Question about Car Audio & Video
My travelpilot ex has stopped functioning correctly. Although it is working to a point, the voice is saying that im not on a digitised road although i am on a major road every time, and as a resuly will not begin the navigation process??? i have tried the calibration option within the extras section but cant seem to get it working
SOURCE: Display dies, although phone still functional
My razr V3 dropped from an astonishing 40cm to the floor, after that both screens stopped working. I opened the screen by removing the four tiny screws in each corner (t5 screwdriver which I didn't have but the smallest of my miniature screwdriver set just fitted), and popping it up carefully. There a two flatcables, one with a silvery color and a connector with a black piece of foam on it. I think it's the screen signal carrying cable. I removed it and put it back in place, pushing it firmly. After that the screens worked again. 10 minutes of work and a great deal of satisfaction. Further, the phone stinks. regards, El Rudo
Posted on Feb 12, 2007
SOURCE: Roomba discovery stop working
Try spraying a compressed air can (computer cleaner) under the brush compartment (under the yellow housing). There are sensors and other wires underneath.
Posted on Oct 12, 2008
SOURCE: ipod
tran nam bac
Posted on Dec 08, 2008
SOURCE: My SE G900 has got a touchscreen problem now after
Alright, i know this is old, but i hope i can help those guys/gals, i recently bought the phone and i had this problem too, i dont know if it will work, but its worth a try, when i tried everything, i started losing hope, but i tried knocking the phone on something soft like a towel or the bed mattress, then it works wonderously, and i heard some people accidentally dropped their phone on the ground etc, and it works like normal again... although i would never recommend dropping the phone on hard surfaces, just try knocking on your bed mattress (do not EVER knock on the metal area, im not responsible for any damages), or put a towel on your lap and knock it few times with the screen face down (of course, just knock slowly, dont put too much pressure...) hope this helps!, and sorry for the long phrase of boringness!
Posted on Mar 11, 2010
SOURCE: instuction manual for blaupunkt travelpilot ex
http://fordfcsd.wunderman.be/UK/Audio%20-%20Multimedia%20-%20Navigation/Travel%20Pilot%20DX%20-%20EX/travel%20pilot%20dx-ex%20%28cg3507en%29%2009-2005.pdf
see link above for manual...sorry i was searching ad fell upomn it...well i just saw ur post its 2011 now!- lol
Posted on Jan 07, 2011
Although headset is paired successfully with phone I cannot use voice dialing commands.
You can try to press and hold the Call button while turning on
the headset to turn these features on/off and select reset to factory default and just follow the voice prompts to make changes to
these settings. Remember that this action erases all pairing information stored in your headset so you will have to paired again.
Jun 29, 2014 | Motorola Mobility H19txt Universal...
I can hear on it but not many can hear me. they say it sounds as though im on the wrong channel
Have your SWR's checked. Free at most shops. it will make it should bad if they are high. although you may be able to hear. if they are high your RX will improve also..once its corrected. other problem could be its been bounced around/vibrations can cause the verticle boards to come loose on those models, and can effect either "IF" function, TX functions or RX functions... or all if they are all 3 loose.. if need more help just ask
Dec 10, 2011 | Cobra 19 Ultra II CB Radio
My 93 EX 500 bogs at 5k rpm
Hello you have a heavily rusted fuel tank, i would suspect the fuel petcock is being restricted.
As for the fuel tank here is a link to a product to remove the rust from your tank.
I have used it and it gets rid of it excelent product.
http://www.kreemproducts.net/p-16-kreem-tank-prep.aspx
May 25, 2010 | 1993 kawasaki KLE 500
Cd changer wont play
All radio accesories are on what is called a d2b ring. This ring consists of your c.d. player,telephone t.r.u. and voice activation module. On some vehicles the factory amplifier and tele aide modules are on this loop. If you have aphone see if it works. I do not think your amp is part of this ring although benz started incorporating the amp. in 2000 model years. The way this system works is that the head unit sends a wake up signal and verifies that these components work. Each components is in series and the last one in the loop sends the signal back to the head unit. It is easy to determine if you have a problem in your d2b ring if none of these components work. Although the head unit reads no changer I would make sure all of the c.d.s are installed correctly. You can also try and remove the unit and there should be areset button you can push in with a ball point pen at the base of the unit.
Jun 26, 2009 | 2000 Mercedes-Benz CLK
1999 Kia Sephia a/c compressor usally will not come on unless i blow the horn. As soon as i blow it i hear the freon hissing through the lines and in about 3 seconds i have freezing cold air. When im going...
saw the EX ,now i think you will have to do something although i cant for the life of me work out why this should be like this ,blow the horn and it ac comes on ??or the vibration of the horn is causing a switch on the AC to come on or a dirty connection in a multiplug close to the horn .Really would need car in front of me to find this fault
Jun 21, 2009 | 1999 Kia Sephia
Olympus vn-4100pc
To record a telephone conversation without warning the parties involved, is not lawful.
Jun 24, 2017 | Olympus VN-4100PC Digital Voice Recorder
Nokia 6110 navigator
when i press the navigate button it searches for a few seconds and then it stops and says "street not digitised". the phone's navigator worked until friday then it stopped. i don't know if someone maybe played with my phone and changed my settings. please any one?
Aug 24, 2008 | Nokia 6110 Cellular Phone
Nuvi 350 - How do you get it to say the name of the street?
You have to select one of the "TTS" voices (TTS stands for text to speech). These are the voices capable of saying the street names (although the mispronunciations are often amusing)
Nov 29, 2007 | Garmin nuvi 350 GPS Receiver
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
