Tdk NX-03CDMP3-sv stops playing after track 3, then starts up plays a 10-12 seconds and then stops again, repeating the squence. If I select track 12 it will play through from there.
  • 979 Answers
Incorrect alignment of track zero switch. TOC not being read correctly. Shop time...accordianman
Posted on Aug 02, 2008
Is having trouble reading or tracking disc.I opened top and while playing disc the tracking mechanism goes out then back in and starts playing where it stopped?
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 22, 2015 | Audio Players & Recorders
How do i turn on shuffle
Hi Nonya Buisness,
  • Music Submenu
To enter the Music Submenu, press and hold the OK/VOL button for 3 seconds.
AB Repeat
When you select "AB Repeat", you will be returned to your file, and "A-" will be displayed on
the playback screen. Briefly press PLAY to set the "A point" and "-B" will be displayed,
briefly press PLAY again to set the B point, and begin playing you're a-B selection. The icon
will change to "A-B". If you press PLAY again, you will cancel A-B Repeat.
Repeat
To adjust your repeat mode, select "repeat". You can select Sequence, repeat one, repeat
all, shuffle, or shuffle and repeat
**Pressing M will lead you to top menu.
http://www.eclipsemp3.com/180G2.pdf
Mar 02, 2014 | Eclipse 180g2 4gb mp3 music/vid
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
Instruction manual for TDK NX-03 CD Sound System needed.
I have a manual if you want to send me your email I'll will scan to PDF and send you a copy.
Dec 16, 2009 | TDK Audio Players & Recorders
I have a RCA RT 2770 receiver and the usb port does not detect any devices. It does have power as I have connected an IPod and it charges via the usb port. It just does not detect the mp3 player, IPod or...
look here
http://www.voxxsupport.com/images/manuals/RT2770/media/RT2770_UMEN.pdf
USB Device Playback Features
(Only support MP3/WMA file)
1. Press USB on front panel or remote control
to select USB mode.
2. Press to start playback or press to
pause playback.
3. Press to end playback.
4. Press CH+/- on the remote control or /
on the front panel to skip to the previous or
next file.
5. Press REPEAT on the remote control to select
repeat mode. (REPEAT ONE, REPEAT FOLDER,
REPEAT ALL, REPEAT OFF)
6. Press RANDOM on the remote control to
select random play mode. (RANDOM ON,
RANDOM OFF)
7. Press INTRO on the remote control to turn
on/off intro mode. The unit will play the first
ten seconds of each track on the USB device.
8. Press DISPLAY on the remote control to
select among mp3/WMA ID3 information,
elapsed time,current play Folder and Track
number and Play Mode.
Dec 10, 2009 | Audio Players & Recorders
Cannot stop shuffling
You need to go into your Play Mode ssettings and select "Repeat All" to turn off this feature:
Play mode
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
Mar 14, 2009 | Philips GoGear HDD1830 MP3 Player
LD Repeats itself every 15 seconds in play, DVD's play fine.
This solution should help or at least decrease the occurances.
It has worked for me.
The problem seems to be that the original manufacturer lubrication on the glide rails and on the glide track has lost it's viscosity causing the Laser Pick-up Head gliding process to bind causing video to repeat at any random binding point.
Open the top cover and play a Laser Disc.
Manually change from Side "A" to Side "B".
Observe how the Laser Pick-up Head glides on the track and on the glide rail.
Stop play mode and remove the Laser Disc.
With the tray open, unplug the power at the power electrical cord. Now with the power removed and the tray left open, take a "Q-Tip"™ and spray some ""WD-40"­™ on the "Q-Tip"™.
Now gently tap the saturated "Q-Tip"™ along the full length of both the upper and bottom glide rails as well as the glide tracks.
Repeat this process.
Be careful not to touch or lube the Laser Pick-up Head with the "Q-Tip"™.
If you do touch the Laser Pick-up Head, just gently clean it with another "Q-Tip"™ saturated with alcohol.
When finished, reconnect the power and play a Laser Disc.
Manually change From "SIDE "A" to SIDE "B" about three times to spread the "WD-40"™ evenly and ease the gliding process.
This solution should help.
Feb 08, 2009 | Pioneer DVL-919 DVD Player
My songs are shuffled
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music:
1. Off
2. Repeat single Track
3. Shuffle/No Repeat
4. Repeat all Tracks
5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
Aug 07, 2008 | Insignia Sport MP3 Player
Songs wont change
It is stuck on "Repeat One" - refer to p.23 of your user's manual -
Repeat All ).
While you are playing music you can see the following active play mode screen.
-Tha Mp3 Doctor
Oct 30, 2007 | Philips HDD1630 MP3 Player
191 people viewed this question
 Grubhead
Grubhead
