My transmitter 6n6-tx6u-516-v10(ss) does not transmit the outside temperature
5 Suggested Answers
marsrover
  • 682 Answers
SOURCE: No sound transmitting from Soundstation EX wireless mic # 2201-00699-002
confirm that you select aux input in your soundstation2.-if your problem excit change audio cord between receiver output and the aux.
Posted on Mar 05, 2008
  • 7 Answers
SOURCE: outside temperature won't work
Please check the following website for all the info and faq.
http://skyscan.info/content/index.php?option=com_content&task=view&id=35&Itemid=40
Also,
If you have lost the outside temperature on the clock display after replacing the transmitter battery then do the following:
1. Make sure you have good batteries installed in the remote transmitter
2. Remove the batteries from the main clock and keep them out until the clock display disappers.
3. Re-install the batteries in the clock.
4. Wait until the display returns and includes the outside temperature display as well.
5. Set the clock again for current time/date etc.
6. Bingo. You are in business.
Posted on Dec 19, 2008
freetek
  • 5568 Answers
SOURCE: Outdoor transmitting
These devices have a limited range, normally 20-30' (~6-9m) and that range is influenced by the material that separates them. Any metal structures in their path can shorten the useful range. Also, I think all of these transmit only a second or two every few minutes to conserve battery power.
Posted on Mar 08, 2009
  • 10865 Answers
SOURCE: Outside temperature not working on
hello lucy... you most likely have some corrosion in the outdoor component. Remove the batteries from the outdoor component and clean the battery contacts with the eraser end of a common pencil. Reinstall the batteries and then give it up to 8 hours to start reporting accurately again. Joe
Thanks for choosing Fixya!
Posted on Feb 18, 2011
I put new batteries in Transmitter and never got any temp reading.The unit is less than 2 years old and is not working. Is there anything I can do?
  • Remove all batteries
  • Install new batteries in transmitter
  • Wait for transmitter to initialize and begin transmitting temperature data
  • Install known-good batteries in receiver
  • Observe outdoor temperature reading
If this doesn't work, the transmitter or receiver or both may be defective. I find in very cold weather the transmitter stops sending the temperature.
Dec 08, 2016 | Measuring Tools & Sensors
Can reset everything on my SkyScan Atomic Clock except for the outside temp. Have new batteries in both units. Main clock and outside remote thermostate..Any suggestions??
I expect that since the unit reads the outside temperature from the remote thermostat, there is no need to "reset" the displayed number since this data is obtained live from the thermostat.
Nov 04, 2015 | Home
How do I set up my skyscan temperature transmitter
These devices are very particular about how they are set up. You are supposed to insert batteries in the transmitter first then wait awhile until it gets in the mood to start transmitting. Next, insert batteries in the clock and wait for the two units to begin "talking to each other".
Sep 16, 2014 | La Crosse Technology TX6U Wireless...
Why does ONLY one out the 17 windows / doors transmitter give a FAILURE signal only when THE temperature falls BELOW 50 degrees fahrenheit?
crystal based transmitters and some pll based transmitters can stop transmitting or change their frequency sufficiently during hot or cold temperature excursions causing them to go outside the monitored range fo the base receiver which looks like them going off line to the control panel. This is a sign that the particular sensor has a bad or out of spec component in the transmitter board of the sensor. You can resolve the issue by either replacing that unit or by reassigning it to an area that maintains a more moderate temperature profile. Replacing it is generally the best bet so that if it dwells on the cusp of being within the correct frequency range it could cause a false alarm under the right conditions.
Jan 04, 2011 | GE Security Simon 3 Wireless Home Security...
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
Outdoor temperature doesn't transmit below about 32 degrees.
I have one of these, and below freezing, the sensor is frozen.
Apr 18, 2009 | SkyScan 86742 Digital Atomic Wall Clock
Remote Sensor
make sure your time is set and the atomic clock time is recieved, then leaving the rear cover off of the transmitter, push the "tx" button not the "c/f" that is just for centegrade or ferenhight. you will see the red light on the front of reciever flash in a few seconds. The temp should display on your clock screen. If not, did the red l.e.d. light on transmitter flash. If not, its not sending data to clock. I have to reset and hit transmit every time I replace batteries on transmitter. Had no problems for over 2 years of using outside. If your not getting a reading with transmitter sitting next to clock after hitting "tx" button you may have defective transmitter.
Jan 13, 2008 | Homedics Sound Spa Premier SS-5000 Clock...
Outside temp
make sure the unit is not in direct sunlight. It wiil pickup sun heat and transmitt the heating of the unit, not just the ambient temperature.
Nov 18, 2007 | Homedics Sound Spa Premier SS-5000 Clock...
Oct 17, 2007 | Polycom SoundStation EX (expandable)...
Temperature Transmitter
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
291 people viewed this question
 Grubhead
Grubhead
