Question about Toshiba HD-XA2 HD-DVD
I have 2 Toshiba HD DvD players which do not work. Do you know any place which will atempt to repair them? Thanks Don sawtell
    Scholar:
  • 146 Answers
Those are both discontinued formats and getting parts will be very difficult
HD DVD was shut down as a format once bluray won the war (kind of like VHS and BETAmax back in the day)
try opening units and cleaning the optic on the player VERY GENTLY with Qtip and rubbing alcohol and this might help
good luck
Posted on Mar 13, 2011
Their is a disc stuck in my Toshiba HD-XA1 plyer.All it says is ''welcome''.I tried to unplug it but still did not work
Hi
Thanks for using FixYa. Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Use a stiff wire,a paper clip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
To open the DVD player top to remove the cd/dvd manually--
  • Unplug the DVD player and take the outer casing of the DVD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  • Locate the disc loader cover. The disc loader cover is located where the extending DVD tray finally comes to rest within the DVD player. It’s the part that holds the DVD loader in place.
  • Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
Points to remember while performing above steps---
n Before you remove the DVD player cover, try turning the device off and then back on to see if the disc will come out after the machine has rebooted.
n Use the opportunity while you have the outer casing off to clean the lens of your DVD player.
n Never work on an electrical device that's still plugged in.
n Opening a DVD player may negate the warranty. Read yours carefully before you proceed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 22, 2009 | Toshiba HD-XA1 DVD Player
I put an HD-DVD in my player but it keeps coming back out.
Temporarily you can hold the lid closed with your hand and press play and leave the lid after it loads the disc. But for permanent solutuion you will require to repair its lid switches,
Aug 22, 2009 | Toshiba HD-A30 HD-DVD Player
Toshiba HD-E1 DVD Player - Region 1 dvd's problem
1) Turn on player
2) Open tray, put disc in tray but don´t close
3) Push T.search on remote
4) Push 1, 3, 9 and "Region number" (e.g. 1 for US discs)
5) Push T. search on remote.
You will see TEST on your player
6) Press PLAY on the remote
Aug 22, 2008 | Toshiba HD-E1 DVD Player
Toshiba Tv remote control
I NEED THE CODEOR CODES THAT TOSHIBA DVD-HD A30KU TU USE AND RECCEIVER ONKOY
Jun 09, 2008 | Toshiba HD-A30 HD-DVD Player
Multi Region Toshiba HD-E1 DVD
RCE Hack.
1) Turn on player
When player is turned off, this setting is cleared.
Mar 14, 2008 | Toshiba HD-E1 DVD Player
Removing region restriction from HD-EP10 HD-DVD player
dear sirs:
pls. kindly instruct me stage by stage to make my panasonic HD dvd player
model HD-EP10 REGION FREE. YOUR COOPERATION is appreciated.
tedayrom
ted.ayrom@yahoo.co.uk
Feb 28, 2008 | Televison & Video
Need Remote Code for Toshiba HD-A30 HD-DVD Player. Thanks.
just pick from here
http://www.google.com.au/search?hl=en&q=toshiba+dvd+remote+control+codes&meta=
you may not find the exact one but the basic functionality for dvds should work.
Feb 01, 2008 | Onkyo TX-SR605 Receiver
Unlock to use Region 2 dvds
No region hack for this player.
Jan 29, 2008 | Toshiba HD-A30 HD-DVD Player
Toshiba HD-A35 region unlock
I am in need to find what an error code is on my HD DVD player. The code is 408 bc 504.
Jan 19, 2008 | Toshiba HD-A30 HD-DVD Player
TOSHIBA HDDVD PLAYER A20
I have a problem like this but mine will play regular dvd's
and just stop playing hd dvd's . exact same message
gene
mrjazz1959@gmail.com
Nov 03, 2007 | Toshiba HD-A20
Toshiba HD-XA2 HD-DVD Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
