Question about Jura Capresso Impressa S9 Coffee Maker/Espresso Machine
My Impressa S9A is stuck in 'Empty Tray". After making one cup of coffee this morning the "Empty Tray" display came on. I removed the tray, cleaned it, as usual, and replaced it. The "Empty Tray" display persists. Also, I noted that when the tray was removed for cleaning it did not indicate "Tray Missing". I've cleaned the contacts on the tray ( I always make sure they are clean and dry when I remove the tray), but the display will not clear and the S9A will not brew. What do I need to do to get my S9 out of the "Empty Tray" state? I've tried everything I could think of: turned power off then on; unplugged unit - let sit for 10 minutes, then plugged in again; thorough cleaning of tray and internal parts I can see; ensure contacts on tray are clean. Any suggestions?
SOURCE: jura impressa s9
A hose has popped off inside the unit.   It is probably due to calcification (waiting too long between cleanings), or using too much powder (more than 2 tbsp) on the manual powder function.
Posted on Mar 01, 2008
  • 2039 Answers
SOURCE: Coffee takes forever to brew
normally when that hapen is the coffee is grinded to fine water has trouble filtering thrue it try corser one and coffee filter pierre
Posted on Feb 14, 2009
SOURCE: Keurig machine releasing coffee grounds on top of K cups
I have the same problem but if you take a paper towel and clean the grounds from the top each time it helps. Cleaning around the little point that pierces the cup. It helps but doesn't completely eliminate the problem.
Posted on May 19, 2009
SOURCE: delayed brewing
The problem is in the sensor that tells the coffee maker when the brew cycle is complete. This is a heat sensor that's clipped to the heating element. The sensor gets overly sensitive and shuts things off too soon. Since schematics and parts aren't available for this unit, it's pretty much junk after it starts to fail. You can remove the sensor, but this creates a major fire hazard. My advice is to pick up a good percolator and forget the drip units. The Grind-N-Brew makes excellent coffee, but they barely last out the warranty and the cost of replacing them mounts up. I've gone through two (same problem with both) and it's no longer worth it to me.
Posted on Jul 26, 2009
  • 4 Answers
SOURCE: Tray empty message
If the machine says TRAY MISSING it's the contacts at the back so clean as other people have stated, you can also use a cardboard nail file to clean the contacts at the back if there really skanky!.
If the machine keeps saying EMPTY GROUNDS even though you have, pull out the tray, look just inside the aparture where the tray goes top right at the front there is a small slot where if you look closely you can see a small white micro switch. This will be probably gunged up with coffee and the switch will be stuck up, get a can of WD40 and squirt a small amount up into the switch then poke the switch with a small screwdriver up and down until it moves smoothly.
Then replace all the bits, sit down, look smug and have a coffee cos you've fixed it!! :0)
Posted on Oct 13, 2009
How to reset descale function on Capresso coffee maker
follow this steps and fix it. God bless you
    • 1 Unplug the coffee machine and remove the cup.
    • 2 Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
    • 3 Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
    • 4 Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
    • 5 Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
    • 6 Unplug the machine and dump the water into the sink.
    • 7 Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue.
Oct 15, 2012 | Capresso Jura-Impressa C 9 One Touch...
I just went thru the entire decalcifying process and got to the final step, emptied the drip tray and coffee grounds bin, put the tray back into place, but can't get the display off of "empty...
You should Clean and dry the metal contacts on the back of the drip tray, ensuring that the gap between the contacts is clean and dry (if present, contacts not on all JURA models) Make sure that the plastic in between the contacts is clean
Sep 13, 2011 | Microwave Ovens
MY Coffee machine continues to say "Empty Tray". I
try taking the tray out and leaving it out for like 2 hours with the machine still in the on position. mine has done this before, when i reinsert the tray it will go back to select coffee on the menu. FYI - there is like a built in timer for the tray removal - I believe it will tell you what the timing is in the booklet - howver it works best to do what is stated above.
Mar 05, 2011 | Jura Capresso IMPRESSA S9 Coffee Maker
I was going through the decalcifying process and the message "empty tray" displayed (Jura Compresso Impressa S8). I removed the tray, cleaned it, replaced it, but the message remains as "empty tray" and I...
I had the same problem and had success with cleaning the contacts in the back of the machine with a small nail file/emery board. I found that the contacts that are inside the machine had a little calisification on them. Once they were cleaned up no problem.
Aug 15, 2010 | Jura Capresso Impressa S8 Coffee Maker,...
Impressa z5 grounds empty will not reset even though the tray has been empty and the contacts cleaned
Oct 13, 2009 | Jura Capresso Impressa S9 Coffee...
I have a Jura S9A that is about 2 years old, brewed about 1600 cups. Regular filter changes/cleanings. When I brew a coffee, it dribbles out, but makes a full cup of coffee. It also has trouble getting a...
It's all plugged with 'lime scale'. That's the white stuff that builds up from hard water. Regular vinegar run through at least two cycles will clear it, then a couple with fresh water to rinse it. That will bring it back to normal flow!
Oct 10, 2009 | Jura Capresso Impressa S9 Coffee...
Impressa E8: even though I did clean machine, it asks me again...
Make sure your water tank to fill, when you start the clean process, and the tray is empty and wiped down. Then add a 500ml container under the spout rather than let the water go into the tray.
Also if you have not serviced the machine for about 5,000 cups this can occur.
Mar 23, 2009 | Jura Capresso Impressa Z5 Espresso/Coffee...
Tray empty message
Nov 15, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Jura Capresso Impressa S9 Coffee Maker/Espresso Machine Logo
155 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
