Question about Miele Vacuums
Miele vacuum cleaner keeps overheating and shutting off. It is only possible to use for about fifteen minutes at a time
Hi Lauren, how do you know if it is the circuit board? (the speed control buttons still work).
Posted on Jul 02, 2015
micromatikal
  • 2777 Answers
SOURCE: Instruction required for the removal of a full
Sure thing, the best thing to do is to have a look at the manual I have found here for you. The part you are looking for is on page 25 of the manual, complete with pictures and everything.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Here is the manual:
http://www.miele.co.uk/Resources/OperatingInstructions/S%205211_5781.pdf
Posted on Oct 15, 2010
Testimonial: "Thank you very much,we have missplaced our operating manual so this is just what we require,again our thanks"
reddevil6
  • 1673 Answers
SOURCE: My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Posted on Mar 22, 2008
reddevil6
  • 1673 Answers
SOURCE: Miele Vacuum Cleaner
S718 doesn't come up in the Meile parts list, there is a S518, some possibles to check: The switch part #04367102, Indictor lite w/pot. # 05482010, Reel cord 05240302, and motor electronic control # 05408620. Any one of these could be giving you the problem you describe. You will have to dive in and starting with the switch, and eliminate which ever parts seem ok. The reel cord could have bad internal contacts, I have had the pots go bad, but the electronic control more ofter. Which I could pin point it for you.
Posted on Jan 18, 2008
tooltech75
  • 80 Answers
SOURCE: Miele 5000 vacuum cleaner stopped during use. no lights on
could be your retractable cord assembly's contacts..
push the power on while pulling out the cord. see if it tries to start.
Posted on Oct 07, 2009
SOURCE: Miele s571 vacuum cleaner power surges up and down
I just repaired the same problem. It is not the motor. There is a defective capacitor in the regulator. Large grey capacitor should have a value of 0.22uF/275V. It was in my case just 85uF. Changed capaitor and it was OK.
Posted on Feb 08, 2010
Where is the fuse located on a dirt buster vacuum cleaner?
Black & Decker Dirtbuster Vacuum Cleaner
no fuses in these ....double insulated
the motor has a thermal protection shut off when overheating
will start again when cooled down
empty bag often
if unit keeps shutting down replace vacuum
2477301-black-and-decker-dirtbuster-vacuum-cleaner-0-bwbjq1d2inqbxh534mfqkm1n-3-0.jpg
Apr 29, 2017 | Vacuums
Tip
Miele vacuum cleaner suddenly stops
So this is a problem I identified in Miele's mid size ranged canister cleaners. Not only the S318...
If you go about cleaning on the highest power setting the engine will overheat after 5-10 minutes. It then will need around 20-30 minutes to cool down before you can use it again.
Tip: Don't run the machine on 100% power, instead turn the setting to around 80-90% and then you can enjoy good suction un-interrupted.
on Jan 28, 2010 | Miele S318 Bagged Canister Vacuum
Reset switch
There is no reset button it as a Thermal Cut Off
This vacuum cleaner has a special thermostat that protects the cleaner in case of motor overheating. If the cleaner suddenly
shuts off, turn the switch off and unplug the cleaner.
Check the cleaner for a possible source of overheating such as a blocked hose or clogged filters. If these conditions are found, fix
them and wait at least 30 minutes before attempting to use the cleaner. After the 30-minute period, plug the cleaner back in and
turn on the switch. If the cleaner still does not run, then call 1-800-282-2886 for customer assistance
this link below is the manual
http://dl.owneriq.net/b/b7517422-db37-404e-9da2-d898185942e5.pdf
Sep 05, 2013 | Eureka 4700A Maxima Bagless Upright Vacuum
Popped the lid open to change vacuum cleaner bag...now lid won't close. It's stuck at 90 degree angle. Is a button to release it?
Hi bndennis,
Please check the spring on your lid, it may be keeping the door open. Miele vacuum cleaners mainly use a spring concept for keeping lids open - merely pushing it down will lock it at the bottom.
Kind Regards :-)
JEDEMEYER1
* If this solution helped you, please rate it
Jul 23, 2011 | Miele S4210 Antares Bagged Canister Vacuum
Why doe this hoover switch off after i start cleaning for about two minutes
You have to check the power switch button because it is mostly used part in the vacuum. A loose connection will occur and the power will shut off if that happened. Also clean the motor, if it is full of dirt you'll be sure motor will easily overheated caused it to premature shut down.
Good luck.
Jul 15, 2011 | Miele Cat & Dog 326i Bagged Canister...
After from ten to fifteen minutes of use it automatically shuts down but will sstart up again after fifteen minutes.
It sounds as if the motor has overheated at some point and damaged the thermal protector in the motor. Be sure all the filters are clean before operating the vacuum. If it continues to shut down, the thermal protector will need to be replaced. ( Part # 28382093 ) This is a very common problem with bagless vacuums, if the main filter is not cleaned after every vacuuming.
Mar 07, 2011 | Hoover U6630-900 WindTunnel Bagless...
Why does my vacuum cleaner quite working about two minutes into vacuuming? It just shuts off. I have the pet fur picker upper version
Sounds like overheating of motor operating a thermal cut out ..Clean all filters you can run machine with no filters fitted to try if okay first.....
Jan 31, 2011 | Hoover U5753-900 WindTunnel Bagless...
Oct 07, 2009 | Miele S558 Red Velvet Bagged Canister...
Miele Red Star Powerhead overheats and turns off
be sure at 1st there is no materials blocking the hose then it seems to me your m/c is good if normall condition around
try to test your cleaner by use less length hoses
thanks
Jul 04, 2009 | Miele Red Star Bagged Canister Vacuum
Vacuums Logo
3,140 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
