Question about Car Audio & Video
ZX3-T4D Audio Amp
Protection light comes on the amp, what dose that mean??
  • gwt4 Aug 15, 2008
    Thanks for that mate, you hit the nail on the head. Cheers
    President:
  • 624 Answers
Normally that means that you have a blown channel in the amp. Sometimes it can be triggered by a bad speaker. dis-connect your speakers and see if it still goes into protect. If it does not go into protect, yu amy only have a bad speaker. Get them checked to see if one is bad and then replace it with a good one. If the amp still goes into protect, you need to have your amp checked by a professional technician to have it repaired.
There is no way to tell just what is bad inside the amp or how much it will cost without having it checked properly. Sometimes these problems can be fixed for as little as $65 and other times it may cost over $200. It just depends on what is found to be the problem.
If I can be of any more help let me know. I have been repairing car and home audio equipment for nearly 18 years and can be very helpful.
Good luck,
Dave
Posted on Aug 01, 2008
Protection light came on what cut off
Amp in Protection - Troubleshooting - Basic Car Audio ...
www.bcae1.com/.../troubleshootingbasicsampinprotect.htm
Some simply shut down and the power light will not illuminate when in protect mode. If the power light blinks then goes off, the amp is either going into protect ...
How do I fix my amp it keeps going into protection mode ...
? 2:00
https://www.youtube.com/watch?v=DQ1bdsm6s2c
Apr 24, 2013 - Uploaded by Nathan West
My MTX 600xd amp light won't even come on. ... Red light comes on. ... one.. and some times it goes into protection... once I turn the car off...
Jan 11, 2016 | Car Audio & Video
Why this planet audio protection light always comes on when i turn up the car audio
The amp in question is a very entry level amp. Meaning it needs to be ran at moderate ohm load. And have plenty of power to feed it. Check your grounds. Pos. Etc.
Feb 03, 2013 | Planet Audio AC1500.1M ANARCHY CLASS AB...
My m.a amp whont work. The protection light turns on. what could be the problem
The protection light comes on when a wire is crossed, shorted, loose, etc. Check your wires, and then double check them, at the amp, and from the head unit, you may have a short or loose connection. If you have any kind of Y adapter on your RCA cables, this could also cause this problem.
It could also mean your amp is dead. If this is the case, get it serviced.
Jul 14, 2010 | MA Audio HK4000D Car Audio Amplifier
What does the red and green light mean ???
red and green light? there is most likely a protection and a power light. The red I assume would either be a protection light or a clipping light signal. Does the amp kick off then these lights kick on red then to green?
May 31, 2010 | Planet Audio VX4002 Car Audio Amplifier
Amplifier has went into protection mode. What dose this mean.
it means you may have a shorted speaker(s) or speaker wire(s) or the amp itself may be bad.
Mar 16, 2010 | Legacy Audio LA430 Car Audio Amplifier
The protection light keeps coming on on my ample audio a 410x amp it was working and now its not whats the problem
Most of the time. If the protection light is on that means your protected. Not that there is something wrong. So if it is working then your fine.
Mar 02, 2010 | Ample Audio A 410X Car Audio Amplifier
My amp is a kenwood kac-9152d it goes in to protection mode soon as you hook up the power
In protection mode do you mean the light comes on and it plays music and stuff? If that's the case, that's what the amp is supposed to do. Protect itself from a power surge
Feb 21, 2010 | Kenwood KAC-9102D Car Audio Amplifier
What does it mean when the red protection light illuminates
Hi the protection light comes on when there is a problem within the amps. circuitry. Generally speaking the protection light normally comes on when powered up while the amp checks all of its voltage rails so that they all lie within a specific tolerance, when all have been verified to be in spec. then the protect light goes out & the power light comes on. If the protect light stays on then a fault exists within it's circuitry. Cheers, acbva.
Nov 14, 2009 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Protection light flashes on and i get nothing
Hello shwoop22,
It sounds like power is shorting out or the amp is defective. With the fuse removed, use a multimeter set to ohms and check between the power terminal to ground.
The protection light will normally come on if the amp overheats (for example when running with too low impedance), or if the speakers are shorted.
Hope this helps.
May 04, 2009 | US Acoustics USX-2100 Car Audio Amplifier
Protection Light
when the protection light comes on means either you have something like you power and bround backwords,or you have speaker wires touching somewhere..
Dec 04, 2008 | Alphasonik PMA1200D Car Audio Amplifier
Car Audio & Video Logo
191 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
