Clen pump light on but dont know where pump is on my whirlpool washing machine
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter which comes before the pump.
Here are my complete, general pre-typed guidance notes for checking filters and pumps/motors ;-0)
If you are unsure where the filter/pump is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
Model 5000 front loader. Why doesn't pump work?
Whirlpool washing machine drain pump replacement and ...
? 17:45
www.youtube.com/watch?v=2abTptUYXH8
Feb 5, 2012 - Uploaded by HandySavesMoney The drain pump replacement procedure will apply to kenmore, whirlpool, maytag and other front-loading washing machines. ...does anybody knows about front loader whirlpool that won¨t start? i could use some help tx.
Oct 07, 2015 | Whirlpool Washing Machines
Clean pump light is on and i dont know where the filter is as i purchased the machine second hand would really love to finish the washing
Look for a little 6"x6" square door on the bottom front of the washer. if not take the back off and take off the main drain hose.
May 05, 2014 | Whirlpool Washing Machines
Clean the pump
If there is a kick plate on the bottom front you take screws off and you can get right to the pump, un hook hose and clen out. Now if there isn't a kick plate then you have to go through the back and then do the same.. Remember to unplug unit before entry.
Jan 11, 2010 | Whirlpool AWM8163 Front Load Washer
I need to clen the pump on a whirlpool washing machine awo/d 4505
hello mam you cant clean the pump but you can clean the filter of the drain line. and if you want to clean it you should use a descaling powder this will be available with the washing machine service centers.
Sep 22, 2009 | Washing Machines
Clean pump light is flashing where is the pump so i can clean it
The pump is located in that bottom compartment under the door. There are two screws that you need to take out located in that tiny little opening and the panel will come right off. The pump is right there in front. Let me know if you have any other questions and let me know if this was helpful for you. Good luck and I am glad I could help.
Jan 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is set to normal 40 mins runs to last two min than I get F
3 screws a;lone the very bottom of the front panel will remove the panel allowing ou access to the pump anbd clen out area, screws are a TORX 15 size
Dec 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Aug 06, 2008 | Washing Machines
Clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Apr 26, 2008 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
285 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
