Question about General Electric Water Heaters
Ge electric water heater. 3 years old. keep tripping reset. both elements show 13 ohms, with no gronding out condition. help!
  • 349 Answers
Have you replaced the thermostat they will short out and keep tripping to they go bad. Check the ends of the elements also for any bad places. Ran along this a few times and it ends up being a bad thermostat causing it to trip. You will reset it and it may last a day or more and keep resetting it and eventually it will short out or burnt out. So please check it out and this helps you.
Posted on Mar 14, 2011
My kwikot geyser trips when I turn it on its 7 year old
If breaker trips check
- elements being to high in ohms resistance (worn out)
- shorted elements
- short to ground
- improper wiring or voltage per nameplate
May 19, 2017 | Water Heaters
I have a power star ae115 electric tankless water heater. It has performed flawlessly for approximately 5 years. A couple weeks ago it stopped producing HOT water but is still heating to Luke warm. The "...
5 years is about the lifespan for tankless.
You might have shorted element. That would explain cooler water and tripping reset.
Test element: power is off, disconnect wires from element; ohms = voltage squared divided by watt rating of element
http://waterheatertimer.org/How-to-test-water-heater-element.html
Call service technician./ Call Bosch
http://waterheatertimer.org/pdf/Bosch-AE115-AE125_manual.pdf
Gene
Oct 14, 2014 | Water Heaters
Not getting 240 volts to lower element- have replaced lower element and both thermostats. get 120 on each leg to ground but no 240
If your top element is bad the the lower element will never turn on be cause the top element completes the 240 circuit. It is like a resister in a circuit. Make sure top element measures out at 13 ohms.
Dec 24, 2012 | Rheem MR50245 Marathon Electric Water...
Water heating not heating water
The Emmerson W152 is ordinary 1-year warranty 120Volt electric storage water heater, except with bronze tank. The bronze tank will not rust, and therefore tank does not have anode rod, and tank has 5 year warranty.
http://waterheatertimer.org/pdf/Emmerson-point-of-use-water-heater.pdf
Actions to take:
1) Check circuit breaker.
2) Emmerson plugs into 120V outlet. See if outlet works for other 120Volt light or can opener.
3) Turn off power and do following:
4) Open cover on water heater, and press in reset button.
If reset will not reset, then replace thermostat with ordinary generic thermostat from hardware store.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
5) If reset button is not tripped, test element.
6) Emmerson has 1500 watt element, and correct ohm reading at 120 volts should be around 9.6ohms
7) This element is 7" long, and is also generic, and should be available at hardware, or plumbing supply, or Google-search 'Emerson appliance water heater element.'
Jul 29, 2012 | Emerson InSinkErator W-152 Point-Of-Use...
Limited hot water from 62 gal ge model D03666 looking for type and how to replace heating elements
Open following links to get started.
If water heater has NO hot water, then best suspect is ECO reset button tripped on upper thermostat. Open upper cover and push in red reset button. If reset keeps tripping, I usually replace both upper and lower thermostat.
If water heater has some hot water, then upper element is good so test lower element.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 22, 2011 | General Electric GE SmartWater Household...
Have sta kleen 805 , have power,240 v no hot water
If I understand correctly, your water heater circuit tested for 240 Volts.
1) If circuit has power on one leg of the 240V circuit, water heater can appear to have electricity, but won't turn on since 240V needs both legs to complete the 240V circuit. Solution: test for 240 across top two screws on upper thermostat.
http://waterheatertimer.org/B220C.html
2) ECO reset button tripped on upper thermostat. Solution, push in reset button. If reset will not reset, then replace upper thermostat. I usually replace both upper and lower thermostats at same time: cost $28. Buy parts from home center or hardware store. Be sure to put factory-insulation and covers back so thermostat is not exposed to cooler outside temperatures, that cause hotter water than set point.
3) If ECO reset button keeps tripping, then keep resetting until you can test water heater parts. Spend 30 minutes and do complete troubleshoot on tank.
Buy cheap multi-meter from home center. When test calls for checking voltage, rotate dial to 240-250-277 VAC. When test calls for checking continuity or elements, rotate dial to Ohms (upside down horseshoe is ohms).
Dec 29, 2010 | RELIANCE ELECTRIC WATER HEATER
The reset button has popped more then once.
You have electric water heater.
Electric water heaters are fully repairable by homeowner.
Reliance is AO Smith company
http://www.aosmith.com/OperatingUnits/Detail.aspx?id=138&ekmensel=c580fa7b_12_0_138_3
http://www.reliancewaterheaters.com/prod/elec.html
Age of Reliance water heater is shown on serial number located on side of tank:
first digit is letter. Next two digits are numbers: for example C06 means 2006.
Serial number also shows model number & wattage of elements in case you need new element from hardware store.
ECO reset button trips when upper thermostat senses temperatures higher than 150 to 180 degrees.
When ECO energy cut off trips, it turns off power at the reset button, so the tank does not continue overheating.
Tripping reset button says tank is receiving electricity, so we can eliminate that suspect.
There are 4 reasons why ECO will trip.
1) Bad upper or lower thermostat: solution replace both thermostats for about 25$. Steps shown in link below.
2) Loose wire or shorted wire at or near upper thermostat: Open covers on water heater and inspect parts for signs of high heat and burning.
3) Bad element shorted to ground in center of element: Solution test elements and replace defective element.
4) Factory-installed insulation and cover has been removed from tank: thermostat exposed to cooler temperatures, and misreads tank temperature, and then elements keep heating water.
If you want to test all the parts before replacing anything:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Thermostats are generic, and each functions same way and each can replace the other.
Same is true for both upper and lower thermostats
Dec 14, 2010 | RELIANCE ELECTRIC WATER HEATER
I awoke to no hot water, my heater is three yrs old and i just changed my upper and lower element and upper thermostat, still no hot water then i checked to see if i was getting power and i am, is there...
Your water heater has 2 elements so its 240Volts.
1) If breaker is delivering power on one leg of the 240Volt circuit, then water heater can appear to have electricity, but tank is receiving 120V. Both 120Volt legs are needed to complete the 240V circuit. Double check for 240Volts.
2) Review electric Load.
Water heater label shows wattage of tank.
If tank is 4500Watts for example, you installed 3500 or 4500 watt elements.
With 5500 Watt elements you need 30 amp breaker and orange-colored 10 gauge wire
With 4500 Watt elements you can get by on 20 amp breaker and 12 gauge wire up to 75 feet away.
3) Check ECO red reset button on upper thermostat. If reset is tripped, then ECO is reading high temperatures. Suspects at this point are defective upper thermostat, shorted wire or bad lower element.
4) Also note that insulation and cover must be re-installed over thermostat. Thermostat reads temperature through wall of tank. If outside air circulates around thermostat, that can cause a mis-read and cause tank to overheat and ECO trips.
If you don't want to test the heater, replace both thermostats for about $25. Return the upper thermostat for a refund. Then see of problem persists.
Here's what I would do.
1. Check breaker for 240
2. Check water heater for 240 across 1 and 3 screws on upper thermostat
3. Note wiring and breaker size.
4. Note label on side of tank.
5. Look at end of new element to see wattage printed on each element. Look for sings of high heat and burning. Tighten screws on elements.
6. Check ECO reset button. Look for high-heat and burning. Tighten screws on thermostat.
7. Test upper thermostat as follows:
http://waterheatertimer.org/images/Electric-diagram-water-800.jpg
Test left-side #1 screw to right-side middle #4 screw. Test should read 240V at all times. If not, then ECO is tripped, thermostat is bad, or electricity is OFF
8) Water heater is cold so upper element should be ON. Test upper thermostat.
Test right-side #3 screw to left-side bottom #2 screw and it should read 240V
Test right-side #3 screw to right-side bottom #4 screw and it should read 0 volts
8. If upper thermostat checks out. Test upper element for 240 across both screws. If upper element does not read 240 when water is cold, then element is bad or there is a shorted wire between element and upper thermostat.
How to test element:
9. Do a full troubleshoot on electric water heater
Dec 07, 2010 | General Electric GE SmartWater Household...
Reset button keeps popping. Have reset this 3 times now and it happens at night when no one is using water. This is a model 502 heater with dual elements.
The problem I have encountered in this is the thermostat is going bad and tripping out. Inspect the ends of the elements and make sure ther eare no black ends on the wires showing elements may be shorting out causing thermostat to trip. More than likely change the thermostat out and you should be good to go.
They are not to exspensive and local hardware stores carry them.
Aug 15, 2010 | Reliance & 50gal Electric Water Heater
The therostat breaker keeps triping no mater what the therostat setting is. I have to reset the breaker each time i want hot water. Is this GE solution to save energy?
It sounds like the thremostat may be shorting out they are not to exspensive to replace.
It it constantly triping there is a wire touching somewhere.
May 16, 2010 | General Electric GE SmartWater Household...
Water Heaters Logo
151 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
