Question about Garden
Chainsaw only runs on choke - Garden
  • 223 Answers
You may have a bad carburator but i would clean it out and try to operate before replacing.
Posted on Mar 13, 2011
Jonsered 2036 turbo chainsaw will not run with out choking
It kinda sounds like there is an air leak on the intake grommet or gasket between the carb and and the cylinder. By closing the choke butterfly, you are limiting the amount of air entering the cylinder enough to keep it running, but not running correctly nor developing enough power because the air is entering downstream of the carb inlet.
Aug 10, 2015 | Garden
455 rancher runs with chock out 15 second and dies
Try opening the choke half way as soon as it starts then all the way open in a few seconds... It only needs the choke to start and should run fine in less than a minute after idleing with the choke not engaged...
Jun 15, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Ozito chainsaw petrol 14 inch bar model
Hi Ed, I had this same problem with my chainsaw when it was new. Once you get it to fire with the choke out push the choke back in but don't pull the trigger. Then try pull starting again and let it run for a few moments to warm up. It should run fine then.
Jan 18, 2014 | Garden
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
How do you keep the blue choke to stay out
The choke is designed to spring back in when the chainsaw operator depresses the throttle trigger for easier starting.
If the choke needs to be out for the saw to run you have a problem with the saw, make sure there is fuel in the saw, and the fuel filter is clean, if it fails to run still without the choke you may have a blockage in the carby stopping the fuel from flowing thru to the crankcase...
Brad
Aug 01, 2011 | Poulan 14" Chainsaw
Need a diogram of how the choke on a 026 stihl chainsaw in setup.
the choke is operated by the fingers on the handle grip...the lever is stop...on...choke...when motor running just flick back up to run mode...the choke butterfly is just a open or closed position in the carb y.
Jul 21, 2010 | Stihl 18" Chain Saw Bar 3005 008 4717
My chainsaw Model 142 - motor runs wide open with choke at 1/2 choke - will notrun otherwise
either fuel is restricted or air is leaking into motor inspect fuel lines fuel filter check for carb tightness or pull carb and clean. replace carb parts with kit
May 20, 2010 | Garden
Stihl ms310 chainsaw will only run on choke
You actually need the adjustment tool,looks lie a small screwdriver with a smal socket at the end of it.
Jun 02, 2009 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
