Cant get belt on - Washing Machines
    Brigadier General:
  • 6,277 Answers
If it has just come off I would strongly advise not just putting it back on as it will only come off again but to purchase a replacement. Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
Hope this is your problem solved.
Good luck,
John C
Posted on Mar 13, 2011
I cant get the crankshaft bolt off
They are sometimes installed with threadlock compound which makes it very difficult. How big and powerful was the impact wrench? Is there scope yet to hire a really huge one?
The bump method is a last resort because it puts the flywheel ring gear teeth at some risk. Break one of those and you are up for expense.
Apr 02, 2017 | Ford Taurus Cars & Trucks
Replaced alternater now cant get belt back on cant find adjuster
well not having put one on myself, here goes.all your pulleys that are smooth on the outside means the back of the belt is goin to be touching it, whereas the grooved side of the belt is gonna face the grooved side of the pulley.the adjuster just tightens the belt.good luck
Dec 14, 2010 | 2004 Saturn VUE
How to change my vacuums belt
If you can't stretch it for enough get a bigger one and cut the bigger belt to where you want it.
May 19, 2010 | Bissell 6594 PowerForce Bagless Upright...
I cant find the belt diagram for my 95 ford taurus
Go to your local Napa store, they should be able to print you out a belt routing diagram.
Nov 07, 2009 | 1995 Ford Taurus
Porsche boxster alternator belt
some porsches adjust belt tension by adding or removing shims between the two pulley halfs.take the nut off the pulley insert the belt put thebelt,outer pulley and nut back on.
Jul 05, 2009 | 2001 Porsche Boxster
Cant get drive belt back in place
You might find this site helpful. Good pictures and a sense of humor!
May 30, 2009 | GE DBXR463EDWW Electric Dryer
Xerox phaser6110MFP transfer belt error cant
Transfer Belt Error Aproblem has occurred transfer belt in the machine. Unplug the power cord and plug it back in.If the problem persists
Cleaning the inside of the sensor of the belt and then not change you change the blet assembly moz-screenshot-1.jpgmoz-screenshot.jpg
Apr 22, 2009 | Xerox Phaser 6110MFP All-In-One Laser...
Hotpoint wf240 replacment of belt, i cant get it on.
Hi, put the belt on the bottom pully and feed the rest up to the top pully, fit the belt on to half of the top pully, now open the door of the washer and very carefuly turn the drum while holding the belt tight to the pully, take care not to get your fingers trapped, make sure that the belt stays on both pullys by rotating the drum by hand a few times, if it all looks ok and central then the jobs a good un.
Mar 03, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Ken more 90 plus serious
hi i assume you cant get on the pulleys . double the belt ant slide your doubled belt under the idle and to the motor you will feel the tension when you put the belt on the motor pulley
Sep 25, 2008 | Kenmore 62602 Electric Dryer
Washing Machines Logo
Top Washing Machines Experts
