Question about Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony kv-36hs500 Hello And Greetings from Virginia Beach Tv Workd great Except sometimes A yellow triangle is seen in the left corner of the screen(70%Opacity) and sometimes moves across the bottom of the screen.Blurring that area and sometimes giving images a 3-D effect Any advice would be much apprecaited JOE
  • phantomoto Aug 02, 2008
    Thanks so much for the advice VERY much appreciated.
    I moved a Tower Speaker and no more distortion.
    Oh Happy Day
    Thanks again you two
    Your Friend JOE
    Well I spoke to soon The problems back! I find it strange that I would move the Tower and the problem disapeared for 24 Hours?
    I'am back to square one HELP!
    To Abrsvcs (convergence IC failure) Is the Solder Job Difficult?
    JOE
  • 4,234 Answers
This sounds like the beginning of a convergence IC failure. If you can solder, you should be able to resolve this yourself. Let me know if that is what you wich to do and I'll provide some additional details and instructions.
Dan
Posted on Aug 01, 2008
  • ABRsvcs Aug 03, 2008
    If moving hte speaker cused a change, then the problem is within the degaussing circuit. Each time the set is turned on you should hear a "boing" sound. That is the degaussing circuit kicking in. If the problem was the magnetic field interfering with the set, removing hte field and turning on the set should have cleared up the problem. I don't believe that that was the problem as the field would not "move across" the picture.
    The problem is most likely within the convergence circuit. The steps to resolve this are 2:
    1) Try resoldering the board at the convergence circuit location as bad connections there can cause symptoms as you describe.
    2) If 1 does not resolve the problem, trace and replace the defective component(s).
    I'll look up the specifics for your model and update this with the probably defective parts.
    Dan
  • 10,594 Answers
Please take away any speaker or some thing magnetic arround TV.
Can't get the "Video 5" legend off the screen
check your manuel, they should be a display button to press to get rid of it, a rectangle with a + in it on the button
Oct 03, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
SONY KV-36HS500 will not turn on. Stand-by mode blinks 6 times then repeats. Repair man checked out our phone system earlier today for signal loss and put 500 V generator on phone line to house to check...
the light blinking six times indicates a probable horizontal circuit failure usually a shorted horiz out transistors but this is not the only component located in this circuit that could create this problem, sorry but i am affraid you'll need to get a tech to diagnose it to the component level or get another pc board to repair it. hope this helps some.
Aug 12, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
No picture or sound
6 blinks usually means a loss of the horizontal signal. This can be as simple as a bad capacitor or jungle IC. I'll look up your specific model, but do you intend to repair this yourself? If so, please update this and I'll provide additional details and instructions.
Dan
Mar 23, 2009 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony wega tv wont turn on
sony kv-36hs500 no enciende y parpadea el stand by
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Tv will work for 10min. or hrs. then cuts off kv-36hs500
it blinked 6x. I unpluged the tv for 12 hrs. and it is fine. trouble shooting said it was horizontal hold overload.
Dec 10, 2008 | Sony FD Trinitron WEGA KV-36HS500 36" TV
Sony FD Trinitron WEGA KV-36HS500 36" TV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
