RICHMOND/MISER MODEL 5V40-7, breaker keeps tripping, have to keep lighting pilot lite
    Guru:
  • 683 Answers
This is two different problems, if you are online i will see if i can help you.
Posted on Mar 13, 2011
U can light the pilot lite,turn 2 ON it will stay lit 4 a couple of minutes then go out? If u turn the knob 2 low,med. It goes out pretty much immediately?I changed the thermocouple,blew the lines ou
Is the thermocouple secure, routed properly, no kinks, no sharp bends? Is the end of the unit properly aligned so the hottest part of the pilot flame is hitting the unit. Did you hold pilot switch in the light position for at least 30 seconds, before you set the gas valve to on? If all above OK, try this. Light the pilot using barbeque lighter once it lights keep the lighter on the t-couple for 30 seconds, then set the valve to ON and keep the lighter where it is. Once the main burner lights, remove the lighter. If the burner and pilot go off, your gas valve is bad.
Feb 17, 2015 | Rheem Richmond 75 Gal Natural Gas 6 Year...
How do we lite the electric water heater run off of a battery or a generator ? and how do we lite it
If it is electric, you do not have to light anything. If it was gas you would have to light the pilot light. Electric water heaters have elements. If you have no hot water it could be caused by no power to the elements (like circuit breaker tripped or fuses). Check to make sure the breaker is not tripped. If there is power, I would test the upper heating element using a multimeter. If you do not know how to do this, then you should probably get a professional to come help you.
Feb 10, 2015 | Cars & Trucks
Fuses
Make sure that the fuse is not blown by checking with an ohm meter. The circuit that the wheel pilot is on may also have a breaker. Make sure that the breaker is not tripped.
If the unit keeps tripping the breaker or blowing the fuses, then the motor is going bad, or at least needs some maintenance.
Apr 17, 2014 | Raymarine Boating
I have a 5v40 hot water heater. I lite the pilot and burner work fine as long as i have the door open to get air. close the door and the pilot lite and burner goes out. starved for air. there looks like...
Probably don't have good news for do-it-yourself repair.
Richmond is Rheem.
Rheem gas water heater manuals say to call service technician if the combustion chamber FV sensor has tripped, or if water heater has flooded.
FV trip requires part replacement, and flooded heater has to be replaced.
I read one thread that might help:
http://www.diychatroom.com/f7/rheem-hot-water-heater-pilot-burner-not-staying-lit-65755/
I posted same question on pro water heater forums, and the plumbers will not man up and tell how to replace the part. They cite legal issue because gas water heater is dangerous, period.
They have a point, but I am still looking for a good DIY answer.
If repairs are more than $330, then buy a new heater at local box store and install yourself same day.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 17, 2011 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Rheem NatGas hot water heater model 41V50, basement flooded pilot went our how do I relight?
At the controls there should be a knob that says " Pilot"... "ON" Turn the knob to pilot and hold it down while lighting the pilot lite. Keep holding it down until it gets warm enough that when you leave it up the pilot stays on. Once the pilot lite stays on on it's own turn it to on.
Mar 14, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a Kenmore Power Miser 12 gas water heater that the pilot light keeps going out. The water heater has been in service for 45 months. The pilot light has a blue flame with some orange flame flares...
check and or replace the thermal coupling. the coupling goes into the main gas control, if the coupling is bad it will shut off gas supply. as a safety measure.
Mar 09, 2011 | Water Heaters
The Lights circuit breaker keeps trips without load
try a new breaker, they do wear out over time
Feb 08, 2010 | Electrical Supplies
Heating & Cooling Logo
251 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
