Question about Garden
We have recently lost power to one end of our trailor the breaker flipped yesterday and now we can get nothing there is nothing plugged in now so what could be keeping our breaker from working
    Sergeant:
  • 257 Answers
I just recently fixed the same problem, and it turned out to be a bad outlet or plug in. Starting with the farthest room that is dark remove the outlets one by one and look for a blackened one. Replace it and repair any burnt wiring with some shrink tube to make sure it will not short out. You can get a tester for less than $10 that looks like a square pen and will let you know if there is power present just by placing it next to wiring or outlets. When in doubt, turn off everything!
Posted on Mar 14, 2011
I have one whole wall that all the plug ins are not working.
You need an electrician it can be the breaker or the power feed to or out of the breaker or ground
Mar 30, 2015 | Kitchen Ranges
Tip
What to do fro a blown Fuse or Tripped Breaker.
Well if you have Blown a Fuse/Tripped Circuit Breaker, FIRST, TURN OFF THE MAIN POWER SWITCH. Now, If a Breaker, simply flip the lever, the "Other Way" or, press the button, on the Breaker Body to "Reset" it. If a Fuse, you will have to withdraw the Fuse(s) from the "Holder(s)" until you find the Blown one, look to see if the Fuse Wire is intact, or, not.. a Blown Fuse will have the wire broken/melted. You then, effect repair, by simply using a length of the correctly rated, Fuse Wire. (Replacement Fuse Wire will be of different thicknesses, for different Current Ratings, usually, 5 Amps, 10 Amps, 15 Amps, & 20 Amps). Simply wrap one end of the Fuse Wire, around the contact, at one end, or if screw connection, then under there, & wrap clockwise, then, .make it go through the little hole/slot in middle, and then, wrap it around the screw, or wrap around the other end contact Then replace Fuse, turn the Power back on. Always do all this with nothing plugged into the power socket too. Now if the Fuse.Breaker "Blows" or "Trips" again, with nothing connected, you have a Wiring fault. Also make sure the Unit that caused the problem in the first place is repaired, or it, simply do it all again.
on Mar 05, 2010 | Heating & Cooling
Dryer wont start
Did you flip the breaker to the dryer and flip it back on
That has worked for me
Apr 04, 2014 | Dryers
No power to 3 plug ins
the breaker my have gone bad
Dec 29, 2013 | Dutchmen RVs
JBL Flip won't turn on
this doesnt help. how can i get back on?
Jan 11, 2013 | Harman Kardon JBL Flip black
Our Belling Touchtronic hob wont now turn on. Have checked wiring on the mains and fuses but make no difference. Any ideas? Was fine yesterday and had shown no signs of intermittent working
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times: I offer free advice bcuz God is so good!
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
5.
6.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
Dec 27, 2012 | Belling Ovens
We just recently moved, and when we plugged in our dryer at the new house, nothing comes on. I cant even get the screen to light up, almost like the power source is dead. I checked the breaker on the house...
-Try difference outlet. If it works then the first outlet you plug in has no power.
-You said you already check the breaker. it looks fine.
-Did you do any thing to the breaker or just look...?
-If the outlet that you want to use still has no power then how about try this:
-Open the breaker panel. Flip all breaker off, then flip all on one by one and check again. If you have power now then good. But still have no power then most likely the previous owner or renter disconnect the wires to that outlet from its connector. At the junction box or may be at the breaker.
Good luck
Mai
Jan 19, 2018 | Electrolux EIED55H Dryer
How do you know if you blow a fuse? i replaced my bulb and when i plugged back in i got a bit of a spark at the plug recepticle and now i get nothing... any ideas?
Well if you have blown a Fuse/Tripped a Circuit Breaker, FIRST, TURN OFF THE MAIN POWER SWITCH. Now, If a Breaker, simply flip the lever, the "other way" or, press the button, on the Breaker to "Reset" it. If a Fuse, you will have to withdraw the Fuse from the "Holder" and look to see if the Fuse Wire is intact.. a Blown Fuse will have the wire broken/melted. You then, effect repair by simply using a length of the correctly rated, Fuse Wire. Replacement Fuse Wire will be of different thicknesses, for different Current Ratings, usually, 5 Amps, 10 Amps, 15 Amps, & 20 Amps. Simply wrap one end of the Wire, around the contact, at one end, or if screw connection, then under there, wrap clockwise, then, .make it go through the little hole/slot in middle, and then, wrap it around the screw, or other end contact Then replace Fuse, turn back on the Power. Always do all this with nothing plugged into the power socket too..
Mar 05, 2010 | Mitsubishi HC1500 DLP Projector
Lost power after opening door during cycle.
Try and flip the breaker to off again and push lightly then on , when a breaker trips somtimes just flipping it on it wont catch a latch inside the breaker to actually flip it on.
Oct 29, 2009 | Dryers
Garden Logo
22 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
