Question about Panasonic PJMCB0097Y Inverter Shield Plate
If airconditioning not pangtioning or not operate the system
    Problem Solver:
  • 30 Answers
Http://www.scannerparts.biz/servlet/the-ALL/oem/Panasonic/searchpath/7570/start/3101/total/3836/Categories
Posted on Mar 13, 2011
My over the stove microwave starts continues for a few econds the f-7 appears and it stops
F7 means power to magnetron is interrupted.
I don't recommend that someone without experience and an understanding of the safety procedures undertake troubleshooting this.
You can find manuals and helpful exploded view diagrams for your model here and my favorite parts supplier is here. There is a technical sheet hidden behind the controls that has helpful technical and troubleshooting information. It will say something like this:
F7 Power to magnetron interrupted
1. Unplug microwave oven or disconnect power.
2. After 40 seconds, check to see whether this solves the problem.
3. Unplug microwave oven or disconnect power.
4. Check cooling fan operation
5. Check the magnetron.
6. Check P65 connection on the relay control board.
7. Check the P56/P66 connection between relay board and relay control board.
8. Check wiring to the 1200W inverter and control system. See "Checking Inverters."
9. Check operation of all interlock switches.
10. Replace all parts and panels before operating.
11. Plug in microwave oven or reconnect power.
12. Check voltage at 4903-1 on relay board. If it is 120, unplug microwave oven or disconnect power.
13. Replace inverter.
14. Replace all parts and panels before operating.
15. Plug in microwave oven or reconnect power.
16. If problem persists, unplug microwave oven or disconnect power.
17. Replace relay control board.
18. Replace all parts and panels before operating.
19. Plug in microwave oven or reconnect power.
20. If problem persists, unplug microwave oven or disconnect power.
21. Check for reversed plug connection on controls or loose wiring.
22. Replace all parts and panels before operating.
23. Plug in microwave oven or reconnect power.
William E. Miller, AS-EET
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Oct 05, 2016 | Kenmore Microwave Ovens
When operating microwave the displays reads "F9". what does this mean?
F9 is a failure of the door latch system, more likely the switch that tells the system it's closed. Replacement switches are inexpensive, see: http://www.electronix.com/microwave-repair-switchescouplers-c-557_564.html
Jul 27, 2011 | LG Over-the-Range Microwave
Error code SE on Maytag Microwave
The error code SE stands for " Systems Error " which indicates there is a short in the keypad membrane causing the system to lock up. The only option is to have the keypad replaced for normal operation.
Mar 27, 2011 | Maytag Appliances Over-the-Range Microwave...
Unable to press buttons and message appears --SE--
The word --SE-- means systems error, caused by a short in the keypad membrane. The solution is replace the keypad to resume normal operation.
Mar 20, 2011 | Maytag MMV4205 Microwave Oven
No power to unit. Internal fuse ok. Power ok to plug
It sounds like you have a short in the keypad controller system, there is a microprocessor board mounted behind the the keypad that control vital areas of the microwave's operation. I suggest appliance technician to check out the systems hardware and the rest of the oven.
Jan 31, 2011 | Kenmore 80603 Stainless Steel 1100 Watts...
Ge spacemaker microwave xl1400 works but does not heat
Pledase check the operation of the door safety interlock system. If you routinely open the door while the oven is operating, these small switches will eventually burn out and not work.
Oct 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The power just quit in the middle of operation. I checked the the socket and it has power.
You will need to pull the back panel off and check the main fuse in the system to make sure that the fuse did not pop. Also if the side of the unit or top got hot during operation that is a sign of a more serious problem and it would be better to just get a new system. Repairing these can be very expensive if it is not a simple issue. Also while you are inspecting the fuse, check to make sure all the wires are tight, and there are no bare wire showing.
Jan 02, 2010 | GE Microwave Ovens
It doesn't heat the food
OK i would advise to check the fan operations. make sure that the blower assembly(fan) is operating correctly. poor circulation can cause this as well as a faulty thermostat. If the fan is not operating, this will damage the entire system. replace the fan if it isn't working. check the filter as well.
Jun 03, 2009 | Microwave Ovens
Microwave F-7 Code
F7 is q Power to magnetron
interrupted
5. Check resistance of the magnetron thermostat.
6. Check the magnetron.
7. Check P2, P4 and P27 connections.
8. Check wiring to the 1100W inverters and control system. See
“Checking Inverters.”
10. Replace inverter, if defective.
11. Replace all parts and panels before operating.
12. Plug in microwave oven or reconnect power.
13. If problem persists, unplug microwave oven or disconnect power.
14. Replace electronic control.
15. Replace all parts and panels before operating.
16. Plug in microwave oven or reconnect power.
17. If problem persists, unplug microwave oven or disconnect power.
18. Check for reversed plug connection on controls or loose wiring.
19. Replace all parts and panels before operating.
20. Plug in microwave oven or reconnect power.
Aug 08, 2008 | Whirlpool GH6177XP Microwave Oven
Microwave oven inoperative
check high voltage section, check magneatron, diodes, etc.
Nov 02, 2007 | Sharp R-1480 Microwave Oven
Panasonic PJMCB0097Y Inverter Shield Plate Logo
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
