Question about Dryers
Even with the door open the dryer turns on - Dryers
    Master:
    Sergeant:
  • 385 Answers
If you can turn the Dryer on even with the door open you have a bad door switch.The door switch is located on the dryer body so that when you close the dryer door it activates the switch.Be sure to turn off the power to the dryer and pull the electric plug before trying replace the switch.
Posted on Mar 13, 2011
My dryer will not turn off! The drum keeps turning even when I open the door! Help!
You need a new door switch.
Google
Make Model door Switch.
Presumably you can turn it off with the timer. If not, you need one of those too.
Nov 26, 2015 | Dryers
Dryer still tumbles even when door is open. It will turn of and stop when i turn it manually to off
The door actuator mounted on the door or the switch mounted on the dryer is missing or broken. The dryer is supposed to stop if the door is opened. Replace the door actuator or the switch.
Mar 03, 2015 | Dryers
I have a kenmore HE2 model 110.87562601. When I turn on the dryer, shut the door and push the start button, it beeps like the door is still open even though it is all the way closed.
Check your door switch...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 25, 2010 | Kenmore Dryers
My dryer keeps stoping during the cycle and the door opens. Do you have any suggestion? Thank you very much
most likely you have a bad door switch your dryer will stop when the door is opened another way of by passing this switch would be to find it onthe inside of your dryer and connect the two wires together this is only a temporary fix your dryer would always run even withthe door open by doing this best thing to door is look online marone appliace call them give them your model number order a door switch ad you might even need a door latch also if your door is not staying closed hope this helps
Jul 13, 2010 | Miele Novotronic T220 Electric Dryer
Kitchenaid dryer keye660wwhi stopped working 30 seconds after turning on. i opened the door and closed it and it turned on again only for it to shut off again in ten seconds.Now it won't even turn on at...
your door latch is getting loose and ont holding the door switch in far enough to make contact,open the door,keep your hands out of the drum and push in or on the switch and see if this fixes the problem and the dryer runs,then just replace door catch hardware
Jan 31, 2010 | Dryers
How to replace door switch on old kenmore stac.dryer 110.88752792
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.Check online for the part repairclinic.com has it for $14.00 not bad
Nov 17, 2009 | Kenmore 63942 Dryer
Dryer stops in the middle of cycle
The door latch has failed, that's why your dryer stops. When the door opens it stops the drum and turns off. Fix the latch.
Jul 01, 2009 | Maytag PYE2300AY Electric Dryer
My Maytag gas dryer is not heating correctly. It gets warm, but takes several cycles to dry even small loads.
one thing u can do remove vent tub,
turn on dryer run for about two min
open door touch inside door if hot
u have a vent problem
May 12, 2009 | Maytag PYG2300A Gas Dryer
Heating element turns on when you turn on timer door open
Sounds like the door switch is broken.Fairly easy to replace.
Feb 16, 2009 | Frigidaire GLER642A Electric Dryer
Dryers Logo
52 people viewed this question
Top Dryers Experts
