaded one a metal pin will fit through a hole in the black to keep it in place. Ensure your blade is not broken and has a hole for the pin to go through.
Oct 07, 2008 | Saws
Philips Philishave HQ5812 Electric Shaver Logo
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
