Somewater stays in washing machine after wash
    Scholar:
  • 111 Answers
It's not pumping out fast enough to get it all out in the alloted time. Check the sewer line. Run a garden hose into it to see if it takes all the water you can throw at it. If that is okay, then have a look at the washer's drain pump, belt and hoses. Sometimes a bobby pin, small nail, or toothpick gets into the pump and stops it turning. Or soap scum and lint builds up. Or a hose gets kinked. Good luck.
Posted on Aug 02, 2008
  • 30 Answers
If some water stays in your washing machine after wash, this indicates you may have some form of blockage in the lower outlet of your washing machine. This blockage maybe cause by a sock, under-wares, head band etc.
Solution, remove the inlet hose from the water pump ,and allow all remaining water to run out, then observe the material that should come out along with the water. Other factors can be caused by a Kinked drain hose, faulty agitate or spin solenoid, a faulty drive belt, or a faulty water pump.
Posted on Aug 06, 2008
Washing machine stays on wash cycle
Insert a piece of wire into hole in filter door, and push in gently. While pushing, turn the cover clockwise, it will came off.
Click if helped.
Mar 18, 2013 | Bosch Washing Machines
The machine wash but the spin not working. so the cloth stay wet
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 10, 2011 | Magic Chef CAV2000AWW Top Load Washer
How to operate samsung wa82v4g washing machine. Water does not stay in washer at all.
The hoses are not hooked up right ...
Here is a tip that tells you how to fix that problem...
Water will not stay in Washing Machine
heatman101
Sep 25, 2010 | Washing Machines
Maytag washer wont fill just drains out
Here is a tip that I wrote about why water will not stay in the washing machine...
http://www.fixya.com/support/r4696322-water_will_not_stay_in_washing_machine
heatman101
Aug 22, 2010 | Maytag MAV3905EWW 13 Cycle Washer
Will stay blanced
you may be overloading you machine.
if not replace the old leg with new one.
just unscrew the old ones out and screw the new ones in.
May 02, 2009 | Washing Machines
My washing machine is tripping the circuit breaker
sorry to hear about the problem it will be your motor or module try online for recon both these parts are prone to go on bekos
Jun 14, 2008 | Washing Machines
Lid lock stays on and constant beep on excellence washing machine
i have the problem when i turn power on 2 green wash cycle lights plus the red lid lock stay on with constant beeping every second then when i push the start button the 2 green lights go out and the red lid lock light stays on but no beeps please help
May 26, 2008 | Fisher and Paykel IWL12 Top Load Washer
Washing Machines Logo
853 people viewed this question
Top Washing Machines Experts
