Question about Whirlpool Washing Machines
I can't get my washer to spinn, I hear the timer inside ticking but won't spin out the water
  • 668 Answers
If the washer will agitate but not spin I'd suggest you to replace the lid switch. Then you need to check the
coupler is working properly or not. In order to provide you proper steps to access the coupler and lid switch.
Please resubmit the question with some more details.
Hope this helps.
Shane
Posted on Mar 13, 2011
Cloths come out wet after spinn
The water drained out ok? If yes, the timer is telling the motor to reverse and run in the drain spin direction and it is likely ok. If the draining is slow the clothes could come out wet, if the belt is cracked or streatched the clothes could come out wet. If the motor is not running through the entire spin/drain mode the timer could be at fault.
Will Not Spin
• Check for unbalanced load.
• Check for broken or slipping belt.
• Does the house drain system accept water from
machine?
• Check for blocked drain hose.
• Check for binding tub seal.
• Check for partial engagement of brake assembly.
• Check for obstruction between tubs.
• Check for broken impeller on pump.
Jan 02, 2012 | Amana NAV5800A Top Load Washer
For Eurotech EWC177W fornt load washer, the machine stopped working in the middle of a cycle and now the start light does not illuminate. I have determined it's not the outlet power. Does thsi washer...
Hi
If the cycle won't complete then either it's a problem with the timer or a cold-water supply problem:-
If your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water.
Please check the link to get some more idea:-
http://www.washerhelp.co.uk/diy-repair-help_8.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Jul 07, 2011 | Washing Machines
Water still in machine
Depending on how high your drain hose is some of the water after the final spin can drain back into the outer tube of the machine. This wont hurt anything but when not using the maching, not a bad idea to leave the door ajared to prevent the washer from giving off a bad odour,
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore washer 70 series how to replace belt
The belt is replaced by loosening the tensioner.
then slip it off the pulleys.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 09, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won;t drain or start spinning
check the lid switch if its ok
you have a problem with the timer
replace it
Jul 05, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool ultimate care II will not spin
You said,washer is full of water and will not spin. You hear the lid switch clicking. When you start it on spin cycle and hear a hum, the tub moves a couple of inches and then stops...shortly after it shuts off.
Some reasons this may happen
Washer won’t drain or spin
n
1. Is the drain hose clogged, or the end of the drain hose
more than 72 inches (183 cm) above the floor?
2. Is the lid open? ............Also the lid switch can be faulty!!
The lid must be closed during operation.
3. Is there excessive sudsing?
Always measure detergent. Follow manufacturer’s directions.
4 If you have very soft water, you might need to use less
detergent.
Sounds to me like the lid switch can be faulty!!Then it acts like the lid is open.
Huuum
Oct 13, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
16 people viewed this question
Dan Webster
Dan Webster
Sal De
