Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
Our SAECO Royal Digital has been working great for a few years, but since some weeks, the water/coffee is pouring very slowly and takes like 5 minutes for 1 cup of coffee. tx for your assisitance. Veerle - Belgium
  • Saeco Master
  • 19,396 Answers
Hi Veerle.
Try descaling and rinsing the machine. The problem is usually given by clogged water lines. In some case a defective pump or pressure sensor can give the same problem. Problems caused by limescale obstructing the lines are far more common.
See cleaning and maintenance operations in this manual.
Do descale and rinse as suggested in the manual. If that does not work, the repair is done measuring water pressure from pump with a gauge tool, and manually replacing the defective part. Here a diagram: SAECO Royal Digital. or (Royal Digital Plus).ind.
See also: (Royal Digital Plus).indd
Regards.
Ginko.
Posted on Mar 13, 2011
How to purge saeco royal digital plus
run hot water from the steam nozzle for few seconds
Mar 01, 2009 | Saeco Royal Digital Plus Coffee...
The steam knob only turns 1/4 turn to left
Hi
!/4 turn is all the Magic and Royal machines will do. Don't try to turn it farther or you could break the steam valve.
Dec 26, 2008 | Saeco Royal Digital Plus Coffee...
Ventilate sign on my coffee machine
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
Dec 15, 2008 | Saeco Royal Digital Plus Coffee...
Instructions for descaling Saeco Royal Digital
I used to run vinigar and water thru my coffee maker to remove the **** vinigar is slightly acidic. make sure run just straight water thru it afterward to get rid of the taste.
Robert
Sep 05, 2008 | Saeco Royal Digital Plus Coffee...
Saeco royal
Try to set the grinder to grind coarser, make 2-3 cup of coffee to get coffee with the new settings.
/Mirran
Aug 25, 2008 | Saeco Royal Digital Plus Coffee...
No coffee, water going to the drip tray
OK, so this is a problem with your brew unit. The unit is not cycling correctly to tell the water to come through.
We had another problem like this just this week.
The wat we fixed it was 1) Give the Brew Unit a really good clean. 2)Make sure the Brew Unit can complete a cycle - manually rotate the brew unit components through a cycle 3) Lubricate the Brew Units moving parts if necessary using some Saeco or Other Food Grade Lubricant
Then try watch a complete coffee cycle by leaving the side door of your machine open, and tricking the micro switches into thinking the door is closed by engaging them with some card or something similar.
Let us know if this does not resolve your issue.
Paul from Coffee Shrine
Saeco Coffee Machines
Aug 20, 2008 | Saeco Royal Professional Espresso Machine
No steam and ventilate
When you try to get out water, can you get a full cup of water or just a half cup?
How often do you descale your machine?
/Mirran
Aug 17, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital not providing water
If you try to make a cup of water, can you make a full cup or just a half?
Jul 31, 2008 | Saeco Royal Digital Espresso & Coffee...
Saeco Royal Digital won't brew coffee
normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
Jan 11, 2008 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
78 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
