Question about GE Profile Spectra JGBP90 Gas Kitchen Range
The oven will not light.. ge xl44 range/oven 10 years old...working fine until this morning...nothing known happened. Broil works. Range works. Has power. No gas from oven burner. oven igniter doesn't get hot. Any thoughts?
  • aw_wolfe12 Mar 23, 2011
    I haven't gotten an answer yet on if there is a way to test the ignitor and I am hesitant to spend the money on one without being sure. It would seem that the gas should still flow if the ignitor was bad, unless there was some sort of safety cut off or something (which is why I was asking). Please let me know if you find out anything...thanks.
    Master:
    Sergeant:
  • 385 Answers
More than likely you have a bad oven ignitor. It's not uncommon that they need repalced, they do go bad.
Posted on Mar 13, 2011
  • 2 more comments
  • aw_wolfe12 Mar 13, 2011
    Thanks for the response. Is there a way to test or be sure? Ohm meter reading or something? Also, is there some sort of safety on the oven that prevents the gas from flowing if the ignitor is bad? At $100, just hate to order a new one unless I'm 100% sure.
    Thanks,
  • Moon500 Mar 23, 2011
    I have the same problem. Oven does not work, all other things work fine. Were you able to solve your problem?
  • Tony Wisinski Mar 23, 2011
    Yes you should have continuity through the ignitor. If it's bad it will not have continuity. The main oven gas valve will not open to allow gas to flow if the ignitor is open.
  • StevenJosker
    StevenJosker Sep 03, 2011
    I Had the same issue... Bought a $75 dollar igniter and still no Oven... Turned out to be the Saftey Valve...BEFORE ANYONE INVESTS IN AN IGNITER. TEST CONTINUITY ON THE SAFTEY VALVE. Make sure you unplug the stove first and remove the wires from the saftey valve. Inside it there is a wire wrapped around a bar that must open when the wire heats. (One for each side) The Broiler and the Oven lugs should have continuity...(a dead short) If you Have continuity and 120V AC from the control panel wires (Yellow for oven and Blue for Broil) Its just the igniter... Saftey valve is part # WB19K14 Cheapest from Seneca River Trading out of NY... $80 plus shipping
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
Xl44 GE GAS RANGE OVEN WONT WORK, RED LIGHT IN
heatman101
czvb
May 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile gas range - Model Number removed by previous owners. Black slide in range with warming drawer - 5-10 years old. Digital oven controls on left side Broil and Bake functions are reversed. When...
Unplug the range.
I would open the control console and locate the BAKE/BROIL terminals on the Oven control. I would reverse the wires,plug the range in and try again.
Sounds to me like someone has changed out a part and wired it wrong.
Jan 03, 2010 | GE Kitchen Ranges
JBP26 Oven broil and bake do not work and the oven light is flash
If you have 240Volts to the range and BOTH elements don't work, it sounds like the L2 OUT relay on the oven control is bad. Bake and Broil share this line and this problem is not un-common. Make sure you have proper incoming voltage first. Turn breaker off and back on to make sure both poles are set.
Dec 15, 2008 | GE JBP24 QuickClean Electric Kitchen Range
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Oven not working after controller beeping
if ihe oven is not working. ck ihe igeniter in side ihe oven it trun red hot when you trun the oven on
Dec 31, 2007 | GE JGBP33 Gas Kitchen Range
GE XL44 Gas Stove
Hi I have a GE X44 gas stove. The 4 top burners work just fine, but the oven no longer turns on. I don't see the blue flame inside the oven. Is it safe to relight the pilot light?????
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
1,336 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
 Fix Your Board
Fix Your Board
Are you a Kitchen Range Expert? Answer questions, earn points and help others
