Question about IBM 6400 Matrix Printer
Quand je lance l'impression sur ibm 6400 un code erreur apparait : code 058 "BLOCAGE DE LA NAVETTE D'IMPRESSION "
5 Suggested Answers
  • 13 Answers
SOURCE: 058 shuttle jam
This can happen for a number of reasons.:-
a. The print mechanism needs to be adjusted ( You'll need a technician to do this if yu are not familiar.
b. Something is clogging the print mechanism, eg Old ribbon residue, or sticky labels etc.
c. The paper thickness lever is set to incorrect setting . Try adjusting it out .
Aido
Posted on Mar 06, 2008
yooperbud
  • 8637 Answers
SOURCE: Error 058 Shuttle Jam on an IBM 6400 Matrix printer
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Posted on Jan 25, 2009
LineMatrix
  • 34 Answers
SOURCE: ibm 6400
This is a easy problem... Have any question call 972-907-9771 x311
51e9bbd.jpg ATTENTION Hammer springs and hammer tips are fragile. Do not touch the hammer springs or tips. Handle hammer springs by the
thick mounting base only. Apply pressure only to the mounting base.
NOTE: Replace a hammer spring assembly only if there is visible damage or broken parts can be seen in the assembly.
5. Remove the mounting screws from the old hammer spring assembly. (See Figure 18, page 367.)
6. Handling the hammer spring assembly by the mounting base only, gently pry the old hammer spring assembly off its
mounting pins. (See Figure 18, page 367.)
7. Inspect the hammer bank and the old hammer spring assembly:
a. If there is ink on the hammer bank mounting surface, the hammer spring assembly mounting surface, or the hammer
spring neck or tines, reinstall the old hammer spring assembly and replace the shuttle frame assembly (page 405).
b. If the old hammer spring assembly and the hammer bank are free of ink, install the new hammer spring assembly
Installation
1. Using a clean dry cloth, wipe the hammer spring mounting surface on the hammer bank. Make sure the cloth does not
leave lint on the hammer bank.
NOTE: Replace a hammer spring assembly only if there is visible damage or you see broken parts in the assembly.
2. Handling it by the mounting base only, remove the new hammer spring assembly and mounting screws from the box.
3. Handling the hammer spring assembly by the mounting base only, carefully position it on the hammer bank mounting pins.
then gently press the mounting base down against the alignment pins. (See Figure 19, page 369.)
4. Continue pressing down on the mounting base of the the new hammer spring assembly as you install the mounting screws
from the replacement kit. Using a Torx T-10 bit adapter, torque each screw to 14 inch-pounds (1.58 N•m). Tighten the
center screw(s) first. (See Figure 19, page 369.)
NOTE: Use the 1-30 inch-pound Torque Screwdriver, IBM part number 16F1661.
5. Install the hammer bank cover assembly (page 354).
6. Install the shuttle frame assembly (page 405).
7. Install the ribbon and load paper.
ATTENTION Do not attempt to adjust or “tweak” hammer springs.
8. Run an operator print test and check print quality (page 223):
a. If print quality is acceptable, return the printer to normal operation (page 339).
b. If print quality is still degraded, replace the shuttle frame assembly (page 405).
Posted on Sep 10, 2009
Printtech
  • 1087 Answers
SOURCE: QUAND JE LANCE L'IMPESSION ,LEXMAX
S'il vous pla?t assurez-vous que les param?tres du papier sur l'imprimante est le m?me depuis l'application (par exemple Microsoft Word).
Posted on Jul 18, 2011
Bonjour, j'ai un problème avec ma MP600. Elle n'imprime plus en noir. Pourtant lorsque je lance une impression noir et blanc elle fonctionne comme si elle imprimait, mais à la sortie, la feuille...
English to French translation bonjour il se pourrait que votre t?te sur votre imprimante est bloqu? aller ? la maintenance de votre imprimante et faire le nettoyage de vos t?tes dans la partie maintenance de votre imprimante, il vous dira everthing comment le faire
Oct 08, 2010 | Canon PIXMA MP600 all-In-One InkJet...
Je n'ai plus de tonalité quand je téléphone, plus de son
Mouais, il manque un peu d'info pour vraiment cibler le probleme mais je vais commencer par y aller avec le plus simple et évident, et si ce n'est pas le problème, récris un commentaire pour préciser pas de son dans quel sens. Donc, tout simplement a priori comme ca, je dirais que le haut-parleur de ton tréo est brisé, ou encore qu'un des connections ou soudures qui le relient a la carte principale du tréo a cédé. Si tu es sur que ce n'est pas ton cas, alors faudrait que tu précises si t'as juste aucune sonnerie mas que tu entends quand meme quelques sons quand par exemple tu fais jouer un MP3 ou quelquechose. Ou encore si vraiment tu n'entends pas parler la personne quand elle décroche mais que tu entends ta sonnerie quand quelqu'un t'appelle. Bref, essaye d'etre le plus précis possible et de me dire tous les modes ou le son fonctionne ou fonctionne pas. Voila, donc en espérant t'avoir un peu aider, sinon j'attends de tes nouvelles pour pouvoir essayer de mieux comprendre le probleme et te trouver une solution.
Jul 28, 2009 | Palm Treo 750v Smartphone
Kodak Error B03
Either your PCB board is damaged, your batteries are old, or your AC adapter is providing higher voltage than the required 3 volts.
Feb 09, 2009 | Kodak EasyShare CX7430 Digital Camera
Je ne suis plus capable de prendre de photo avec ma cam?©ra ???
N'inquite pas. C'est parce-que tu essais de prendre un foto par utiliser le petite button sur la camera. Cela n'est pas correcte. Tu besoin de cliquer sur l'icon pour la camera sur la desktop de votre ordinateur. Quand le fenetre pour Microsoft Lifecam a ouvre, il y ont tres buttons, cliquer sur l'un qui resemble une camera. Voila, ce come ca que tu peut prendre un foto. Bon chance (et pardone-moi pour le francais qui e suelement come ci come ca.)
Jul 24, 2008 | Microsoft LifeCam VX-3000 Web Camera
Error F89-2
bad controll board
May 27, 2008 | Office Equipment & Supplies
Mon recepteur fta viewsat ultra est bloque
As-tu le cable db9? Et qu'est ce qui apparait sur la fenetre de ton ultra quand tu l'allumes?
Feb 06, 2008 | Audio Players & Recorders
IBM 6400 Matrix Printer Logo
102 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
