Carrier Condenser Fan Part# LA11ZD058 has 3 blades that have broken off. I am having a problem finding just the blower itself without having to buy the motor also
    Guru:
  • 1,524 Answers
1-800-Carrier
Posted on Mar 13, 2011
My son has a noisy condenser fan on the carrier condensing unit, model is a BRC060360 and Im puzzled on this unit seer rating, any ideas? Also looking for a budget condenser fan for it?
Condenser fans are usually not very expensive, so I suggest you go to a carrier dealer and buy one as a spare part. Have you check that the fan is clean and none of the blades are damaged.
May 19, 2016 | Carrier Heating & Cooling
When the heater is on, should the fan outside on top of the unit also be working along with the blower from the heater ? When the heater is off, cold air is comming from the vent's, can I cover the
No. This is strictly a gas package unit, not a heat pump. the condenser fan motor should NOT run when their is a call for heat from the thermostat. The condenser fan only runs with the compressor on a call for cooling. Hopefully the compressor is not running @ the same time, but if it is, it would make sense that the contactor for the compressor & condenser fan motor is stuck closed OR the low voltage cooling wires are shorted straight to a 24Volt control wire.
Jan 15, 2015 | Carrier Heating & Cooling
Very loud when fan is running
This is likely caused by a faulty blower motor bearings, or the fan has something in it or it could possibly have broken. Shut down power to unit, remove cover and inspect the fan shaft, blades, and spin it. it should freely spin. If it hangs up you likely have a bad blower motor.
Mar 03, 2014 | Carrier XHB123D X/Y Series Heat/Cool Air...
I cannot find a condenser fan for a 1973 Ford Ranchero. it is the fan that attaches to the blower motor for the heater. 1973 Ford Ranchero GT 351 Cleavland
Yah!, sometimes, old spares won't be available. But if you replace with other model of fan motor with blade, but same capacity it will work out.
Tnx
Nov 13, 2013 | Flex A Lite 1973 Ford Ranchero Fan Blade...
I have a carrier Day & Night a/c - heater unit. the model # 591ANX0480000ACAA, 208/230 volts. my blower fan stays on continuously, even after turning the thermostat off. the condenser fan does not come on...
If the blower fan in the furnace won't turn off, there is a tripped/blown limit. It's a safety. As for your condenser fan it could be a run cap or motor. Do yourself a favor and have a licensed HVAC contractor take a look. Find a NATE certified or ACCA member. You will find a much better more qualified contractor.
Sep 23, 2013 | Carrier Packaged A/c 3 Ton 13 Seer And...
How to replace condenser fan blower wheel and where can i get one ?
Hello, in order to replace the condenser fan you will need to remove the motor aseembly and use a hub puller to remove the fan blade. When removing the fan blade spraynsome wd- 40 on the motor shaft and then attach the hub puller to remove the fan blade. You csn buy the fan blade at any heating and cooling store.
May 07, 2012 | Continental Heating & Cooling
Just had AC tech charge $257 to replace capacitor on carrier 38ckco48300. tech also stated condenser fan motor may have been damaged with replacement cost of $500. can a condenser fan motor for this unit...
I don't know what part of the country you are in, but here in Okla. a condenser motor can be bought by the home owner for around $100. You should be able to go to any appliance supply house and purchase your own motor. Take the model and serial number with you, it may help. If you have a local carrier distributor, they should give you a users manual. Try your best to get a motor close the the same as what you have. Note the horsepower, rpm, voltage and take the fan blade with you in case you need a new one. Hope this helps. Mark
Sep 07, 2011 | Heating & Cooling
Carrier unit pro earth ultra fresh II, unit stays on for about 15 min then everything shuts of, showing error: high head pressure
clean your condenser with air pressure to blow out the condenser or use spray bottle to wash down the condenser and fan blade wipe down and make sure all lint is removed from air flow passages!
Aug 28, 2011 | Carrier Refrigerators
Amana AP148D-RB, Air Conditioner Parts
Not sure if you have fixed yet, but I had the same problem on my AP148D. There are 2 fans, 1 for the condenser (base of unit) and 1 for the evaporator (top of unit). My condenser fan disintigrated. Go to his web site and you will find a parts list for this model, and a distributer list http://service.haieramerica.com/Models.aspx?CID=231
Call this number and they have the parts in stock : 800-313-8495, mine shipped overnight. The parts are :
AC-8000-27 Wheel-blower condenser $21.81
AC-8000-26 Wheel-blower evaporator $21.81
I suspect you will need the first part. Hope this helps. Be careful to note where all the screws come from when dismantling !!!!
Mar 02, 2010 | Heating & Cooling
Carrier Synergy 2000 Condenser fan does not turn on
the mfd is stamped on the side of the capacitor.Be careful to kill the power and to NOT touch the terminals.The capacitor is capable of holding a charge even after power is disconnected.
Jul 28, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
