Question about Plumbing
Salamander pump cuts out half way through shower what is the problem
2 Suggested Answers
  • 1015 Answers
SOURCE: salamander rsp 75pump not working, When shower tap
I would be more inclined to think that pump impeller has something caught in it. There should be a flex coupling of some kind that you can lossen to remove pump from basin. Unplug electrical cord and pull pump out. There should be a removeable slotted cover on the bottom that you can take off to clean impeller. Remove all debris from bottom, wash out with water. Depending on what type of switch you have on your pump you can make sure all water is out of pump and plug in momentarily,rise float to turn it on and see if it runs. If it has apressure switch you won't be able to do this. If you can make it try to run make sure you only try for a few seconds. These pumps are not designed to be run dry. If it runs put bottom cover back on and reinstall pump. If it doesn"t you probably will need a new pump. Thank. Hope this helps.
Posted on Nov 14, 2010
How to increase water pressure on wall mounted shower
Yes,,,
You could fit a shower boost pump if you water supply to the shower is gravity fed. Pump both the hot and cold so that the water pressure is equal...
Salamander pumps are the best and have flow switches which activate when the shower is turned on..
There are cheaper pumps available... you get what you pay for...
http://www.screwfix.com/p/salamander-pumps-rsp50-positive-head-shower-pump-1-5bar/99043
Just for a guide....
Apr 12, 2017 | Home
My shower does not stop when turned off. It still runs fully for half an hour and then dribbles all the time
Tell us what type of shower. Power shower with a pump? Mains water power only? How old is it? Who fitted it? Does the control valve feel like its working properly?
Aug 12, 2015 | Home
Salamander pump leaking
I have repaired in the past by disassembling the pump assembly and freeing up the paddles. It will likely require a new gasket - either purchase a new one or make one (tedious but dooable). It is also possible that the leak is from a hose connection instead of the pump - pretty simple to cut back the hose slightly and reconnect.
Good Luck!
Nov 25, 2014 | Heating & Cooling
Triton t200re shower
Paul. Is it only the shower that the pump cuts out? i dont think we have these pumps in AU. Would bet that its a flow issue. Either remove the water saving device in the shower, if there is one. Pr turn another tap on just a dribble when you start the shower?
We have these issues with "smart"? controllers that think there is a leak
May 19, 2013 | Grundfos Pumps Grundfos MQ 3-45 1 HP...
Comes on but cuts out and bellows smoke from filter.
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 29, 2011 | Milwaukee Tool Master Heater 70,000 BTU...
Salamander rsp 75pump not working, When shower tap is turned on the pump hums but does not pump. Could this be just electrical brushes that need replacing?
Nov 14, 2010 | Plumbing
Your install instructions are wrong. they read cut off two and one half inches off measurement of bottom guide. I did that and it is one and one half inches too short. your instructions are wrong and now...
are you sure your measurements are correct? hate to be looking like i'm playing devils advocate for sterling, but i've installed many shower doors and had made this mistake once,.....write me and maybe i can help rectify this potential goof,......
Aug 22, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
New shower installed doesnot always kick pump in
some times if there not enough water flow passing through the pump it wont kick in make shure all other taps ar off an try that ,have you got a good water pressure in you house?
Jan 26, 2009 | Home
Triton Millenium Power Shower
generally if the flow sensor notices no water through the pump it will auto matically shut the pump down. so it could be the flow sensor is bad or the pump is not working like it should. now it depends on how old the pump is. i would start with the flow sensor.
Aug 30, 2008 | Home
Plumbing Logo
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
