Question about Dryers
Not heating. power good, vent good. how do I access and check heating element
    President:
  • 3,074 Answers
Http://www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
Posted on Mar 13, 2011
Whirlpool dryer not heating any more
Several different things can cause this issue, below is a video that explains how to test all of the dryers components.
http://www.appliancerepairlesson.com/
http://www.appliancerepairlesson.com/category/appliance-repair-video/dryer-repair-video/
Feb 08, 2011 | Whirlpool Dryers
Dryer was heating, the motor running. heating element is not gettin hot but we have power.
CHECK YOUR BREAKER BOX FIRST. THEN MOVE ON TO THE DRYER VENT THEN THERMAL CUTOFFS THEN ELEMENT. THAT IS ALL OF YOUR HEATING PARTS. GOOD LUCK RATE ME!
Aug 26, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Dryer has no heat
Check the entire exhaust venting sytsem. If lint is inside of the tubing it will cause a restriction shutting the burner off at all times. If the tubing is clear the moister sensor is at fault and needs to be replaced
May 09, 2010 | Dryers
Dryer will not produce heat to dry clothes
you first need to access the heating element case and with a multi-meter check the element for 50-250 ohms,then the hi-limit switch and cycling switch on this case,then on the dryer exhaust vent housing theres a thermal-fuse,check this for continuity all components will check 0 or near 0 ohms=good/infinity,no reading=bad/except the element and the above is just an approximation as each element has its own resistance
Mar 19, 2010 | Kenmore 800 6983 Electric Dryer
Whirlpool dryer not heating up
first you need to check your breakers or fuses in your home's breaker box, try turning the breakers off then back on again (if you have fuses ,check them or replace them). If everything is ok there then you need to access the heating element(with the power off) test to see if you have continuity in the element then the high limit& the thermal cut-off. Sometimes dryers seem like they are not heating when the dryer vent is kinked or clogged. This is the number one thing that I find when servicing dryers. Usually when the vent is clogged or kinked I correct that problem first, then continue with the other things . you can quickly check that by unhooking the vent and run a partial load just to see if that works. while the vent is unhooked you can start the dryer and feel the air coming out of the vent of the dryer to see if you are getting heat. You can check that without having clothes in it. let me know. Thanks
Dec 18, 2009 | Whirlpool GEW9868K Electric Dryer
How to replace a heating element for a kenmore
Hello there
i am posting instruction for this dryer below
(For some help with that, and before buying an element you might not need, please see my article entitled 'The No-Heat Dryer'). Note: Always check airflow out the vent before firing up your dryer with its new element. A partially clogged vent can burn out an element - even a brand new one - fast! Just run the dryer on the 'no-heat' or 'fluff' setting, then go outside and check for a good strong flow of air from the vent hood. If there's any doubt, Whirlpool makes a cool little airflow test kit for their dryers that will tell you for sure, from inside.
There are basically 3 styles of heating elements in use for these dryers.
1) Most common is the 'long' one, part number 4391960, accessed from the back of the dryer, and which looks like this:
wpl%204391960%20el.jpg To replace this one, power down and pull the dryer out and remove the back cover. You'll see a long, vertical 'can' on the right side, with the element coil inside. To remove this can, simply pull the element wires (can be hard to remove; I use a long-nosed pliers), the limit thermostat wires just above them, and the thermal fuse wires if equipped (this is a little device mounted high on the side of the can, with two wires attached). One 5/16" hex screw at the top and a little strap holds the can in place. Remove this screw (You can look through the small hole that lines up with it, originally to poke a long screwdriver through), tip the can rearward, and lift it off its two bottom hooks. Once the can's out, one screw holds the element inside. Remove it, and the old element coil will slide out. Slide the new one in, reverse this process, and you're done!
Nov 13, 2009 | Kenmore Dryers
Kenmore Dryer won't heat.
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Sep 09, 2009 | Kenmore 64902 Electric Dryer
Crosley CEDS774JQ0 electric dryer. It wasn't drying well so I pulled the vent line and cleaned it out well, ran the brush down the filter area too. Good venting now. But no heat, none at all. Ideas?
Do not know the model in particular, but by "not drying well" you mean not much heat, and then after cleaning there was no heat---would suspect the heating element (220Volts divides to 110 to make lower heat, like on a range burner) or operating on only 110v. The jostling could have completed the burn-out point of the heating element. Could check for continuity of the element (unplugged) using VOM (volt ohm) meter or flashlight bulb, wire, and battery--bulb metal to one end and wire to bulb tip and other end of wire to other end of element. If careful and safe access could check that voltage to heating unit is in fact 220 volts with VOM set to AC 600v setting (greater than 220v) unless automatic range setting VOM. (or check voltage to element first).
Also, remember when finished to check that vent hose is to inner vent pipe, not just to cabinet; lint build up in cabinet is a common reason for heating elements to burn out.
Aug 08, 2009 | Dryers
Not getting hot
2. Heating element
3. Thermal fuse
Jul 13, 2009 | Dryers
Whirlpool electric dryer that will not heat up, dryer comes on and turns, but no heat
2. Heating element
3. Thermal fuse
Jun 18, 2009 | Whirlpool Dryers
Dryers Logo
24 people viewed this question
Top Dryers Experts
