Question about Acer Computer AOA150 Notebook
Battery will not charge. Purchased new battery and ac adapter still will not charge. Unit will work while pluged in but shuts down as soon as the cord is removed.
  • 55 Answers
My suggestion is to sned it into acer and tell them thet your battery terminals are malfunctioning because if you have replaced the battery and the ac power adapter it is probably somthing inside of the computer and opening that up voids your warranty
Posted on Mar 13, 2011
    Sergeant:
    Champion:
  • 285 Answers
The laptop is faulty i dont think it can be repaired your best bet is to take it to a computer shop and ask
Hi, my laptop crashes when the ac adaptor is plugged in yet it will charge the battery fine when the laptop is shut down.
Problem description: The laptop shuts off when AC power adapter is plugged in. The laptop works fine on battery power but as soon as you connect it to AC adapter, the laptop turns off.
Possible cause: 1. Power adapter failure.
2. Motherboard failure.
Possible troubleshooting steps and repair solution: First of all, test the power adapter. Make sure the adapter outputs correct voltage. It's possible that the output voltage is not correct and the laptop shuts down to prevent the damage. Test your laptop with another known good power adapter.
If the problem still exists, even after replacing the adapter, most likely it's the motherboard failure. Replace the motherboard.
Resource: Acer Laptop AC Adpaters
Mar 20, 2011 | Acer Computers & Internet
Few months ago I started having issues with the ac adapter it did not provided power to the unit, if you unplug and plug it again from the power cable it worked, until one day just stop. I purchased one in...
Apparently, either the AC adapter isn't compatible (check the voltages and power ratings) or you have a battery charger issue. If you're sure the adapter is OK, then the battery might wrongly report a full charge at a higher voltage than the AC adapter.
So when the battery is plugged in, it will always preempt the AC adapter - possibly even shutting it down - except that, having almost no power left, it will also force the computer itself to shut down.
What might have happened is that the faulty AC adapter actually damaged the battery. I'd suggest checking with another battery if any is available, and not to use both together lest the battery now damage the new adapter. But first of all, check the power ratings and polarity on the adapter against the old one and whatever is indicated (usually) on the PC underside, just to be sure.
Oct 27, 2009 | Gateway 6022GZ Notebook
Toshiba Laptop Wont Boot.
yes,if the battery doesn't charge with the ac adapter or turn on with it pluged in.it is common on comuters for the power adapter on the motherboard to go bad after a while.downfall of the laptop is that it is very hard to replace it(desktop easy because it is not built into the motherboard)you can either buy a new motherboard or a new laptop.if you got any more questions feel free to email me at gamecrazy944@yahoo.com
Aug 03, 2009 | Computers & Internet
Lenovo 3000 N200
sounds like the mother board maybe on its way out - is it under warranty?
Jul 24, 2009 | Lenovo 3000 N100 0768 - Pentium Dual Core...
My laptop HP Pavillion ZV6000, battery started decreasing and wouldn't charge when the ac adapter was connected. I purchased another ac adapter thinking that was my problem. It didn't work. Now I have...
As others have said, the most common fault with the ZV series is the power socket. However, you mentioned the Lightning Bolt. This indicates that the battery is being charged and it should go out as soon as the battery is fully charged.
If the Lightning Bolt flashes on and off regularly, especially when the power cable is moved, then the socket is at fault and needs replacing.
You can check to see if the battery is receiving a charge by doing the following
1. Right Click the Desktop
2. Click Properties
3. Click the Screen Saver tab
4. Click the Power button
5. Click the Power Meter tab
This will tell you the computer's current power source and whether the battery is charging.
I have replaced several of these sockets on ZV5000s and I'm sure the 6000 will be similar. I would not recommend this job for anyone without technical knowledge, despite some of the websites that say you can do it yourself. You will need to strip the entire laptop down and all but remove the motherboard before the socket can be replaced.
Hope this helps
May 21, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Wont charge while powered on or run on ac power
Sounds like a lose or burnt charge terminal.  Fixing would require disassembling the laptop and resoldering the loose or broken connections.  You might want to try a different AC adapter first.
Apr 21, 2009 | Toshiba Satellite A75-S211 Notebook
Hi!
It's your ac adapter that is causing this issue. The ac adapter doesn't supply enough power or doesn't supply any power at all to the battery. Try to borrow another ac adapter from any inspiron system and if that works, then you need to replace the ac adapter, else, it's the motherboard.
Hope you find it helpful.
Thanks,
Karlox™ :)
Jul 28, 2008 | Dell Inspiron 1501 Notebook
Issues with new Garmin
Try pushing the reset button and charging again. If that doesn't work I think you've got a defective unit. Contact the seller and sendit back for a trade.
Apr 20, 2008 | Garmin Nuvi 660 GPS Receiver
Supersonic SC-299TDVD
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
Dec 27, 2007 | Supersonic SC-299TDVD
Acer Computer AOA150 Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
