Question about Ricoh Office Equipment & Supplies
Richo ft4018 copier copies all black - Ricoh Office Equipment & Supplies
  • capscrew Aug 10, 2008
    yep lamp is ok
  • 30 Answers
Does the lamp appear to be working take a copy with the lid up!
Posted on Aug 01, 2008
Richo aficio 2045 out of focuse problum
could be developer powder is bad i would start there
Aug 13, 2014 | Ricoh Aficio 2045e 2035e Copier...
How can i solve error code sc:901 in richo africo 2000 copier
The mechanical counter is either unplugged or is defective.
Oct 30, 2013 | Ricoh Aficio MP 2000 Black and White...
I have a Richo 2035 black and white copier. Recently the copier has begun to paper jam...and its done frequent every time i clear the jam..it runs for a while maybe 10 copies and jams again. What can i do?
Not surprising - it may need some service. It is 7-8 years old. There are a few areas that could be affecting output. Most likely you need to replace the rollers that pick the paper out of the tray (3/drawer) -especially if the problem occurs with 1 specific tray. Try using another tray to isolate the problem
Jul 10, 2011 | Office Equipment & Supplies
Witch is better Gestetner DSm745 or richo 1045 or richo 2045 any one help me pleas
dsm 745 has more modification than1045 more comfortable less disputes little problem. technicians can see this difference there are more details but i expressed that dsm 745 is recently than 1045 good luck
Jun 27, 2011 | Gestetner DSm745 Black and White Copier
My aficio richo 2016 black and white copier is showing code error sc 544. pls how do i fix this problem.
This error code is related to a overheat in the Fuser Unit.
Probably you have a faulty thermistor.
I advise you ito call a technician. But you can do this procedure to see if you can work while technician does not arrive.
Press yellow key.
Press 107 on the key pad.
Press red key at least 5 sec.
Press copy SP.
Exit all the way out and turn the machine OFF and ON.
I think did may help you.
See you!
May 11, 2011 | Ricoh Aficio 2016 Black and White Copier
My richo ft4822 copier is now printing blank copies. Before this, image density was faint even if you set to maximum density.
Clean the optics and change the transfer/separartor corona wire.Verify the drum ground plate connection.
Nov 11, 2009 | Ricoh Office Equipment & Supplies
FT4018 RICHO PC MACHINE BREAK DOWN.
CODE #29 — LENS HOME POSITION ERROR 2
- Definition -
The lens home position sensor’s output remains HIGH (actuated) for 10
seconds after the unit leaves the home position.
- Possible Causes -
· Defective lens home position sensor
· Defective lens drive motor
· Defective main control board
· Defective lens drive mechanism
May 25, 2009 | Ricoh Office Equipment & Supplies
Drum on the copier (Richo 220) is covered in toner?
Yes, replace the photoconductor (drum) unit . You can contact Ricoh directly, or a dealer.
Mar 20, 2009 | Ricoh Office Equipment & Supplies
I have in the Ricoh copy printer
I just looked back at my analog manual. I think you have a different machine than you listed - maybe an FT3713, FT4018, or similiar.
You have a scanner problem:
Possible Causes -
· Scanner home position sensor failure
· Defective scanner motor
· Defective main board
· Defective dc power supply board
· Incorrect scanner drive wire position
· FU202 on the dc power supply board open (blown fuse).
Mar 18, 2009 | Ricoh Aficio 450 Copier
Toner lines when I print
I don't think it is anything to do with the toner cartridge as this doesn't put the toner on the page seems to me that the drum unit is faulty either the cleaning blade has failed or the charge roller. Best thing to do is call a service engineer or copier company that deal with Richo or Rex Rotary.
Thanks J
Nov 18, 2007 | Ricoh Aficio 180 Laser Printer
47 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
