Question about Roper Washing Machines
My roper washing machine doesn't spin all the water out.When the cycle is done the clothes are still dripping wet.The drum does aggitate and spin.What could be the problem?
    Brigadier General:
  • 6,277 Answers
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
MACHINE WITH AGGITATE BUT WILL NOT SPIN DURING SPIN CYCLE AT THE END. CLOTHES ARE DRIPPING WET
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Inthis case as the final spin is not working the voltage to the motor at the time of the cycle must be checked to confirm the fault of the main program controller . Also the drainpump must work after the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin. If the drain pump is clogged and not working there will be residual water and so SPIN MIGHT NOT WORK.
cleaning drain pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Thank you for using fixya.
Sep 21, 2011 | Washing Machines
Spins but laundry is still dripping wet
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
May 01, 2011 | Smeg Washing Machines
Washing cycle just fine, goes through the spin cycle, but clothes are not spun out, still dripping wet, but water has drained. Replaced the timer but still does not spin out.
The belt around the drum may be worn and slipping, either on the drum or motor.
Check to see if you can find any evidence of belt dust, etc.
Mar 17, 2011 | Washing Machines
My wash machine wash the clothes but not doing the final spin, all the clothes all soak and wet
Handyman here -
Its possible that the door is not locking properly. If the door doesn't lock the machine will wash, but not spin the clothes dry. If you wait 15mins or so after machine is done, then set cycle to spin, it will pump any water that has dripped off your clothes out, but again it will not spin. Helps a little.
Good Luck!
Apr 03, 2010 | Frigidaire ATF6000ES Front Load Washer
After wash cycle is done, the drum fills with water. I can use the spin/rinse cycle to get rid of it but if I'm not there, immediately after a wash cycle is done, my clothes are all wet again.
your fill valve is leaking mostlikely caused by haveing a cheap valve they use these days or sand could have gotten in it and caused it to stay open a bit dripping water in. replace the valve and it should be ok.
Jan 04, 2010 | LG WM-2277HW Front Load Washer
I have a Sears Kenmore washer that sometimes does not spin in the spin cycle and sometimes it does. The timer progresses to stop, but clothes are still dripping wet. Resetting timer from spin usually...
The transmission in this machine is worn and is not shifting correctly. Understand that after the aggitate cycle, this machine should go into drain cycle without spinning and it should drain for about 1 minute. Then it should kick into spin cycle after it has emptied all the water. What is happening is it is (like skipping) the drain cycle and going directly into spin with water still in it,,, so the spin is slow as it is trying to empty and spin at the same time,,, thus the clothes do not spin out correctly,,, when you reset the spin, you actually spin all the water out the second time around.
Oct 10, 2009 | Kenmore 24032\24036 Top Load Washer
Dripping wet clothes
will be an UNBalanced load, maybe there was not enough clothes in the load so in that case the drum would not be able to distribute the load evenly so gave up on the spin, hence wet stuff!
Jan 27, 2009 | Haier Washing Machines
Spin Cycle Works Some
you have a broken coupler...this is a plastic and rubber part that connects the motor to the transmission.  A $20 part
Jan 24, 2009 | Kenmore 15864/15862 Top Load Washer
Roper washer leaves clothes wet after spin cycle.
you need to check the lid switch ...Set the unit to the spin cycle and open the lid look on the right side for the switch there ia a finger on the lid itself that closes to this with the lid open and the unit on use a pen to press in on the switch you should hear a click if not the switch is bad and will need replaced
Jul 30, 2008 | Roper RAB2121KW Top Load Washer
Washing Machines Logo
89 people viewed this question
Top Roper Washing Machines Experts
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
