Question about Fossil AU4003 Wristwatch
Cannot figure out how to set the hour ahead. Nothing I do works. I have the Fossill dqb 1185.
I have a Fossill SpeedwayTitanium, the second hand doesn't work, i tried the fixya suggestion by pulling out winder and clicking the start stop button, with no sucess, it doesn't work
the module of your watch must be cleaned, bring it to watch service center, they have to see it and they really know what they are going to do with it.
Sep 09, 2011 | Watches
My casio g shock model GA-110C is 6 hours ahead no matter wat i do to it it will stay 6 hours ahead.im tryin to figure out how to fix this problem could u please help me?
It sounds like your watch is set to the wrong time zone. If you haven't got instructions, you can get them from their web site.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Apr 06, 2011 | Casio G-Shock GW300CA-1V Wrist Watch
My g-shock ga-110c-1a hour hand is 6 hours ahead. The digital time is correct but the hour hand is six hours ahead. If i set the time at 6:00pm the hour hand will move to 12:00. the minute hand is fine, i...
go to support page on casio. and get your manual. youll probably gonna look for a 3 or 4 digit number located at the back of your watch. once you got the manual. go to page 4. and follow the steps of "Hand Home Position Correction". that should fix it.
i also have ga 110c and i have encountered this issue
Dec 29, 2010 | Casio G-Shock GW300CA-1V Wrist Watch
The 24hr hand is meant to keep time in another
I too was confused at first at setting the second hand after reading the directions. I read your post in searching for a solution, then I figured it out. Check the watch face, the second hand is operating using military time. (24 hr. time) You will see 24 hour time embedded on the face.
For example: if you wanted to set both hands to be at the same time to test this. At say 10 p.m. set the second time hand to 22 for 2200 hrs. (10 p.m.) Let's say you woke up at 7 a.m. The second hand would be at 0700 (Embedded on watch face) then at noon it would say 1200 on the watch face... I now use the normal hands for local time and set the 24 hour hand for my home time.
I hope this helps.
Dec 30, 2009 | Invicta Watches
I cant find a battery for my Fossill Abacus Wristnet AU 4005
Hai,
It has a Powerful rechargeable Li-ion battery so there is no need to purchase extra battery kits!
Aug 25, 2009 | Fossil AU4003 Wristwatch
I have an analog Fossill logo watch from my company. I notice recently that when I set the watch down flat, it stops. When I pick it up, it works. If I leave it down all night, it will be 8 hours late...
I would check the battery first, but I am going to put the odds on that it is a mechanical problem with the watch. It's not like in the old days when watches had a mainspring, where the power from the coiled metal was strong enough to push out any particals that got in the way of the gears teeth. Now they are all quartz, where any little piece of anything will stop the gears from running. If you haven't had this watch along time send it back via warrenty, if not it needs to be serviced.
Jun 27, 2008 | Fossil Watches
How to set a nike triax watch
Press and hold in the mode button the seconds should start to flash.
Press top right button to select hour.
Press set button to advance hour.
Press top right button to select minutes.
Press set button to advance minutes.
Repeat this for the month/dte/dy/yr
Press mode button when done
Mar 09, 2008 | Watches
Watch has correct day and date only 1/2 each day
The watch thinks at Noon it is really midnite, so you must scroll 12 hours ahead to repair this. There are usually 2 "clicks" on the stem of the watch when you pull it out, 1 will set time, 1 will set the day/date, be careful to pay close attention to which is happening when you pull out the stem, and setting should go well after that.
Dec 01, 2007 | Watches
Fossill Man's wrist watch FS4252
go to fossil.com and click on custumer support that is where all the manuals are hope this helps
Nov 25, 2007 | Fossil ES9825 Wrist Watch
Fossil AU4003 Wristwatch Logo
Top Fossil Watches Experts
Jimmy Accardi
Lyle Siemens
Lyle Siemens
Are you a Fossil Watch Expert? Answer questions, earn points and help others
