I have oasis and when come to the water the regalator make free flow . the regulator bring to service dealer and ajust . the free flow is eliminated but if come more hard breathing . I return to the service center to adjust more soft breathing but it come free flow again.
Water pressure from city side should be. (Minimum 20 psi ) Maximum (80 psi ) If sump tray is filling up and water valve is cutting off then water supply is ok. If you are not getting enough water over the evaporator plate then you need to make sure the distribution tube is not stopped up with. if it is clear then replace the water pump.
Hi este3banjpere Check your gas regulator, it could be faulty ************************************************* Gas regulators are notorious for doing just what yours is doing. After sitting in the same position for a length of time they freeze in that position, then along comes a grain of sand, or other debris and blocks the gas flow. Remove the regulator if possible, if not try it in place with the tank removed. Get a plastic headed hammer and gently but firmly tap on the regulator, your trying to free up the diaghram inside. After tapping and freeing the regulator diaphram reinstall and you will be good to go. If this does not work, the replace the regulator as it is defective. Some regulators are ajustable, if you have one of those then try to adjust the regulator, you will see a cap on top of the regulator, that is where the adjustment screw is located. Please take time to rate me Bud
Regulators are notorious for doing just what yours is doing. After sitting in the same position for a length of time they freeze in that position, then along comes a grain of sand, or other debris and blocks the gas flow. Remove the regulator if possible, if not try it in place with the tank removed. Get a plastic headed hammer and gently but firmly tap on the regulator, your trying to free up the diaghram inside. After tapping and freeing the regulator diaphram reinstall and you will be good to go. If this does not work, the replace the regulator as it is defective. Some regulators are ajustable, if you have one of those then try to adjust the regulator, you will see a cap on top of the regulator, that is where the adjustment screw is located. Please take time to rate me Bud
Your regulator requires servicing as this problem could be caused by either excessive pressure in the LP line to your Reg or the valve in the reg has become defective.
A well tuned reg will easily freeflow. Try holding the mouthpiece downward and SLOWLY rotating to fill the 2nd stage with water. If that does not stop the freeflow and/or if the 2nd bubbles even with the mouthpiece held downward, the you need to get the reg serviced.
use a prybar and use a piese of duct tape to keep it closed or take it to the dealer they will be more gental and paitent dealer will charge 50 to ajust it properly
Tankless Water heater tempature is regulated by the rate(amount) of water flowing through the device. To get warmer water for the hot side, slow down the elbo stop leading into the device. Since it is a shower,and you did not say one handle or two.You will have to slow the rate for the cold as well , if one, unless it is an ajustable valve.
The drawbacks to the tankless heaters.
Try going to your local auto parts store and have them check the computer. Doing so should tell you why your vehicle is not running right. Also it might be a bad Mass Air Flow Sensor that the dealer put on your car.
Check your hot and cold water supply hoses for residue buildup that restricts the flow of water.....there is a small metal screen filter that clogs up ....most likely the cause if your pipes are old and the inside walls are shedding deposits into the water line.
