Question about Cell Phones
How do i set the time on my trac phone. - Cell Phones
  • 34 Answers
Simply by turning your phone off then back on, you should be able to correct this problem. The phone will reconnect to the carrier and retrieve the local time information.
Posted on Mar 13, 2011
4 wheel drive wont lock in on my 99 jeep cherokee.is there vacuum
are you on pavement, or offroad.?
99 Cherokee what transfer case?
if Part time system. then,.
are your tires on ice or dirt?
if not its cockpit error.
read the operators guide, on this.
if on ICE,say so, we can not know what transfer case you have
nor what tires are sitting on.
do tell, and we can tell you what good or bad.
here is the build list for these years XJ
what do you have. ?
The full time box, must not be in 4Lo , on pavement
unless it too is on ice .
All the transfer cases used on the Cherokee were chain driven with aluminium housings. Command-Trac was standard on XJ models built with 4WD.
  • 1984-1987: New Process NP207 Command-Trac, part-time only, 2.61:1 ratio with low range
  • 1984-1986: New Process NP228/229 Selec-Trac, full- or part-time, 2.61:1 ratio with low range
NP228/229 has a vacuum switch for 2WD-4WD selection on the fly and a separate manual lever for low range
  • 1987-2001: New Process NP231 Command-Trac, part-time only, 2.72:1 ratio with low range
NP231 has the following settings: 2HI, 4HI, N, 4LO
  • 1987-2001: New Process NP242 Selec-Trac, full-time or part-time, 2.72:1 ratio with low range
NP242 has the following settings: 2HI, 4 full-time, 4 part-time, N, 4LO
never post questions on 4wd unless you know what is there.
the transfer case, also has tag , telling what it is.
Jan 07, 2017 | Jeep Cars & Trucks
I have a 93 jeep Cherokee, it will move in 4wh and in 4wl but will not go back into 2wd?
Hello guy
try posting what 4wd system you have,? first.
command trac or select track, (the latter is full time)
part time or the full time system,
we cant guess it....
read the operators guide first, if a part time system only
as i suspect, stop driving on dry pavement.
it's only for ice, or dirt. part time. part time is not a full time system.
Command-Trac
shifting to 4wd on dry (means no ice) pavement causes, drive line wind up! and the gears to lockup. (see steering get tight in turns?> and is dangerous to drive it like this , you, me and the box)
posted here 100s of times.
http://www.rubicon-trail.com/4WD101/driveline-bind.html
the non grand Cherokee. early
had these choices
as you can see you need to first know, what NP box you have or
photo your shift lever for 4wd, an post it and we tell you.
more facts, on select trac. (totally unlike command trac)
Selec-Trac locking hub is used on 4WD Cherokee. Selec-Trac
utilizes a non-disconnect front axle. Engagement of 2WD or 4WD is
accomplished at transfer case by means of mechanical shift linkage.
System allows full or part time 4WD. Selec-Trac can be shifted into
2WD or 4WD modes from inside the vehicle at any speed.
unquote
next from the service manual,
4WD TO 2WD
1) Place mode select switch in 2WD position. Transfer case
should shift to 2WD and not allow shifting into 4WD or LO range. Axle
should shift after transfer case shifts.
2) To determine if front axle has completed a shift out of
4WD into 2WD, position mode select switch back to 4WD position while
operating vehicle at slow speed. If vehicle shifts into 2WD, axle will
ratchet. If shift is not completed, transfer case will shift into 4WD
and hissing sound will come from mode select switch.
end quote.
if unsure read the FSM book its free.
shows you both systems and how to diagnose it.
in the box, click Cherokee,,then click 1993, and behold.
the real deal.
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
May 10, 2016 | Jeep Cars & Trucks
What do I buy to get the s3 on tracfone service?
If this is even available on this phone you need
1- the phone unlocked since you will be changing the sim card
2- the phone unlocked and I don't mean the keyboard lock
3- the new trac phone sim card. ready for install
4- fully charged phone and the patience to install the card and set up your new trac phone.
Hope this helps
Apr 02, 2016 | Samsung Galaxy S Iii Gt-i9300 - 16gb -...
How do I change the time on Alcatel trac phone
Go to Phone Settings - General - Date and Time.
Mar 08, 2015 | Alcatel Cell Phones
I have a Hauwai cell phone and I use trac phone service but cannot use the microphone nor can I access the internet with this even though I pay for it every month
u have to check ye network data setting and it's a setting of yr services provider setting so go to network services store they give u proper setting and trac phone services has various settings so u have to talk with model number and id to customer support
Nov 02, 2013 | Allsop 29575 Ahola Hawaii Mouse Pad
When i try to send a picture on TracFone LG500g I get a message telling me I cant send/receive message
i guess u might have not activated mms setting. ask your network operator for these setting
Mar 12, 2012 | LG 500g TracFone
How do i set time and date on LG 800 G Tracfone
Just had to do this fix for my LG800. While the phone is on, press and hold the turn off button on top until the Trac Fone "signature" comes on and shuts the phone off. Then restart. The "system" will correct and display the correct time for you. 11-3-2013
Feb 18, 2012 | Cell Phones
I want to use a t-mobile sim card in a motorola trac phone
You want to use your T-Mobile sim card in a Trac Phone..... I hate to be the bringer of bad news. But your S.O.L Trac Phone mainly design there phones to not use any type of sim card. Thats why it is a Trac Phone..... Now say if you was with AT&T or T-Mobile had a Go-Phone then yes, you can use your sim card in it to keep all your information. But the company Trac-Phone there abunch of ***** that don't give you that option.
Jun 25, 2009 | Motorola Mobility TracFone C139-4 Cellular...
Trac phone says service disabled
I have a trac phone as well. My son did "something " and then I was unable to make/recieve calls and where my units display it now says "service disabled". I contacted trac phone at 1-800-867-7183 and spoke with tech support. After entering a series of codes into my phone I was able to use my device again.
Apr 22, 2008 | Lands Phones
Cell Phones Logo
27 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
