Question about Vacuums
I need an instruction manual for the Archer Battery Charger 23-134
Will not charge the charging light is flashing
I'm not familure with your device but this is battery charging101. For a battery to charge the input voltage must be higher than the operating voltage of the battery. An example of this is your car. You have a 12 volt battery in your car and the alternator applies 13.4 volts or so to charge it. It is the same with any battery charger be it phone, laptop, chordless drill or small AA,AAA,C,D battery charger, that being said is the Dyson charger a seprat device? If so it can easily be tested at Batteries Plus, Any big box auto parts store, any high school electronics class. Check your owners manual it should give you the operating voltage, check that against what you discover about your charger. The charger only needs higher voltage output than the battery it doesn't have to bee a lot more. If you have further ? Email me at bret610@icloud.com good luck. Ps, you can by a reasonably accurate and easy use volt meter at W-mart for under $20. I am attacking video from u tube as to usage it's not difficult and well worth the money.
Sep 28, 2014 | Dyson Animal Bagless Cordless Hand Vacuum,...
When I put the battery on the charger the light on the charger stays on for little awhile the it starts to blink, but when I try to use the battery it is not charged. So I am not sure if I need a new
Hi there! It sounds like you have our Linx stick vacuum or hand vacuum model. Plug only the charger into an outlet, the blue light on the charger should flash once. If the light on the charger flashes once then the charger is fine. Try resetting the battery by following these quick steps below.
1. Remove the battery from charger or cleaner
2. Unplug the charger
3. Insert the battery into the vacuum and turn the unit on for 30 seconds (even if it has no power)
4. Remove the battery
5. Plug the charger into an outlet, make sure the light on charger blinks blue once.
6. Insert battery into charger
The light should be a solid blue, indicating the battery reset worked. If so, allow the battery to charge for 3-4 hours, completely deplete battery on your next use and re-charge. If the light on the charger is still blinking, your battery will need to be replaced. I have included a link where you may go to purchase a replacement battery if needed. Hope this helps!
Search Results
Sep 21, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Why doesn't my battery charge? Why doesn't the charger's light come on?
Hi Suzanne! Follow these steps to check that your charger and battery are working properly.
1. Unplug the charger for at least 30 seconds.
2. Plug the charger back in. The blue light on the charger should flash once.
If the blue light flashes once this is an indication that the charger is still functioning properly. If the blue light does not flash, the charger will need to be replaced. Follow this link to order a replacement charger. LiNX Battery Charger
3. Place the battery in the vacuum and turn it on for 30 seconds. (even if it does not turn on or powers off)
4. Turn the vacuum off.
5. Remove the battery and place it in the charger.
If the light on the charger is solid blue this is an indication that the battery has been reset. Allow 3-4 hours for the battery to fully charge. The blue light will start to blink slowly to indicate the battery is fully charged.
If the light on the charger is flashing blue or there is no light at all this can mean that your battery needs to be replaced. Follow the link to order a replacement battery. LiNX Lithium Ion Battery
Hope this helps!
Jul 28, 2014 | Hoover Platinum LiNX Cordless Stick Vacuum
I have a Dyson DC35. It has just stopped working. The green light on the charger is on and the vacuum is plugged into the charger, but it is like the vacuum is completely dead.
I had a similar problem. I have it on the wall mount and it turns out the plug that goes into the dyson to charge the battery had become unseated from the mount. I pushed it back in ("click") and that fixed it.
Mar 18, 2012 | Dyson Vacuums
I need an instruction manual for a EUROLAB robot vacuum cleaner Auto Cleaner Intelligent Floor Vac please
I have a Eurolab and I can give you a couple of tips...
Spot = concentric circles from a start point and will continue for 4mins
Clean = will clean until battery runs out then go to base.
Max = will clean until battery runs out and then return to base, charge and go again.
If you interupt any of the settings you will need to manually return unit to charger (either by picking it up- or turning it off on the unit - then turning it on again while holding down "Max" on the unit). It will then find its way home. The two different settings on the seperate little room divider are about how big the doorway distance is ie 1 metre or 4-7 metres (somethinig like that) to prevent it going into a sep room. There is a little filter that needes to be cleaned 1 or twice a fortnight - just to help with suction. The auto settings on the charger unit should be self explainatory but I just set mine off in the morning while I am doing other things and haven't go around to setting it yet. I am very happy with mine and my floor has all of those loose bits gone. I empty the pod weekly.
You can't make it go back with the remote - or if you can it is not mentioned in the manual and I haven't worked it out yet.
I hope this helps.
Cheers
Brittany
Nov 22, 2011 | Vacuums
I just adopted a Bissell 1719 spot cleaner from my sister-in-law but they don't have the manuals. How do I change the battery? I don't see any removable clips, just screws in the unit housing
Good evening,
Please see the below link for the user guide/manual to this unit:
http://www.retrevo.com/support/Bissell-1719-Vacuums-manual/id/10659bh140/t/2/
This unit should include a charger for the battery. Below is the instructions on how to charge and maintain the battery.
If you need to actually replace the battery, the instructions below show the process:
Just a quick note, these units do come with a Ni-Cad battery, which should last you at least 5 years (closer to 6 or 7), and make sure that dispose/recycle the battery properly.
This can all be found in the manual (link provided at the top). I hope this helps, and please let me know if you need clarification. Please rate this solution!
Thanks,
~PCF
Mar 15, 2011 | Bissell 1719 Spot Lifter 2X® Handheld...
Battery does not seem to fit machine
the light only shows that its plugged in, it wont shut off when its fully charged
Jul 03, 2009 | Vacuums
Cordless vacuum WESTINGHOUSE WST1600A - problem with charger.
http://www.download-manual.com/shop/Westinghouse-c-145.html
Jan 29, 2008 | Westinghouse WST1600 Upright Vacuum
Scumbuster S600
According to B&D, the nicad battery can be replaced & disposed of at a DeWalt Factory Service Center; call ahead for battery availability. Also, for DIY folks, peruse the instruction manual at http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/90500564.pdf
Aug 08, 2007 | Black & Decker S500 ScumBuster Handheld...
Vacuums Logo
304 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
