Question about Creative Technology ZEN Vision M Digital Media Player
Successfully installed a replacement battery but when I had machine open, the small black rubber square (1cm) with a button indentation fell out from the on/off switch mechanism. I am having trouble knowing how it goes back as everything I have tried does not allow me to switch the machine on or off, or put on lock. Only by sliding the mechanism with a knife (with the top plastic cover removed) can I make the machine turn off. The only way to switch on is be plugging in the mains. Can anyone help me by illustrating how this rubber pice fixes in? Do I need to take out the four screws and insert it or can I do so with the top cover removed only? Cheers.
  • 16 more comments
  • cliffcobb Mar 15, 2011
    Hi, the first expert didn't actually help me in any way unfortunately - both two photos and a video failed to address the issue for me. Here's hoping now. The whole point for me is that there is a small square 2cm rubber piece with a 'button' formed in it that fell out of the machine when I opened it to successfully replace the battery. I have assumed it fits into the little rectangular (5cm long, white) plastic on/off piece at the bottom above the mechanism which, when pressed, switches on the machine. No matter which way I have tried to place this rubber piece, I cannot get the Zen to switch on or lock. Can you help me on how to fit the rubber square and make the machine switch on? All I can do at present is plug it into the mains which automatically brings the Zen into life, use it, and then open the top and with a knife slide the mechanism over to switch it off. Any help would be appreciated. Cliff
    Thanks very much as this is much more like what I need. However, I have never worked on a motherboard before and need more help here. I have the Zen disassembled down to the motherboard. I have fixed back the battery but I don't know "try to turn it on by pressing the 'on' switch directly on the board" There is nothing I can see which is an obvious 'on' switch. The blue light comes on at the top.
    I also have no idea how to 'try the lock function' on the motherboard.
    As I can't identify any 'on' switch it is not for me so easy to see how to 'fit the rubber there'. Which way round does it go and how does it fix on? The only thing I can see where it would fit over is something on the left of the motherboard two thirds up, but I guess the 'on' switch is at the top.
    Can you help further? Hopefully quickly as I have the pieces all over my desk! Thanks, Cliff
    Thanks very much as this is much more like what I need. However, I have never worked on a motherboard before and am struggling to identify the 'on' switch.
    I have it disassembled and fitted back the battery. I get a blue light at the top but can't identify an 'on' switch to test, nor a lock function to test. What am I looking for?
    Clearly, I can't fit the rubber piece onto something I cannot recognise. I am not sure I would automatically know which way round it goes to fit on.
    Can you tell me what I am looking for and where on the motherboard?
    Thanks, Cliff
    Hi, I have no way of knowing if my words are getting through to you? I don't know if there is a problem sending or not as I am having connection problems. I will send it one more time and see if anything shows me it has gone.
  • cliffcobb Mar 17, 2011
    Hi, any idea when I might hear back from you? I need to know exactly where 1. the on switch is on the motherboard 2. where the lock is and how to try it out 3. how exactly to fit the rubber piece? I can't see how it fits anywhere and how it functions.If you don't know, please say and I will keep trying to ask elsewhere. Cheers, Cliff
  • cliffcobb Mar 19, 2011
    Hi, got a message four days ago and have the Zen in pieces. Do I need to still or wait or shall I try another 'expert'? Just say if you don't know where the rubber goes. Cheers, Cliff
  • cliffcobb Mar 21, 2011
    Hi, now 6 days - should I still be hanging on for you? Thanks Cliff
  • cliffcobb Mar 22, 2011
    I have my Creative Zen Vision M openned up to the motherboard (though not detached it as yet) and need to know how to place a square black rubber piece (1cm long, 8mm wide with a rubber button shape) onto any switching on mechanism. I had changed the battery and this fell out. I now can't switch on or put on hold. I don't really know what is the 'on' or 'hold' function on the motherboard (I am a complete novice at this) and would welcome someone giving clear instructions where it goes so I can put the machine together and start using it. The 'on' function works fine if connected to the mains.
    Hi, thanks for this but it is precisely "fix the rubber piece or replace it properly" that I don't know how to do. Where does it go and how do I fix it? I can't work out where it actually goes before I put the machine back together. Cheers, Cliff
    Also, the manual doesn't tell me anything on how to replace this rubber piece.
  • cliffcobb Mar 23, 2011
    I am still trying to locate an expert who has actually taken a Creative Zen Vision M apart and can answer me the simple question of where the small (2cm x 3cm black with button area) rubber piece goes inside. It is clearly to do with the start/lock mechanism as it will neither start nor lock now. I was taking out the battery for replacement when it fell out. I am not an expert at motherboards so you will need to give clear instructions of where it goes. Thanks a lot.
  • cliffcobb Mar 24, 2011
    Hi, thanks for reply. Definitely no springs as I was opening the machine on a towel and the rubber piece was the only thing that dislodged while I was handling it.
    The crucial thing I need to know if what you don't quite say, assuming you are familiar with the Zen Vision M?
    To fix the small black square rubber is by taking out the four screws and ensuring the rubber sits well with the indented part facing down. I have the four screws taken out and the motherboard exposed. So where do I ensure the rubber sits well? Is it at the top? Is it on the front? Is there a clear place where it goes? This is precisely what I need to know - where is the exact location of the rubber piece before I put it back together? Have you had one opened? Thanks a lot. Cliff
    Hi, thanks but that video shows me nothing about that black rubber piece. I have watched in many times carefully but I can't see that piece anywhere. Cliff
    Hi, you actually pointed me to pics and text rather than the videos on that site. On the step 3 final picture, do you think that is the rubber piece on the left? Have you taken apart a Zen Vision M? Cliff
    Hi, I am completely and totally in the same situation I was two weeks ago. I try to fit the rubber piece on top of the on/off slider and then place the piece on top which has a bit to show the light and the rest has two prongs down which goes into the rubber thing. When I assemble the top thing, this arrangement will not press hard enough on the on/off switch to make it work. All I can do to work the machine is take all those pieces off, insert a cutting knife into the on/off switch to slide it along and then the machine works. I have to do the same to stop the machine. It seems to me now that I can't find anyone who has seen the inside of this machine and let me know where I am going wrong. I guess I just throw the whole thing away now. Before I replaced the battery, I could work the on/off switch with main power plugged in. It was only when I bought and replaced the battery that this rubber piece alone fell onto the towel I had out. Since then I cannot work out the way it actually fits into the machine to give the pressure needed to switch it on or off. Do you agree the machine has had it? Just a shame because it is fine in use. Cheers.
  • cliffcobb Mar 25, 2011
    Hi, one last try to find an expert who has taken apart a Creative Zen Vision M before I throw the machine away. It works perfectly after I fitted a new battery but a little rubber rectangle (3mm by 1cm)fell out. Now the power on switch and lock do not work (previously working fine as I could use the machine on mains). Now the only way I can turn the machine off is take off the top cover and a bit of plastic, put a knife in to slide the switch off. I have to do the same to switch on or just plug into mains and it comes on automatically. I have tried a number of experts here but they try to answer without giving me a clear understanding on how to fit this bit of rubber. If the bit of plastic at the top should fit into this rubber and rest on the power switch, any way I try to fit it does not allow pressing that plastic to switch on the machine. The power switch is on the edge of the motherboard and flush with it, so I am not sure whether the switch itself has become indented or faulty. I have tried for weeks now and have got nowhere. It is frustrating as the switch was fine and it was easy to replace the battery. This one lose piece makes the machine useless. I can't sell it or give it away like this, so it will be thrown away unless some kind soul knows what to do. Thanks, Cliff
    No way the LCD screen is anything to do with it.
  • 3,018 Answers
What fell out was your switch. That little indentation you speak of is what activates certain functions of your media player depending on the switches position. If you are handy enough you can replace the switch where it goes. You have to open your media player up. So you will want to do this on a table with some space. Use a thin towel or something else similar to work on so you don't scratch the face of your media player. Let's get started.
  1. Move the setting on the MP3 (where the switch will go) to all the way on one side or the other. This will take the guess work out of placement of the switch.
  2. Remove the screws on the back.
  3. Now you have to remove a couple more screws to get the front off. Now when you open this media player you are just going to set this with in it's spot so don't pull the front all the way off. Just enough to get the switch where it needs to be.
  4. Set the switch on the its track according to the position the switch on your media player is at.
  5. Set the front panel down and make sure everything lines up.
  6. Carefully reverse above procedure.
  7. Your media player should be back to normal.
Regards, Tony
Posted on Mar 25, 2011
    President:
  • 739 Answers
Hi.
these things usually happen because of problems lcd screen.
If your problem just happened after you make repairs to the hardware, it is probable technical error, try to loosen the back of what you have done and make the installation more carefully. Normally, if the error during installation, it will return to normalcy after the installation is back to normal.
regards
    President:
  • 2,047 Answers
Power buttons are quite a delicate part to tamper with as they are usually very sensitive and little misguidiance could spoil the power function. To fix the small black square rubber is by taking out the four screws and ensuring the rubber sits well with the indented part facing down.Also most power button systems have springs chech if your unit has a space to accomodate springs then get replacement springs for the button as most likely the spring would have fallen off.
Hope this solution has been helpful?
Posted on Mar 23, 2011
  • 1 more comment
  • Rockme
    Rockme Mar 24, 2011
    Thanks for your feed back. I mixed up the unit you were refering to with a different unit. Here is a link to completely guide you in the assembly of the Yen Vision M as well as give an insight to help you re-assemble it.http://anythingbutipod.com/2006/02/how-t...
    Hope this has been helpful?
  • Rockme
    Rockme Mar 24, 2011
    There is more than one back rubber inside the unit. Some of them are used to support the HDD from making continous contact with the main board and the screen while the other one goes under the top screw coverng where the power button is supposed to be slid from. It is meant to support the decorative cover from depression.
  • Rockme
    Rockme Mar 24, 2011
    Sorry but instead of throwing of the unit i would advice you just refer it to an expert to help couple it back. instead of throwing the unit away as you have come a long way.
    Guru:
  • 1,833 Answers
According to your problem it may occurs for on/off switch. Don't worry It is not a big problem. If you sure it is the problem of on/off switch then you can try to fix the rubber piece. To do so just open the screws and take out the front panel of the player very carefully. fix the rubber piece or replace it properly. It may solve your problem but before that make sure the replaced battery is OK and the wires and circuits of the battery or player is not faulty. To do so you can take help from manual.
Posted on Mar 22, 2011
  • 6,993 Answers
First, you will need to disassemble the player completely in order to fix the rubber firmly to it's rightful position.
Make sure the player is turned of. Get a screw driver that can fit into the screws of the player, remove the battery, and proceed in disassembling the player.
After it has be disassembled, fix back the battery into it, then try to turn it on by pressing the "on" (switch) directly on the board without the on rubber piece. This will enable you know if actually the "on" is working. You can also try the lock function. After that,you can now fix the rubber.
Look at the case of the zen player, I mean the position if the 'On', you will see where the rubber will fit. Place the rubber there, then carefully assemble the zen with the rubber getting of. This clip the rubber firmly to its correction position and is shouldn't fall off.
You can now screw the case back together and it should be done.
I hope you understand what I am trying to say............
I wish you good luck...
Posted on Mar 15, 2011
  • Walesarumi
    Walesarumi Mar 15, 2011
    yes, I can see your message. I wasn't online all this well. Please give me some time to look into your problem. I will get back to you....... Thank you.
    President:
  • 1,961 Answers
I believe the rubber you are describing is the slide switch control for the on/off button
here is the illustration:
for a more comprehensive explanation watch this video.
good luck!
and please do accept my solution if this help you.
Thanks for consulting Fixya.
Posted on Mar 13, 2011
Ice maker shutoff bar fell off
This arm is called a "bale". There should be a small, round opening on the backside of the front of the ice maker. Use a mirror to look behind the square control box of the icemaker and you should see the opening. It is impossible to see it from the front when the icemaker is installed in the unit.
Oct 10, 2014 | Kenmore Refrigerators
Why does the remote unable to turn tv off and on?
Same thing happened to me... Was ready to purchase a new remote and decided to take remote apart first and see if it could be fixed: In battery compartment, remove small screw. With small flat precision screw driver separate the black from grey part of remote starting with the larger side of remote (do not force open anything!). Then do the same from the other side of the remote, moving slowly (without forcing) towards the middle of the remote, prying open both sides of the remote delicately. Finally, from battery side, push down on battery springs which should allow you to take remote apart completely. Remove small black rubber washer holding motherboard, allowing removal of motherboard completely.
With a dry cloth gently wipe motherboard down. Clean the rest of the remote (NOT motherboard) with warm water and soap. (After a few years, inside remote accumulates sweat and dirt ! Use paper towel to dry inside part of remote first as best as possible. Finish by blow drying thoroughly every part that was washed with soap and water. Wipe down again the motherboard removing all type of humidity and possible greasy layer that may have accumulated through the years. Put remote back together by snapping every part back in place (much easier than taking apart). Don't forget to insert black square part, black rubber washer and little screw in battery compartment. Once this is done, make sure bottom black switch of remote is pushed to desired position (TV for me). Your remote should work properly, on/off button should also work properly. Don't forget TV has 2 setting for On/off switch, one normal the other something like "power saving" which requires user to press on/off button for a few seconds. This definitely worked for me, hope this works for you :)
Jun 11, 2014 | Toshiba Ct-90275 Remote Control
Watch battery size
mcdevito75 here, Best Bet For correct Battery Number is to call Kenneth Cole T 1-800-KenCole / 536-2653
Jul 01, 2010 | Kenneth Cole KC1346 Watch for Men
How do you remove battery in remote
On some models the label covers a small phillips screw that holds the two parts of the case together. You can usually fell the indent and then scrape part of the label away.
Oct 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
2 small rubber pieces have fallen out. any idea
Those pieces go on the clean station and can easily be replaced. They each fit over a stud where the printhead parks and just press on.When they are missing the ink will dry out on your ink cartridges and the machine won't be able to clean them properly.
Jul 24, 2009 | HP Officejet 5610 All-In-One InkJet...
Telmann washing machine TEL6TL
Telemann TEL6tl E2 Problem
E2 on screen means the lid is not closing properly and thus not activating the (hidden) switch that prevents the machine from spinning while the lid is up.
The lid switch in this model is not a direct contact switch between lid and switch , but it switches on and off due to a MAGNET embedded in the lid on the left hand side near the front. You will see a small indentation where the magnet SHOULD BE. My magnet had fallen off, so the lid could not activate the operation switch. I had lost the original magnet( about 1cm X 2cm) so glued another into place.
Machine is now fully operational again, and the job cost .78c.
If your magnet is still in place, the E2 fault could lay with the switch itself , which is fixed to the underside of the top casing of the machine near the front right hand side of the lid cavity. The switch measures 1cm X 3cm heavily black tape insulated. Access is gained by popping the 2 X2cm discs at front top of machine and releasing the 2 small philips screws here and a further 2 at the back top of machine. This operation of replacing the switch is best left to an electrician or washing machine specialist.
Hope that helps
Apostle95
Nov 01, 2008 | Dishwashers
Power Button does not push in and out
http://www.richspsxparts.com tells you how to disassemble the game console and replace the old switch this also sells new switches
Jan 21, 2008 | Sony PlayStation 2 (PS2) Console
On / off
I suggest you to take out the remote control batteries to discard that as the problem.
Try working the TV without remote controller to see all the functions working and if everything works ok without the remote then you may have a broken remote controller.
As I can conclude with your pretty small description, you may have some remote buttons stuck and maybe humidity or plain fluids into the remote controller circuits causing false button activations in buttons like the ON/OFF, or PIP, or RECALL.
You can try open the remote and clean any dirt and humidity inside, specially taking care of the rubber buttons pad and its black touch pads behind each button. also the circuit board and the golden/black threads where the pads touch the board.
Also if you note a broken battery, clean any battery fluids inside the remote as these liquids are very corrosive for the circuits.
Good Luck...
Oct 17, 2007 | RCA F32632SB 32" TV
Creative Technology ZEN Vision M   Digital Media Player Logo
124 people viewed this question
Top Creative Technology Audio Players & Recorders Experts
Jim Y
Jim Y
elvis nunex
Level 1 Expert
Tom Chichester
Are you a Creative Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
