Question about Dell Inspiron 546 MT Desktop Computer
Dell Inspiron 546; 5 beeps when I TRY to boot-up computer. Power light in front of computer is yellow during attempted boot-up, light is normally blue when computer is working properly. After about 5 ties to boot-up computer works seemingly normally.
  • 60 Answers
It is either a memory or graphics card problem. you can clean the pins on the memory cards and the graphics card with a pink erasure and reinsert them and see if it gets rid of the problem.
Posted on Mar 13, 2011
    Sergeant:
    Champion:
  • 285 Answers
Have a look to see if the memory is sitting down properly if thats ok it might be that your motherboard is on its way out or you processer is faulty
546 will turn on normally(light is blue) but won't display my monitor and usb ports power some items and not others.
You probably dislodged some components in your computer after it fell. Suggest that you open the computer and re-insert the memory modules and other cards inserted in the motherboard. Unplug it first and on a non static surface like a kitchen table.
Mar 22, 2014 | Dell Inspiron 546 MT Desktop Computer
Adding Memory to Inspiron 546
Try them in slots 1 & 2 also make sure your ram is all the same .Also try 1 at a time you may have a faulty ram module. .
Jan 17, 2014 | Dell Inspiron 546 MT Desktop Computer
What does a memory card look like
Are you speaking of the RAM / DRAM card inside the PC? You need to google it online to see it before you open the case. Dell offers many PDF manuals which include replacement of those cards. It normally is not difficult or expensive. Be careful in dry weather, of static discharge.
Jan 11, 2014 | Dell Inspiron 546 MT Desktop Computer
Dell Inspiron Desktop 546MT, green light on the back, but no light on the front
Could be a faulty switch, switch wire connector loose from the motherboard, faulty power supply.
Jan 29, 2012 | Dell Inspiron 546 MT Desktop Computer
Dell Inspiron 518 Solid Amber light on power button. My power went out today and i turned my computers back on and this happend. All fans are running.
Your computer has failed the Power On Self Test.
Be sure to check all external connections as well as the connections within the computer chassis. Clean the Gold fingered connections of the RAM modules and Graphics card with tissue paper.
Also go through my published guide entitled, My Computer is not turning on!!! Is it dead!!! No POST!!! for additional help and information.
You may need to clear the BIOS/CMOS.
Take care!
damnor01
Sep 22, 2011 | Dell Inspiron 518 Desktop Computer
My dell inspiron 1525 power light is blinking amber???
Most newer models of Dell computers now have a diagnostic LED surrounding the power button on the from of the computer. When you press the power button to boot the PC, the light should be green and remain green under normal circumstances. Any other lights will help you troubleshoot the power issue you are having.
A solid green light means the computer is operating normally.
A solid yellow light indicates the power supply is operating normally but the computer is not processing data. This could mean there is a problem with the CPu or another component on the motherboard.
A blinking yellow light indicates the power supply is receiving power from the wall, but not functioning properly. This generally means the power supply itself is bad and should be tested or replaced.
A blinking green light means the computer is in standby mode.
So use the LED power light codes if your Dell computer has them. Also pay attention to any unusual beeps or sounds coming from the computer. Then join us in our free computer tech support forums and we'll try and help you solve your PC problem. Sometimes, however, a service call to Dell will be required. If your system is still under warranty, you should always just call them first, as tampering with your computer may void your warranty.
Hope this helps!
Mar 31, 2011 | Dell Inspiron 1525 Notebook
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
I turned my 546 off from the 'Safe' mode and now it will not power-up. No yellow or blinking lights.
if no power indication at all, the I'd ensure the power supply connection is good, bypass any power strips and see if the system powers on, if no power with a known good outlet, then like the power supply for the system has failed (Generally an AXT power supply about $30)
Feb 12, 2011 | Dell Inspiron 546 MT Desktop Computer
I have a Dell Inspiron 546 running Windows Vista. When turning it on the Start button lights up, but the display very quickly goes into power saving mode. Nothing further can be done. The computer or...
Hi. Were you able to see the the DELL post screen when you turn on the computer? Take out the battery and unplugged the power adapter from your computer and to the wall socket. Press and hold the power button for 30 secs. Put everything back in then turn on the computer.
Nov 07, 2010 | Dell Inspiron 546 MT Desktop Computer
Computer won't start, solid amber light, no fans, no keyboard, nothing. There is power to monitor and modem. What's wrong and how can I fix it?
That my Friend is the Yellow Light of Death, anyway turn on Your PC, as it starts You will here some beeps especially on a Dells. Count the beeps , there will be a slight pause so it will beep once then pause then beep again. Count the beeps and that will be Your code. Go to Dell Support site and look up code. Most of the time a Yellow amber light means that there is trouble with Your Motherboard but thats not to say its the Motherboard itself, during a power outage with no surge protected, it could have possibly burned out Your RAM, Processor, Heat fan, even the power supply itself. So look up the code and at least You'll have a better chance of finding the solution, Good Luck
Sep 21, 2010 | Dell Inspiron 530 Desktop Computer
Dell Inspiron 546 MT Desktop Computer   Logo
1,065 people viewed this question
Alun Cox
