Question about Microsoft Xbox 360 Console
The xbox its self just stopped working it wont receive any of the ;power from the pac which has a yellow light on it i tried with aother power pack so its definatly notthat i dont understand one minute it worked n the next nothing
  • Rod Sims
    Rod Sims Mar 16, 2011
    When you plug the power chord from the power brick in to the console does the yellow light flicker and dim a little?
    or no change?
    Problem Solver:
  • 13 Answers
Check all power cables once more and if connected to an extension cable check that too and if all cables are connected try turning on console by pressing the eject button if this doesn't work and if another power supply doesn't work then you will need to get your xbox fixed.
Posted on Mar 13, 2011
Testimonial: "ive tried all of these so the xbox its self must need to be looked at :( thanku for your help "
  • 767 Answers
One more thing to look at before you take it in.
Check the two usb ports on the right side in the
front of the box , some times the four pin connector
will break and the wire ( contacts ) will be touching,
this will prevent the console from starting. Just take
some tweezers and make sure all of the contacts
inside the ports are separated.
It's a shoot in the dark ,
Rob
Posted on Mar 22, 2011
My 02 gtp wont start no power to fuel pump but power to coil pac but only dull spark
if you had a broken wire this would cause arking which generats heat so could be short else ware
coil pack will be on same circuit as fuel pump so needs checking
Aug 18, 2012 | Cars & Trucks
POWER WILL NOT TURN ON AFTER I PUSH POWER BUTTON,TRY TO EJECT DVD LETTING THE POWER PAC COOL DOWN. WHAT IS THE POSSIBLE PROBLEM?
Has the power pack got the light on in? If it has one saying it is receiving power from the socket. If not try plugging into an alternate outlet or changing the plugs fuse, also make sure all connections are fitted properly and there is no dust blocking any connections.
Feb 28, 2011 | Video Game Consoles & Games
My xbox adapter keeps on flashing yellow and the xbox360 wont turn on
xbox 360 and you mean the power brick is flashing yellow that means its broken you can try it with another xbox or buy a new one but first thy it in another outlet if you fix it by your self its hard to open its glued together and the problem can be many diffrent things
Dec 18, 2010 | Microsoft Xbox Console
My console wont turn on
Check to make sure the light is green on your power pack, usually yellow when the system is powered down....if there is no light on (when plugged in) its juiced and time for a new one
Feb 16, 2010 | Microsoft Xbox 360 Console
THE POWER PAC FOR MY NADY WIRELESS MIC DOES NOT WORK. ON THE POWER PAC IS MODEL: HHD15-300, INPUT: AC120V 60 Hz, OUTPUT: DC15V 300mA. DO YOU HAVE A REPLACEMENT? BOBBY
Hi Bobby
It is most likely that the moulded plug fitted to the power pack has failed. Do you have any way of testing the the output of the pack
Please let me know if you have a multimeter and we can go from there. It may be an easy fix for you.
regards robotek
Jan 03, 2009 | Audio Players & Recorders
My xbox 360 wont come on
my power wont come on and my light on my power cord is yellow
Jan 01, 2009 | Microsoft Xbox 360 Console
Battery Pack or Ac Adapter
check the light on the box. if it has no light no power is getting to the box. if its red then it could be a xbox problem. yellow is standby and green the xbox is turned on.
Sep 15, 2008 | Microsoft Xbox 360 Console
Xbox360
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one
Sep 06, 2008 | Microsoft Xbox 360 Console
Xbox 360 Controller - no power
The same thing happened to me the other day. My controller simply stopped working! So I called MS to report the problem, and they asked me to send it and they replaced it at no cost. They only asked me for my Console's Serial Number (I bought it on December 06 so it was under the 1 year warranty) and that was it. I received my new controller 1 week later. Have you tried using the rechargeable battery pack from MS? Because maybe what went wrong in your controller is the battery pack.
Aug 18, 2007 | Microsoft Xbox 360 Console
Xbox 360 wireless controller
You must sync the 360 with your controller. Turn on your 360 and your controller. Push the little black button on the front of your console, then hold the little tiny button on the top of your controller for a few seconds. This should sync them.
May 19, 2007 | Microsoft MS Xbox 360 Common Controller...
Microsoft Xbox 360 Console Logo
132 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
