Question about Samsung DualView TL210 Digital Camera
Samsung TL210 When trying to delete a image in camera recieve a "file error" message and unable to delete.
  • 93 Answers
Check your memory card for the lock. If it's not locked and you steel having the issue then try backup all you pictures and format the memory card using format utility in setup menu.
Posted on Mar 13, 2011
Transfer pictures from my samsung TL210 camera to my computer
The best way to transfer pictures and videos from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy files from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Nov 24, 2012 | Samsung DualView TL210 Digital Camera
Tip
How To Fix You Camera's "Card Error" or "Card Not Initialized" Message
When you recieve a "Card Error" or "Card Not Initialized" message, this indicates that your memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most consumers will use the "delete all" feature and continue to take pictures. By doing this, the file format of the card may become unstable.<br /><br />We recommend formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted, the images will not be recoverable.<br /> <br /> If this doesn't fix the Card Error, try replacing your batteries with a new, fresh pair of batteries. Also, if you haven't tried already, replace the memory card with a known working card and see if this fixes your error.
on Feb 14, 2011 | Cameras
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Casio Camera Exilim EX-Z29: After transfering pics to my laptop (Mac) I am unable to erase them from the laptop (get an error message that is unable to do) and from the camera I get a "card is...
You didn't actually transfer the pix, you created shortcuts to them. You'll have to have the camera attached to the Mac to delete the shortcuts. Then, move the files from the camera to the computer. That will clear the card, and insure you've actually got the files on the computer, not just shortcuts.
Jul 06, 2011 | Casio Exilim EX-Z29 Digital Camera
I have a video image I am trying to review and when I scroll to it, I get an error message that reads, "This motion image cannot be played". When I try to delete it, I get an error message that...
I think the easiest thing to do is to put the memory card into a card reader on your computer, copy everything off of it that you want to keep (excluding the problem files) and then try to delete the problem files using your computer. If this does not work, I would reformat the memory card, as these file seem to be corrupted. I would also suggest getting a new memory card, because they do go bad, and could corrupt pictures and videos that are important to you.
Mar 14, 2011 | Panasonic Lumix DMC-FH22 / DMC-FS33...
I have not been able to scan any of my documents from my SamsungSCX-3201 All-in-one machine. The error message reads "The Current Image Transformation failed. Probably the problem could be caused by...
i had the same issue. Just uninstall the software, also remove from programfiles( check if there are any files left by typing samsung in run and delete everything). Then install the new software from samsung website. and the problem would be solved. Let me know if you still have an issue!
Feb 05, 2011 | Office Equipment & Supplies
When I try to delete a corrupted save file on my Play Station 3 this message comes up "80010036 An error occured during the delete operation error." and I am unable to delete the file.
There was a problem when it first came out (not reading the hardrive correctly). Download a small demo or trailor and then delete all, this should work
If however it does not, then you will have to re-format the hardrive.
It sucks to be sony!
Jul 17, 2008 | Video Game Consoles & Games
Samsung DualView TL210 Digital Camera Logo
149 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
