Question about Dell PowerEdge 1500SC ( pe1500sc/2113 ) Server
I have a dell power edge 2300 and at boot there is a constant beeping and wont stop until i turn the server off wht could this be
  • 60 Answers
Does it actually boot up?? sounds like a motherboard issue.
Posted on Mar 13, 2011
Dell PowerEdge 2300 Server won't boot
To power off using the power button, press and hold in for more than four seconds.
However this is not solving your problem of not booting, needs some more information. Such as Beeping noises, number and length of beeps. Or any LED.s flashing?
Aug 16, 2012 | Dell PowerEdge 2300 Server
Have a Dell 6300 Power Edge serving running Windows Server 2003. Server was working fine until this morning. Server is in constant sleep mode. Unable to get video display or any peripheral working. Checked...
I had the same problem in two Power Edge 2970s. I had a bad stick of RAM in each server. After removing the bad sticks they both successfully posted.
Aug 13, 2012 | Dell PowerEdge 6300 Server
Power edge 2550 beeps 1-3-2 will not boot up
If you're positive the memory is good then it means that the system board or the actual seating for the memory is damaged.
If you have someone with soldering skills they could try and re-flow the seating for the memory. Otherwise you simply just will have to replace the system board.
info about this process can be found HERE.
Jun 29, 2011 | Dell PowerEdge 2550 Server
Dell power edge 2850 make 4 seconds beeps alarm without stopping and without show any error Msg on the screen.
I don't understand the beep code you describe, but the 2850 has many beep codes to help understand what is going on.
First ... Identify the beep. Does the beep start as soon as you power it on, or after several seconds? What is the pattern of the beep - is it a repeating set of beeps - 3 sets of beeps between 1 and 4 beeps ... like 1 beep-3 beeps-2 beeps, or 3 beeps, 3 beeps, 1 beep? Or is it a steady repeating beep - about once per second?
Second ... is the LCD panel on the server blue or orange? If orange, what is the error code(s) it is scrolling?
If it is a steady, once-per-second beep, it is probably your RAID controller. Does the system boot to Windows/OS ok? If so, use (or install) OpenManage Server Administrator (Managed Node from Dell's Support Site) to check the Hardware Logs and check the RAID array (under Storage/Virtual Disks). If it is not booting to the OS, then go into CTRL-M to see what the status of your array is.
Aug 16, 2010 | Dell 3.0 GHz Second Processor for...
Dell poweredge 2300 server have a contant beeping. i change the battery but still beep.
It probably is trying to tell you that it is overheating.
Check that the fan(s) on top of the CPU(s) is/are working.
Jul 30, 2010 | Dell PowerEdge 2300 Server
Wont boot says array controller wont start and no bios dell power edge 2500 server
Sounds like the RAID controller has failed. I would replace this first as RAID controllers are less expensive than replacing the system board, or the server as a whole.
Suggested: PERC 5i (RAID 0/1/5) or PERC 5iR (RAID 1 or 0 only)
Jan 03, 2010 | Dell PowerEdge 2500 Server
Dell 1800 power edge is giving long beep continuously.
Power supply, system board, or keyboard problem
Apr 17, 2009 | Dell PowerEdge 1800 Server
Dell Poweredge 700 Server problems
Dear jckim, Which server you are using? Usually this error occurs when raid controller card have some problem.Have you getting any error codes?
Oct 20, 2008 | Dell Computers & Internet
Constant beeping when booting up
It is just keypad problem.needs servicing the keys.
Jul 07, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
211 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
