Question about Logitech Webcam
How i can change setting for my camera, if i don't see on the desktop its menu?
When i take pictures pink lines appear on my monitor and my subject is not clear and sometimes cannot be seen at all. what is the problem? Is it on my lens or on the settings?. help me please...
I think you are photographing in life view. I can't reproduce the error on my D7000. I don' think is has to do with the settings nor with the lens. If you think it has something to do with the settings, try to put the camera back to factory settings, by pressing both buttons marked with the green dots for 2 seconds. One button is on top, the +/- button and one is the Qual button. Be aware that you lose all settings. There are two other possibilities to reset settings, that are less changing, look it up in the manual. One is in the menu recording options and one in the menu personal settings. Both the top lines in the menu's
Oct 18, 2013 | Nikon D7000 Digital Camera
I want to add Turkish language in my camera sony dsc h70. is it possible?
It can do this. That is just a selection on the setup menu. If you don;t have the manual or want it in a different language this link should get you to the download section for it.
http://www.sony.lv/product/dsc-h-series/dsc-h70#pageType=manual
To change the language this is all you need to do Is open the MENU then MAIN SETTINGS then select LANGUAGE SETTINGS and finally your language and that will do it. You may also want to change the location under the time selection in the menu.
Sep 24, 2011 | Sony Cyber-Shot DSC-H70 Digital Camera
How do I change the date on my camera?
Hello! Welcome to FixYa!
You can change the date of your
Samsung Digimax A503 Digital Camera. first of all turn your camera on. Now go to the menu by pressing "MENU" button. Now using right arrow key, Go to "Setup Menu". Now using down arrow key, select "Date". Here you can change the date that will be displayed on the captured images and set up the date type.
Here "Right arrow button" select the Year/Month/Day date type and "Left arrow button" is to move cursor to the Date Menu if the cursor is at the first item of the date and time setup.In all other cases cursor will be shifted to left of its current position and "Up and Down button" is to change the settings values. So you can change the date the according to desired format.
For clear picture the image of the menu where date menu is visible on the camera is given below
Don't hesitate to let me know if you want any further assistance.
I hope this solution helps you
Thank you and Keep using FixYa!
Sep 13, 2011 | Samsung Digimax A503 Digital Camera
Display mode will not go off
Does your camera have a viewfinder? If it does press the display button or change the display settings in your camera's menu. Also, many of the recent camera's that don;t have an optical viewfinder don't give you the option to turn off the display.
Hiram
Photo Tech Repair Service
110 East 13th Street
New York, NY 10001
212-673-8400
Jul 01, 2011 | Samsung Cameras
How do you transfer photos on a kodak m863 from internal memory to an sd card?
Insert a SD memory card. Set the camera's image storage location to "internal memory". Press the Review button, then press the Menu button. Use up/down to highlight "Copy" then press OK. Select an option and press OK.
To set the camera's image storage location, press the Menu button then use up/down to select "Image Storage." Don't forget to change it back when done.
Hope this helps.
Apr 28, 2011 | Cameras
How do I get the date to show and stay on the pictures I take.
You need to set the date using Set Up menu and you must remember to reset it after you change the batteries. Have you done that but still don't get dates on pictures?
Mar 05, 2011 | Fuji FinePix A205 Digital Camera
How do I turn on my laptop webcam?
There should be shortcut of Compaq web camera on your desktop. If no found on your desktop, just seeks manually on your laptop. By webcam menu you can take pictures and videos, even you can set/change the settings and effects of camera. Regards
Dec 25, 2010 | HP Compaq nc6220 Notebook
Wrong batteries settings prevents access to menu
Charge fully the batteries you have, to prevents the camera distinguish the type of batteries (maybe the camera senses the charge), turn on the camera and you will have access to the menu to set up the batteries type correctly, that´s all.
May 05, 2009 | Nikon COOLPIX L18 Digital Camera
Logitech Webcam Logo
19 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
