Question about Car Audio & Video
I am having trouble with the shift interlock on my '92 Audi 100cs. When the engine is off and the key removed I can move the shift lever through all gears; however when the engine is running the shift lever is locked in either the "P" or "N" position even when the brake is depressed. Can you offer any suggestions to correct this issue?
  • 11,800 Answers
The solenoid that controls the blocking pin is faulty. The easiest and cheapest way to fix that is to completely remove the blocking mechanism - it's bolted on with just 3 screws.
Posted on Mar 13, 2011
I have a 2006 lincoln zephyr and I can't get key out of ignition
Does it have floor shifter ? Shift interlock system .
Diagnostic Trouble Code (DTC) Chart
DTC Component Description Condition Symptom Action B2572 Brake Shift Interlock Brake Shift Interlock Output Circuit Failure The associated circuitry connected to the smart junction box (SJB) or fuse, or the SJB itself may have an issue causing a brake shift interlock concern. Brake shift interlock is inoperative or does not operate correctly. Go To Pinpoint Test A .
SYMPTOM CHART Condition Possible Sources Action
  • Shift interlock system does not release/lock correctly
  • Circuitry open/shorted
  • Fuse(s)
  • Stoplight switch
  • Go To Pinpoint Test A .
  • Shift lock actuator
  • INSTALL a new selector lever assembly. REFER to Selector Lever in this section.
Do you have a scan tool ? Not a code reader .
Aug 25, 2017 | Lincoln Cars & Trucks
My 2007 chrysler pacifica wont shift out of park.
SHIFTER LOCKED IN PLACE
  1. Remove the instrument panel cover below the steering column, then remove the steering column shrouds to gain access to the brake transmission shift interlock (BTSI) solenoid. The solenoid is part of the interlock cable assembly.
  2. Disconnect the wire connector from the rear of the BTSI solenoid.
  3. Insert the ignition key and turn it to the ON position.
  4. With the brakes applied, try moving the shifter out of the PARK position.
    • If the lever now moves freely in and out of PARK, perform the Circuit Test below.
    • If the shift lever still does not move from the PARK position, remove the BTSI solenoid from the shift lever assembly. If the shift lever now moves freely in and out of the park position, the BTSI solenoid is faulty and the interlock cable must be replaced. If the shift lever still does not move from the park position, the problem is in the shift lever assembly or the ignition interlock cassette
Aug 14, 2011 | 2007 Chrysler Pacifica FWD New Cars
My 2005 Pacifica will not disengage from park and the check engine, brake and anti-skid warning lights are all on
Jul 30, 2011 | 2005 Chrysler Pacifica
2006 chrysler pacifica - drove car into my garage and shut down. Next morning I could not get the car to shift out of park.
some are set up with safety with brake lites out. ck if brake lites work if not turn key on do not start and shift to neautral and start and have brake lites repaired
Jun 03, 2011 | 2006 Chrysler 300
2006 Chrysler Pacifica- Will not shift out of Park, the steering wheel isn't locked, and the brake is releasing as it should. What else could it be?
Can't get out Park, starts ok, tried the manuel thing pressing
the pink release button, nothing. Had the car towed but
they had to hoist it on a truck. Was there a recall for this?
Jun 09, 2010 | 2006 Chrysler Pacifica
Gear shifter does NOT shwitch from park and break
May 09, 2009 | 1998 Honda Accord
Gear shifter is not moving when u press on break
center console shifter? if so, likely could be a misadj shift cable, you can pull loose top cover per instruction maneul tells you how to get out of park till you can get it adj, or repaired
Apr 01, 2009 | 2004 Ford F150
Can't get 1993 Linclon Towncar out of park
Feb 21, 2009 | 1993 Lincoln Town Car
2000 range rover
Pull hard on the steering wheel to the left and the steering wheel lock mechanism should release. I mean pull hard to left because shift interlock is froze if you cannot get it this way you will need a pro to help! Good Luck Mate.
Dec 07, 2008 | 2004 Land Rover Range Rover
Key gets stuck in ignition
My daughter drives a Suzuki, my solution to her is: while the gear shift lever is in park, lightly put pressure on the gear shift lever, through the park position and while pressing the gear shift towards park light rock left to right while trying to remove the key.
The interlock between the transmission and the ignition switch needs to be adjusted/ repaired or replaced.
Oct 04, 2008 | 2006 Suzuki Forenza
Car Audio & Video Logo
18 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
