Functional problem sc552
How can i correct the functional problem sc552
  • arnoldjemy Aug 02, 2008
    bubbabear64,
    Absulutely its ricoh 2075 and thanks for your tips. anyway, i found out already the problem yesterday it was one of the thermostat on fusing unit.again thanks and more power
    arnoldjemy
  • Anonymous Jan 04, 2009
    asap
  • 2,794 Answers
I take it this is for a Ricoh?
SC552 is a pressure roller warm up error. It didn't detect the right temperature when it was turned on.
Turn the copier off for 30 seconds and then turn it back on again. If the error message returns, a technician should look at the fuser section to see whats causing the problem.
Posted on Aug 02, 2008
Sc552-03 on my ricoh Aficio sp c830DN please what is the remedy
Jun 05, 2013 | Office Equipment & Supplies
I have a copier ricoh aficio 2550 and presents me code SC552. As the unlocking?
I have a copier ricoh aficio120 and presents me code SC552. As the unlocking?
Feb 13, 2013 | Office Equipment & Supplies
When we turn on the power we are getting an error message "Functional problem within the Copier. Please call service and report the service code SC552. Ricoh Copier Model MP5001
Solution Reset (machine was not working for 2 - 3 month):
C button (yellow) + on keyboard: 107 + C-button (orange + large) long press
Then, go to the menu
scroll
Mode 5 enter
here below 810: SC Reset
Unfortunately, there is no OK
keyboard: 0 or 1 (probably 1) choosed and press #
it displays a confirmation message: run as service - etc.
Switch off the machine
Error: reset
(on some devices without a reset command: open flap + off)
Jan 29, 2011 | Ricoh Computers & Internet
Sc552
Pressure roller warm-up error
pressure roller thermistor bad or dirty
Jan 15, 2010 | Ricoh Aficio AP3800C Laser Printer
Operating problem for copier machine
SC552 is a fusing thermistor error. Thermistor is in the fuser section. This code is for the END thermistor. You can also try to just reset the code. Enter the SP mode (service program) by entering the following keys.
CLEAR MODES, 1 0 7 and hold the CLEAR STOP key down till the maintenance screen appears. Press COPY SP on the touch panel then turn OFF the MAIN POWER SWITCH then turn it back on and see if it clears. NOTE: The "MAIN POWER SWITCH" is of the left side of the machine, NOT the top right side.
Sep 14, 2009 | Gestetner DSm660 Copier
We have a code SC552 functional problem with copier what does this mean
if the machine is a plack and white ricoh then the new error code is for the thermistors in the fuser they are not sending the correct temp readings check the fuser for toner build up on the surfaces of the thermistors and check the thermo fuses to see if they are blown....GOOD LUCK aa>>
Jul 30, 2009 | Lanier Office Equipment & Supplies
Error msg "sc552,Functional problem" on a Ricoh Afficio 1013F?
You either have a defective thermostat (thermistor) in your fuser, or a defective power supply. The error can only be reset by a tech in service mode after the problem is fixed
Jul 16, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Desperate!!! Ricoh AP3800C Error SC552 fixed last week now back
SC552 means that the pressure roller (Lower roller in the fusing unit located in the left hand door of the machine) is not warming up correctly. Is the copier installed somewhere cold? i.e. a garage? If conditions are ok and damp is not a problem, either the thermistor that controls the pressure temperature is defective, or the lamp that warms it up is defective. They are the two more common problems, might be worth looking for one on ebay. However they are approx 250 pounds so if you can find a second hand one thats cheap for spares I would recommend that. Email me if you have to do this and I will talk you through changing the parts.
Dec 23, 2008 | Ricoh Aficio AP3800C Laser Printer
4,252 people viewed this question
jasbo
jasbo
