Question about Intel DG31PR Motherboard
Motherboard Respected Sir, In Intel mother Board there is No Signal / Display, its dead. For your information its under warranty, purchased from Net com Systems & services - laxminagar.but not getting proper service from him, I am very much disatisfied & distrub, due to this from last two months i am unable to do any work on my system., He said you can directly approach to Intel Co. at Banglore or mail them. so thats why directly approaching to you, Plse. help in this regard. Mother Board Serial No : BTPR934002Z8 Mother Board Name : DG31PRI Kindly suggest what to do, looking for replacement, kindly suggest the procedure. Looking your kind cooperation in this regard. Regards, dhanasekhar kallakurichi villupuram dist Mobile No : 09843632344
  • Intel Master
  • 27,725 Answers
If it is still under warranty you should not attempt to fix it you might lose any warranty you have
contact them ask for someone with a high ranking to help assist you with this warranty claim
if you want to test it yourself do not tell them you have touched it
one bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
Posted on Mar 13, 2011
How to check my gigabyte mother board under warranty?
hi.there...
i read from your information and picture about your motherboard type..i think yours is not under warranty from factory anymore (GIGABYTE)
for additional information your mainboard (MB) is using old type of intel chip set (Intel 865 series) and only support intel processor type Pentium 4 with 478 pin with 533 MHz bus processor..
talking about warranty from factory GIGABYTE only give 3 years warranty only for MB with minimum chipset intel ICH 7 and up..that's mean MB must be support processor minimum 775 pin and 1155 pin or support intel Pentium D,Dual Core,Core2Duo or Core i series...
hope this is can help to solve your problem..
Aug 13, 2012 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Hello sir i have ecs mother board but i haven't sound driver..what can i do..i don't which is the model no..
I would suggest if its not under warranty to open the case an get the model number off the board.
If there is no model number on the board it would help to know what chip set it is as in AMD or intel.
Then its a matter of trial an error if you can not get that information.
Nov 04, 2010 | ECS 945P-A (V3.0) Motherboard
Problem with intel mother board
If the problem is definitely in the motherboard and it's still under warranty, follow the manufacturer's process for getting the board serviced or replaced. Here's Intel's page for warranty support.
Mar 19, 2010 | Intel Motherboard
Warranty for Intel Desktop Motherboards
i need to chech my intel mother board warranty
Mar 22, 2009 | Intel D945GCL Motherboard
Download motherboard drivers
what is the brand or model of your motherboard? then go to the web.. try to search there... if you have an intel board you must type to the adress bar the web.. example.. www.intel.com. then find the supprot and download tab.. there you can download the driver of your motherboard.
Feb 18, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Need dirvers of intel Fw82801db
You must get correct name of the mother board
goto run type msinfo32, wait for some second you wil get brieft information about your system. Check for SYSTEM MODEL that is your motherboard model. Then you go to this link for driver
http://downloadcenter.intel.com/default.aspx?iid=subhdr-IN+downloads
Aug 09, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Mother bord dead
the intel 101 and 82801 share the same sound driver between the two. when the sound system fails it always goes and takes out four more systems including the BIOS system, my suggestion is to retire the motherboards and install an AZUS motherboard and matching cpu. lala linda
Jun 01, 2008 | Intel D101GGC Motherboard
Warranty
Hello Sir/Madam,
Check the local intel office and note down the motherboard no. or better go with motherboard they scanned the barcode and replace within 1 or 2 months if any fault in motherboard.....
good luck
bye
Mar 21, 2008 | Intel D845GVSR Motherboard
Intel 845 chipset mother board no reaction - expecting solution
this is normal No-Ram. No-Beep.
The ram is all part of the bios analysis beep codes.
install memory, and setup the board to the manufacturers specification.
1 beep at post is normal on many bioses.
Mike @ compurepair.
Feb 22, 2008 | ASUS P4BGL-MX 845GL (AS04P4BGL-MX)...
Intel DG31PR Motherboard Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
