Question about Acer Computers & Internet
My monitor. Does not come on - Acer Computers & Internet
  • 93 Answers
Try unplug all wires and check your power supply. Then reconnect the cables and try again. If that doesn't work then try changing the power cable. If that's also fail then take the monitor to service center.
Posted on Mar 13, 2011
PC SWITCHS ON BUT NO PICTURE
1. Check to make sure your monitor is on! Some monitors have more than one power button or switch - check to make sure they're all switched on.Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable.Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.Note: A disconnected monitor data cable could be the cause of your problem if your monitor's power light is on but is amber or yellow instead of green.Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.Note: Most monitors today have a single onscreen interface for all settings, including brightness and contrast. If it turns out that your monitor isn't working at all then you'll likely not have access to this interface. An older monitor might have manual knobs for adjusting these settings.Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.If the new monitor you connected does not show anything either, proceed to Step 6.If the new monitor you connected does show information from your computer, proceed to Step 7.Important: When testing with the new monitor, make sure you use the data cable that came with it and not the one from your original monitor.Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.Chances are your original monitor is working fine.Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.Note: If possible, test using the data cable from the monitor that you successfully tested with in Step 5. If not, purchase a replacement monitor data cable to test with.Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8 Replace the monitor.
Sep 27, 2011 | Mesh Matrix 6000+ DX PC Desktop
What is the m button for
Hope this helps you out
Sep 19, 2011 | Health & Beauty
My pc does not give display ? Why
Time Required: Testing a monitor could take from a few minutes to much longer depending on the cause of the problem Here's How:
  2. Check for disconnected monitor power cable connections. Your monitor might be working fine and your only problem may be a loose or unplugged monitor power cable. Note: A disconnected monitor power cable could be the cause of your problem if your monitor's power light is completely off.
  3. Check for disconnected monitor data cable connections. Again, your monitor might be turning on without a problem but no information can get to it because the cable that connects your monitor to your computer is disconnected or loose.
  4. Turn the monitor's brightness and contrast settings completely up. Your monitor might be showing information but you just can't see it because these display settings are too dark.
  5. Test that your computer is working correctly by connecting a different monitor that you are certain is working properly to your PC. Your monitor may be working fine but your computer might not be sending information to it.
    • If the new monitor you connected does not show anything either, proceed to Step 6.
    • If the new monitor you connected does show information from your computer, proceed to Step 7.
  6. Determine why your computer isn't sending information to your monitor. Since neither monitor works, you now know that the computer is not sending information to the monitor. In other words, you've proven that your computer is the reason that nothing shows up on your monitor.
  7. Test your original monitor with a monitor data cable that you know is working. It's possible that the monitor itself is working properly but it can't receive information from the computer because the cable that connects the monitor to the PC is no longer working.
    Note: The data cable on some older monitors are permanently connected to the monitor and are not replaceable. In these cases, you'll have to skip this step and proceed to Step 8.
  8. Replace the monitor.
    WARNING: A computer monitor is not a user serviceable device. In other words - do not open the monitor and attempt to repair it yourself. If you would rather have your dead monitor serviced instead of replaced then please let a professional do it.
Aug 02, 2010 | Dell Dimension 2400 PC Desktop
E176FP 17" LCD Monitor: my computer will come on but the monitor won't...
Here is what you need to do to know if your monitor is defective. Plug the power cord of the monitor. Turn on the monitor. If the monitor display image for a second and then black out then the monitor is OK. If not you will need to replace it.
If the monitor is OK.. look for other possible problem. Next to it aside from checking the cable (connecting your video card to the monitor) the one to check is the video card.. the signal from the cpu will pass through the video card to your monitor. If no reaction to the monitor then its the video card.
May 18, 2010 | Dell E176FP 17" LCD Monitor
So I hooked this moniter up to my hp and all I get is two blinking lights
One monitor serves as the primary monitor, and this monitor displays the Logon dialog box when you start your computer. In addition, most programs will display windows on the primary monitor when you initially open them. You can select different screen resolutions and different color quality settings for each monitor. Multiple monitors can be connected to individual video adapters or to a single video adapter that supports multiple outputs. To configure the arrangement of multiple monitors:
  1. Click Start, and then click Control Panel.
  2. Click Appearance and Themes, and then click Display.
  3. On the Settings tab, click Identify to display a large number on each of your monitors. This shows which monitor corresponds with each icon.
  4. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply to view changes.
NOTE: The icon positions determine how you move items from one monitor to another. For example, if you are using two monitors and you want to move items from one monitor to the other by dragging left and right, place the icons side by side. To move items between monitors by dragging up and down, place the icons one above the other. The icon positions do not have to correspond to the physical positions of the monitors. You can place the icons one above the other even though your monitors are side by side.
Change Primary Monitor
  1. On the Settings tab of the Display Properties dialog box, click the monitor icon that represents the monitor you want to designate as the primary monitor.
  2. Click to select the Use this device as the primary monitor check box. Note that this check box is unavailable when you select the monitor icon that is currently set as your primary monitor.
View Same Desktop in Multiple Monitors
  1. On the Settings tab of the Display Properties dialog box, click the monitor icon that represents the monitor you want to use in addition to your primary monitor.
  2. Click to select the Extend my Windows desktop onto this monitor check box. After you enable this feature, you can drag items across your screen onto alternate monitors. Or, you can resize a window to stretch it across more than one monitor.
Move Items Between Monitors
  1. On the Settings tab of the Display Properties dialog box, click Identify to display a large number on each of your monitors. This shows which monitor corresponds with each icon.
  2. Click the monitor icons and drag them to positions that represent how you want to move items from one monitor to another, and then click OK or Apply.
  3. Drag an item on your desktop across your screen until it appears on the alternate monitor. Or, you can resize a window to stretch it across more than one monitor.
Using DualviewOn many portable computers and some desktop computers (those with two video ports on one video card), you can expand your display to a second monitor by using Dualview. Dualview is very similar to the multiple monitor feature, with the exception that you cannot select the primary display. On a portable computer, the primary monitor is always the LCD display screen. On a desktop computer, it is the monitor that is attached to the first video out port. Once you attach the second monitor and turn on your computer, use the Display tool in Control Panel to configure your settings, just as you do with multiple monitors. You can use Dualview with docked or undocked portable computers.
Mar 08, 2010 | HP A4331D 20" CRT Monitor
Monitor stand screws
More likely to be metric M4 screws, 1/2" will more likely to be long enough.
Feb 23, 2010 | Acer AL2423W LCD Monitor
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    Dual monitor setup
    Assuming you are using Windows Vista:
    All you have to do is connect your laptop to a monitor via a VGA port (located on either the side or at the back of your laptop - it's the port with about 15 holes).
    Once connected , you will need to configure how your 2nd monitor will function - as an extended or duplicate monitor. To set this you will need to go to Display Settings > and select your option.
    Sep 28, 2008 | Compaq Presario 700 470024-192 Notebook
    Dell e193fp monitor
    Have you made sure the laptop is outputting the the monitor? Does the monitor have dual inputs? if so check it is switched to the correct one. With the laptop turned on and connected, switch the monitor on and off.
    good luck
    fridge
    May 17, 2008 | Dell E193FP 19" LCD Monitor
    HP desktop monitor problem
    hi try this ,,,
    1. Ensure the video cable is connected (and connected to the correct video port).
    2. Turn off the monitor using the monitor's power button and then restart the monitor.
    3. Cycle the power on the monitor as follows:
    4. Turn off the monitor. The power light on the monitor should be off. Leave the computer turned on.
    5. Unplug the power cord.
    6. Wait 5 seconds.
    7. Plug in the power cord.
    8. Press the power button on the monitor to turn on the monitor. One of two things happens:
      1. The image from the computer displays on the monitor and you can use the computer again. This indicates that the monitor was unable to detect that the computer had awakened from suspend mode. Turn the monitor off when it is not being used or disable suspend mode. For some computers, updating the BIOS corrects these types of suspend problems.
      2. The power light on the monitor comes on but the screen displays one of the messages again. The monitor is not receiving a video signal from the computer that it can detect and use. Continue using these steps to adjust the Windows display resolution to the Monitor's native (default) resolution
      3. Connect the monitor to another computer that you know is working to determine if the monitor should be serviced or replaced:
        • If the monitor displays an image from another computer, you know that the monitor works. Troubleshoot the video connection and graphics adapter on the computer.
        • If the monitor remain blank when connected to another computer, the monitor signal processing hardware may be bad. The monitor should be repaired or replaced.
        hope it will work for u .. little_angel
    Apr 30, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
    Computers & Internet Logo
    49 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
    Alun Cox
