Question about Nintendo DSi Matte Blue Console
How do I connect to the web? It says no compatible access point in range.
  • 84 Answers
You may not have a compatible Wifi connection near you. Your best bet is to get a wifi router that works with it.
Posted on Mar 13, 2011
HOW DO I CONNECT MY EXTENDER THROUGH WIFI
It need to be wire connected to another router, once it has an IP you can access the device with a web browser and configure wireless access pretty much with the same information as your actual wireless access point, same network ID and key.
Aug 13, 2014 | NETGEAR CONSUMER New - Netgear Wn2500rp...
Unable to browse to cisco access point
'192.168.0.116' is the wrong range for the router. The Cisco manager allocates the ranges the router will use.
See this page on the setup.
Getting Started Guide Cisco 3700 Series Access Points
May 28, 2014 | Cisco Computers & Internet
How do i get my web to work on my dsi xl nintendo
You must be connected to a wireless network. To do this:Go to the settingsThen Wireless communications (set that to on)Continue then scroll over until you see internetTap on internet then connection settingsTap on connection 1,2,or 3Search for a wireless access pointthen type in your wifi access point and password
Dec 29, 2011 | Eforcity Light Pink Soft Silicone Skin...
My nintendo dsi pink console will not connect to the internet. It says no compatible access point in range. My error code says 051311.
You need to have an accessible Wifi router in order to connect to the Internet. The message means that there isn't one.
May 08, 2011 | Nintendo Dsi Pink Console
I can't get the liberty card on pokemon black version because I have a no compatible access point in range what does that meen please help.
If it tells you there is no compatible access point in range, then you are not near an access point. The liberty card must require you to be connected to the internet, and if you have no wireless internet in your residence, then it will not work. An easy fix is to head to a common fast food restaurant, most nowadays offer free Wi-Fi.
Mar 08, 2011 | Nintendo DS Console
How to get on the web on nintendo dsi?
you go to your system settings which is the wrench-like icon on the main screen. you then find the internet option and tap it. select connection settings and pick connections 1, 2 or 3. After that, tap search for an access point. then select an access point that is either unlocked, or you know the code to a locked one. if its unlocked, select it, save it, and do the connection test. if the test is successful, you will then be able to use the web icon or anything else. If the access point is locked, enter the code or if it tells you to use advanced setup, go all the way back to the first internet option, pick connection settings, then select advanced setup. pick a connection, search for an access point, enter the code, and save it. then do a connection test. if successful, you can access internet, dsi shop, or any other wi-fi compatible game/app.
May 22, 2010 | Nintendo DSi Black Console
Im using Motorolla canopy 5.4 and 5.7, both ,they are confiruged whith ip addresss in the range of class A, my problem is that in lot of them i cannot access thru web page, what should be wrong on this...
I would advise you to be sure that your routers are MDI/MDIX Compatible, (i.e it can allow you to use either a straight-through or cross-over cable).
If not, then try using a cross-over cable when connecting the routers together.
Also, try making your router's LAN configuration to be DHCP and the one for your Wireless Access Point Static.
Then make sure that they are all in the same Subnet. This is also very important.
Try out these few troubleshooting steps first and keep me posted about the problem.
Hope it helps.
Goodluck
Nov 14, 2009 | Motorola Canopy 5.2 GHz Wireless Access...
Sitecom WL-330 range extender with dlink dir-615- unable to use
I am guessing you have XP or vista. here are the instructions for both.
XP 1. Click ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Double-click Network and Dial-up Connections icon, double click Local Area Connection, and Local Area Connection Properties window will appear. Select ‘Internet Protocol (TCP/IP)’, then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Vista 1. Click the ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Click View Network Status and Tasks, then click Manage Network Connections. Right-click Local Area Network, then select ‘Properties’. The Local Area Connection Properties window will appear, select ‘Internet Protocol Version 4 (TCP / IPv4)’, and then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
Next step for both All functions and settings of this access point must be configured via the web management interface. Please start your web browser, and input ‘192.168.0.234’ in the address bar, and press the ‘Enter’ key. The following dialog should be shown: Please input user name and password in the field respectively. The default user name is ‘admin’, and the default password is ‘admin’. Press the ‘OK’ button to see the web management interface of this access point: NOTE: If you can’t see the web management interface, and you’re being prompted to input user name and password again, it means you didn’t input username and password correctly. Please retype user name and password again. After you connected to the access point by web browser, the first thing you see is ‘Status and Information’ page. All system and network related information of this access point will be displayed here. The information is very helpful when you want to know the detailed information of your access point, and when you try to fix the communication problem between this access point and other wired / wireless computer / devices. You can click ‘Home’ on the left, This access point can be operated in different modes; you can click ‘Basic Setting’ to select an operating mode you want to meet for different needs: You can click ‘Mode’ dropdown menu to select operating mode, and there are 3 operating modes available: AP Access point mode, allows wireless clients to connect to access point and exchange data with the devices connected to the wired network. Station- Infrastructure Enable the Ethernet device such us TV and Game player connected to the access point to a wireless client. Universal Repeater This product can act as a wireless range extender that will help you to extend the networking wirelessly. The access point can act as Station and AP at the same time. It can use Station function to connect to a Root AP and use AP function to service all wireless clients within its coverage. You can hopefully figure it out from there.
Sep 13, 2009 | D-Link DIR-615 Wireless Router
Tew-630apb
hello!
-- what is the exact model number of your access point and router?
-- what is the ip address of your access point and router?
-- what is the operating system of your computer?
-- Is your computer directly connected to the router?
-- Do you have a wireless computer? what is the model number of the wireless adapter
if you want to configure your access point with your router you may try the ff:
Step 1: Connect the Ethernet port of the access point to one of the Ethernet ports of the router
Step 2: Make sure the power adapter is plugged to an available power outlet
Step 3: Check if the corresponding LEDs on the access point are lit
Step 4: After connecting the devices together, configure the access point’s wireless settings
Step 5: Open the access point’s web-based setup page
Step 6: When the access point’s web-based setup page opens, change the SSID, Channel, and Wireless Security.
Apr 07, 2008 | Trendware TEW-630APB (TEW630APB)
Nintendo DSi Matte Blue Console Logo
19 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
