Question about Garden
What is the battery voltage on a sentinel by murray sit-on lawn mower, it doesnt say on the battery and its in need of a charge. The engine is a briggs and stratton 10bhp hope you can help me thanks Gary
    President:
  • 3,074 Answers
Same as a vehicle 12 volts, you can use a pair of jumper cables and use you vehicle to jump start it. Good Luck Tim
Posted on Mar 13, 2011
Stiga Lawnmower - On numerous occassions i have to slightly charge the battery b4 it will start.It tries to turnover but on second attempt it just clicks. It wasn't long that it had a new battery.
Try measuring the voltage across the battery when mower engine is running. If it is too low it will not charge the battery. .Should be 13.5 V to 13.8 volts if it is a 12V lead acid battery.
if it is lower then alternator device in the mower will need to be checked out.
May 03, 2016 | Garden
How do you check a ignition switch on a murray riding lawn mower to make sure it is operating properly?
You will need a multimeter... then you will need to check each wire port to see if voltage is registering . I would also disconnect the safety switch under the seat or.. plus put the emergency brake on as well... anything and all that will stop the engine from getting the signal to the coil to start up..
Nov 01, 2015 | Murray Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
Gx75 not charging
a lawn mower battery is only good for a couple years when keeping it charged and testing voltage doesn't tell you what is has for amps is the volt meter read more than the off voltage while running then it works they only have a 4-7 amp charging system
Apr 30, 2012 | Garden
I have a craftsman LT 1000 lawn mower that runs the battery down while it sits and it will not charge the battery while mowing even though the guage says that it is charging.
Something within the machine is discharging the battary, it does not sound like the engine is not charging, there is a tool called a negative shunt, it connects to the negative pole on the battary and enables you to connect a multi meter, this will tell you if there is a charge going out of the battary when the machine is switched off, you can then disconnect components to see which one is causeing the problem, a good mower shop should have such a tool .
Mar 08, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a diagram on how to fit a cutter deck belt for a murray sentinel 15.5/ 106. Belt number 037 x 88 Keith
The routing is usually pictured on the belt cover such as in your picture. If you send me the model no. to the rider, I will verify proper routing.
Feb 11, 2011 | Murray 38 Lawn Mower Blade Belt '90'96...
Murray quattro ultra mower
Murray for the Mower and I imagine its a Briggs engine, go to Briggs.....If any other engine go to the maker of that engine.
Jun 04, 2009 | Garden
Garden Logo
294 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
