Question about Olympus OM-4TI 35mm SLR Camera
Film was in camera, frame 18. Batteries had failed at frame 17, had to depress "B Lock" button" and set shutter to 60 to release shutter. Replaced batteries with fresh batteries, battery test gave steady tone, light on front on, meter working. Film advanced from 17 to 18 after fresh batteries. Shot frame 18, shutter worked. Film advance lever would not advance to frame 19, shutter button not working. Rewound film and removed film. Tried depressing "B Lock" button" and set shutter to 60 to release shutter, nothing happened. Meter working, clear view through viewfinder.
  • Olympus Master
  • 5,412 Answers
This camera is somewhere between fifteen and thirty years old. It is highly unlikely that spares would be available, and it would be extremely expensive to have it repaired in any case, most artificers familiar with the internal layout having probably retired years ago. Maybe the camera should be retired too ?
Posted on Apr 17, 2017
5 Suggested Answers
  • 362 Answers
SOURCE: Shutter is stuck halfway
Don't fool with it yourself. You could make the problem worse and more expensive to repair. Get an estimate, then go on e-bay. This camera body is not expensive as it was when it was new. If the camera repair man wants more then the cost for a used body, save your body for parts.
Posted on Nov 28, 2008
  • 302 Answers
SOURCE: can't see through viewfinder (it's all black) and
Remove the lens and look inside it. Do you see the mirror? If not, your mirror is stuck in the up position. Its flat up against the focusing screen. If the mirror is down, the problem is in the lens, or you still have the lens cap in place.
Check your manual under troubleshooting.
Try setting the shutter speed dial to the M90 position.
Also be sure the batteries are inserted correctly!!!!
If no change yet, you can try to put the mirror back down yourself. With the lens removed, set the camera on its back. You can use your fingers, but I suggest a toothpick cuz they won't leave fingerprints on the mirror and the toothpick should break before you exert enough pressure to really break something. So just try to return the mirror to the 45 degree angle within the mirror box. Be careful not to damage anything in there, like the shutter or the arms that raise and lower the mirror. Depending on where you live, there may be some corrosion or rust on the mirror linkage. It should move easily. If you feel any roughness when you move the miror, that may be the reason it did not return on its own. Then turn it on, off again. At some point, you may want to have this camera cleaned, lubricated and Adjusted(CLA) - after all, its over 25 yrs old.
If all that did not work, you'll need to send it in. Here are some good choices for repair places...
Garry Airapetov in Niles, ILL
Camera Repairs in Avon, IN.
BTW here's a website with several pages about FG...http://www.mir.com.my/rb/photography/hardwares/classics/emfgfg20/fg/index.htm
copy and paste it into your browser.
Posted on Oct 11, 2009
ftw1952
  • 10319 Answers
SOURCE: nikon fm10 cannot get shuuter release button to
The film lever is also a switch. If you had advanced the film lever, **** it outward a little. You will feel the detent click somewhat when doing so. Leave the lever outward and see if the shutter will work. The detent is for appling an closed circuit for the light meter. When the lever is fully pushed back in it shuts the power to the meter on off to conserve battery power
Posted on Jan 01, 2010
  • 3289 Answers
SOURCE: om-4ti film advance lever will not advance.
I don't know if this is you first film camera or if you've owned one for years - so pardon some beginner suggestion.
If there's film in the camera, you may have reached the end of the roll. What you're describing sounds very much like this is the case. There is a window to indicate of how many exposures have been taken next to the film advance lever. Most 35mm film manufacturers offer 12, 24 and 36 exposure rolls. Check to see the number shown in the window. If at the end of the roll, you may have advanced the film so far that the number is half in the display and half blocked.
If there is film in the camera and since it will no longer allow any more exposures, you'll need to remove the film. Locate and press the R button next to the film advance lever. Unfold the crank handle from the knob on the top of the left side of the camera (as viewed from behind - in picture taking position). Twist the crank in a clockwise direction (viewed from above) to rewind the film into the film canister. As you get closer to the end of the film, more resistance will be felt until finally, the handle spins freely. This indicates that all the film has been safely rewound and stored in the canister. Next, lift the knob that the crank attached to up and away from the camera body. The back door of the camera should pop open. You can now remove the film from the camera and have prints made from it.
You can get a copy of the manual for your camera here. There is no charge to download it - but a donation is accepted by the person that is making it available.
I hope this helps and good luck! Please rate my reply - thank you.
Posted on Mar 13, 2011
When I insert the film, it won't catch, therefore I keep winding until the roll is done (also, the shutter release button won't depress). What does this mean? Is there a way to fix it?
When you say 'vintage', are we talking 35mm or roll film ? If 35mm, looks as if the interlock between shutter release and wind-on spool needs adjusting, but no idea if this is possible.
Aug 31, 2015 | Kodak Vintage Automatic 35 1959-64with...
Nikon FM10 will only release shutter with cable
Hello Blair,
I too like old school camera, mine are the N2000, N6006, N80, and F100. First without film in the camera I would attempt to release the shutter. If it does then there is something going on with the film transfer causing a bind.
However, If it continues not to release the shutter I would put the FM10 on the shelf then go to KEH.com for another. Just now checked KEH.com, 2014-05-26, a FM10 in EX condition is $89, EX+ condition $99. That would be a much better move than repairing yours and less expensive.
Cordially
May 25, 2014 | Nikon FM10 35mm SLR Camera
I just bought a nice used Mamiya twin lens C3 but the shutter is locked up. There is a small metal piece holding the shutter release from moving. Not sure how to un-lock, seams to be a safety device of...
The vertical shutter sliding lever gets locked if the film doesn't get advanced to the next frame, and the mode selector is set for single exposure. You can't trip the shutter unless you have film in the camera and you forward the film to the next frame. That should allow you to release the shutter with the sliding lever.
Mar 17, 2014 | Mamiya Cameras
Will a nikon n2000 turn on without a lens and film?
The camera should operate perfectly fine without a lens. It should also operate perfectly fine without film (other than for not taking any pictures, of course).
I know this is stupid, but make sure the batteries are inserted in the proper direction. Then make sure the film advance mode selector around the shutter release button is not in the "L" position. L is for Lock, S is for single-frame, and C is for continuous.
If you need a manual you may download a copy here.
Apr 27, 2012 | Nikon N2000 35mm SLR Camera
Shutter release button on my F3 is stuck (locked) and shutter speed is locked at 1/60. Works fine when camera is attached to a motor drive, but not otherwise.
When the batteries in an F3 die, though the film can still be advanced, the photographer is limited to a single mechanical shutter speed of approximately 1/60 second. It is tripped by a secondary fully mechanical shutter release. Works fine when camera is attached to a motor drive because it uses the drivers power...Pls replace the batteries as one of the following is okay.....
  • Battery: Choice of one 3V lithium battery CR-1/3N type,,
  • two 1.55V silver-oxide batteries SR-44 type, or
  • two 1.5V alkaline batteries LR-44 type
Hope this helps!
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Thanks
Jun 23, 2011 | Nikon F3 35mm Film Camera
I purchased a Nikon N60 used. The film will not automatcally load therefore not shoot
Please follow these instructions: 1. Open the camera back 2. Pull the film leader across the red film index mark (red line) 3. Check to ensure film is properly positioned with no slack, then close camera back 4. Fully depress shutter release button to advance to frame 1. Check the rewind lever if it turns counter clockwise when you depress the shutter release button.
Keep on trying this procedure until you get it right. Most of the time, the error is in not pulling the film leader enough to reach the red film index mark.
If you're still having a problem with this, the next best option is to have the camera checked by a competent camera technician.
Mar 25, 2011 | Nikon N60 35mm SLR Camera
Cannot/****/the/shutter/when/camera/is/using/the battery(which/has/been/tested) Nothing/appears/in/the/led/box/excpt the/occasional/"30M)nd/that/only when/I/hold/the/shutter/release/button Took/b
Sorry but I will ask a dump question , what about the polarity of the battery ?
was it correctly fitted ? sorry but I had this case twice,that's why I asked......
When the batteries in an F3 die, though the film can still be advanced, the photographer is limited to a single mechanical shutter speed of approximately 1/60 second. It is tripped by a secondary fully mechanical shutter release. Works fine when camera is attached to a motor drive because it uses the drivers power. the batteries as one of the following is okay.....
Hope this helps!
Thanks
Jan 09, 2011 | Nikon F3 35mm Film Camera
Just recieived a used Nikon N80 and it gives the message of open door.Frame counter and film indicator flashes when door is shut and no film is in in camera?
Confirm tht DX shows in LCD. If not then press and hold shift button then press ISO so "DX" appears.Open Camera Back. Insert film cartridge, pull film leader out to right and align with red index mark (inside film chamber on right). Make sure there is no slack in leader.Close camera back until lock release snaps closed. Fully depress shutter until film advances to first frame.
Confirm " 1" and film transport show in LCD. If Film is not loaded correctly, "ERR" show on LCD. Open cack and reload film.
Users manual can be downloaded from:
http://www.lensinc.net/manuals/Nikon_N6006L.pdf
Nov 03, 2010 | Nikon N80 35mm SLR Camera
Loading the N8008 camera
1. Set the film speed manually or DX to do it automatically by holding down the ISO button and turning the command dial.
2. Slide the camera back lock releases toward each other to open the back.
3. Insert the film cartridge on the left.
4. Pull film leader over to the red index mark on the right.
5. Close the back, making sure there's no slack in the film, and the lock releases snapped close.
6. Lightly press the shutter button. The film icon will appear in the LCD panel.
7. Fully depress the shutter button to automatically advance film to frame 1.
You can download a manual from http://www.butkus.org/chinon/nikon.htm
Mar 23, 2009 | Nikon N8008 AF 35mm SLR Camera
Film advance lever wont move. Shutter button does not register.
the self timer may be the issue. the self timer if not all the way released will not allow you to advance to the next frame :( i sometimes have to push it back to the start position
Nov 13, 2008 | Photography
Olympus OM-4TI 35mm SLR Camera Logo
209 people viewed this question
Top Olympus Photography Experts
pontelemon
pontelemon
Steve
David Payne
David Payne
Are you an Olympus Photography Expert? Answer questions, earn points and help others
