Thewater doe,nt seem to heat up - Washing Machines
  • 46 Answers
If you have hot water in other facuets check to be sure that the hot water faucet serving the washer is turned on.
Posted on Mar 13, 2011
2000 MONTE CARLO BLINKERS DO NT WORK,AC/AND HEAT DO NT WORK,AND RADIO IS SAYING LOCKED UP
Does the vehicle start?
If not, then check battery voltage. If below 12.5 volts, then recharge the battery and retest system charging voltage (should be around 14 volts)
If battery is fine and vehicle starts, then check fuse box and wiring loom connectors.
Nov 13, 2012 | Chevrolet Cars & Trucks
My riccar does'nt sew
could you explain more of the problem
Mar 13, 2012 | Sewing Machines
Have hotpoint single oven ,oven does,nt seem to get up to temp ie had it on full power 250 and placed a oven thermometer in and it only reached 150 any idea.nige
either the thermostat is faulty or the heating element is playing up ,check the wires as well in case you have a burnt/corroded terminal on the heater unit which is holding the amperage back
Nov 28, 2011 | Hotpoint Ovens
My minimax nt only heats till 90 degrees. I set it up to 104 which is the highest and it only stays at 90 degrees. Everythig seems to be working well, no errors either. Please advice.
Either the thermostat board is defective, the temperature sensor is defective or not enough heat is being produced by the heater. . I recommend you call the Pentair technicalsupport at 800-693-0971 and they should be able to help you figure this issueout. I hope this helps.
Please vote on this answer. Thank you.
Aug 25, 2011 | Pentair Minimax NT Heater
Roper dryer runs but has no heat
my roper dryer does not heat up i checked thermostat, thremo fuse and heating element they show working could it be my timer when dryer is running timer does nt advance it stays in the same position.
Jan 11, 2010 | Dryers
89 saturn fan does,nt kick on
cooling fan or heater fan? if its cooling fan then the coolant temp sensor is bad
Jan 06, 2010 | 1999 Saturn SL
PC overheating
most over heating issue solutions are...put your computer in ventilated area, add more ventilation and exhaust (fans)...replace CPU heat sink and fans..yes upgrade the RAM
Mar 16, 2009 | ASUS P4GE-MX Motherboard
Dishwasher runs for a long time
If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Yourdishwasher may pre-heat the water. If so, and if the water entering thedishwasher is cool, the heater may take up to half an hour to heat thewater.
To avoid the wait, increase the incoming watertemperature before turning on the dishwasher. Do that by running thekitchen sink faucet until the water runs hot. Or increase thetemperature of the hot water to the entire house at the hot waterheater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Nov 12, 2008 | Kenmore 24 in. 17362 / 17364 / 17369...
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
